Question about Maytag MAV7600 Top Load Washer
I need to remove the lid on a may tag mav7600
Maytag MAV 8260 AWW Does not work at all. No water flow, no spin (even when filled with water from hose) Does it have an internal fuse? Where is it located? Is the large timer switch the brain of the...
Some model have fuse in top control panel, check lid switch, yes large button is the brains, it sometime can fail but usally only takes out 1 of the cycles.
Nov 02, 2013 | Maytag MAV7600 Top Load Washer
How do I change tag light
Open the trunk. Remove the fabric cover. Remove the ten or so nuts holding the rear lens assembly to the trunk lid. Remove the rear lense assembly from the trunk lid. There are six bulbs, part number 194, in this lense assembly. Two or the lisence plate and four for the tail lights. I would recommend replacing them all as long as you have it disassembled.
Jan 15, 2012 | 2001 Buick LeSabre
I need to know how to put the bulb in on the tag in a 2003 mercury grand marquis
the interioir panel on the trunk lid has to be removed to access the tag light bulbs.
Jul 30, 2011 | Mercury Grand Marquis Cars & Trucks
Maytag MAV7600 - loud noise on spin cycle
It's more likely something caught in the pump or bad pump. Remove the belt under the machine and check the pump pulley for noise.
Dec 26, 2007 | Maytag MAV7600 Top Load Washer
Washer does absolutely nothing.
I would hope you have a VOM or DMM.
Check 10 amp fuse first. may be located near L1 black input from wall plug. If you do have a fuse then investigate for shorts and get a few fuses. (not all will have a fuse)
Set Conditions White Cycle/ Temp Control Off/ Water Cold Cold
With lid open 2 Red wires at lid switch to Grnd should be 120VAC (Red feeds water temp selection / Temp control). If 0 then your lid sw internal spring is no good. Red should always read 120 VAC with lid open or closed.
Close lid lid sw Yellow wire should be 120VAC to grd.This wire is motor feed line if Timer enables "T" contact. Motor is now waiting for timer to provide Path.
The "T" contact N to wire 16 provides a timer bypass.
YOu did not mention if the timer moves at all!
That should get you going!
Nov 26, 2007 | Maytag MAV7600 Top Load Washer
Won't agitate
well, you might have to get a new washer. It sounds like the control circut is going out and the door switch is also gone. it would cost about the same as a new washer. sorry.
Nov 21, 2007 | Maytag MAV7600 Top Load Washer
Atlantis MAV7700
Got to take front cover of washer to get  at the screws to take out... to get lid to lift up
Sep 15, 2007 | Maytag MAV7600 Top Load Washer
Washer
Suem...Check your lid switch. With the lid closed, push on the atuator with a small screw driver...see if it starts agitating. Revised switch kit part number is 12001908. Catriver..post back.
Jan 26, 2007 | Maytag MAV7600 Top Load Washer
Maytag MAV7600 Top Load Washer Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
