Question about Refrigerators
My kenmore elite refrigerator model #59676523500 s/n 1027822766 temperature control stays at 43 degrees..i would like to reset it at 38 which is recommended, but when i follow directions to press ^ pad..nothing happens..thanks
SOURCE: Samsung RS2556 - Refrigerator side is not cooling - Freezer is fine
Ok, what I found out is that there are codes built into the front panel. If you hold the top left and right buttons for 5 seconds, the fridge will reset. If there are no issues, the panel goes blank. If there is a dash in the right side of the panel, there is an issue with the fridge side. In the left, freezer side. The dash indicates a defrost problem. Only a couple of things can cause this. 1. Sensor 2. Heater 3. Fan, 4. control board.
Posted on Jul 02, 2008
  • 531 Answers
SOURCE: Ge model PSC25MSTASS digital refrigerator setting
check for frost in the freezer back wall
Posted on Apr 01, 2009
Bothcoasts
  • 10 Answers
SOURCE: kenmore elite refrigerator temperature controls
I am sorry I am not a top refrigerator expert. It sounds like there is a way to reset that. You most likely hold down two buttons for a period of a few seconds.
Sorry I don't have the time to search the net for that particular manual or way to reset that board. If you have no luck by tomorrow try me then.
Posted on Jul 27, 2009
  • 1218 Answers
SOURCE: My GE Refrigerator model GSL25JTFBBS stay in
Good day,
35 minutes would be considered nominal. That is the amount of time needed to heat up the cooling coils behind the rear panel in the freezer compartment, and then allow it to drain the condensate water out the drain.
The defrost cycle is made up of 2 parts.
The first part involves shutting all fans and compressor off, and turning on the heater/heaters mounted on the bottom of the cooling coil to above freezing. About 10 to 15 minutes.
The second half occures when a defrost thermostat mounted on the top of that coil senses the coil is above freezing. It cuts the power to the heaters, and lets the system just idle, while the water is allowed to drain out of the drain.
If that tstat is working properly, the food temperature is affected slightly but never to an above freezing condition.
The thermostat is a small 1" round disk clipped to the top of the coil.
Only one possibility, but that tstat could be hanging allowing the freezer coil compartment to reach a very high temperature. If so, it needs replaced.
You should also check to see if both fans and compressor start running as soon as the cycle is done.
Posted on Mar 12, 2010
SOURCE: My samsung refrigerator model RB1855SL is
Hey Luckydawg70, did you ever get the issue worked out? I'm experiencing the same thing with mine. I've been unplugging and replugging it in to keep it cold.
Posted on Mar 19, 2010
Have a kenmore refrigerator freezer works but not refrigerator
You mean "How to Fix a Kenmore Refrigerator That Is Not Cold But the Freezer Is Good?"
Well this what i say,
Kenmore combination refrigerator and freezers combine the short- and long-term food storage options in a single unit. There are some occasions when the refrigerator compartment might appear to be malfunctioning while the freezer box stays cool. Ruling out these occasions ensures you have done everything you can to correct the problem before calling for a technician if necessary.
1.Verify that the temperature controls for the refrigerator compartment are properly configured. Tap the "^" or "v" buttons beside the refrigerator's LCD temperature display until "38," the ideal temperature, appears. The compartment could have been set too warm. Allow 24 hours for the the appliance to reach 38 degrees Fahrenheit.
2 Check that the refrigerator compartment door closes completely, objects inside the appliance could be holding the door ajar. When cool air is allowed to escape, the internal temperature rises. Cracked, holed or corroded door seals may also raise the refrigerator temperature.
3 Change how you use the refrigerator compartment; storing hot or warm food strains the appliance and causes a rise in internal temperatures. Do not prop open the door or leave it ajar for more than a few seconds at a time for the reasons outlined in Step 2.
4 Contact Kenmore if the refrigerator compartment remains too warm for your food. There may be a problem with the motor or any one of the other parts that regulate the temperature
If this was helpfu.l please let me know.
Thanks for using FixYa
Sep 06, 2011 | Kenmore Top Freezer Refrigerator
Kenmore elite fridge, french doors, bottom freezer: water does not come out cold. What should the temperature settings be at (for fridge and freezer)?
Fridge 34-38 degres
Freezer below 29
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 17, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Red and Green lights both stay on AW1200 and now
The temperature in my office was 38 degrees yesterday. After I turned the heat up the printer "dethawed" and started working normally. I believe the problem was environmentally induced and therefore solved with the more moderate temperature. Thank you for your reply.
Jan 03, 2010 | Xante AW 1200 Laser Printer
My samsung refrigerator model RB1855SL is experiencing a temperature sensor issue. The freezer target temp is set to zero degrees and the refrigerator to 38. The unit cools itself down to the target...
We've had tonza problems with ours too, kept building up frost, temperature sensor acted up as well. Piece of trash if you ask me. Never fixed it (did not want to throw money at it). Amazingly we just got a new one... another Samsung.... (with 4 yr extended warranty though this time!)
Oct 13, 2009 | Samsung Refrigerators
Kenmore elite coldspot 106.55606400 --fridge not cold enough --
37 is the atual temperature that your trying to acheive. so to make it colder you would go down to 36 which is one degree cooler. hope that helps. thx peyton
Jan 31, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore elite refrigerator. both compartments (bottom freezer and top refrigerator)are not keeping with the temperature setting. the food is cool but not cold as it should be. how can I test to see if...
Really most folks have to keep their setting on their fridge on about a 6-7 or-8 setting with the amount of food that is kept in the fridge now.
YOU CAN KEEP AN EYE ON THE RELATIVE temp if you like by placing a fridge thermometer in the appliance. Optimal fresh food should be around 40-43 degrees F on average to keep things on the cooler side without freezing.
Hope this helps
Nov 27, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore fridge and freezer not cooling
Check to see if there is any ice built up on the back wall of the freezer. If so thaw the ice and take the back wall out of the freezer. next check to see if the fan is running in the freezer (evaporator fan) This fan is what circulates the air from the freezer to the fridge. If it does run then you have a defrost problem (if ice is on the coils and back wall). Then replace defrost timer, heater, and thermostat.
Nov 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Mod #76523
The problem is the fan unit that pushes cold air up to the fridg, usually located nere the back of the freezer.
Aug 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
