Zanussi 1221W washing machine has a grinding noise and small shreds of plastic in the drum and doorway
During a cycle the machine made a grinding noise and when stopped and unloaded there were strips of shredded pale grey plastic in the clothing and around the drum front. Could this be the water seal between the drum and metal housing? The rubber door seal is complete and in tact. Can this be replaced/repaired?
5 Suggested Answers
catriver
  • 878 Answers
SOURCE: Replacing rubber seal on Kenmore Elite He3
Gowalia, it's going to be a fight without removing the front panel. This is the easiest and not that hard. Remove the top, by removing the 3 screws in the rear. The top will slide off toward the back. Next remove the control panel. Remove the 2 screws on each end on top. Remove the detergent drawer. Remove the torq screws behind the detergent drawer. The control panel will now snap off, pulling from the top and lifting up. Once freed, remove the control panel ribbon cable from the side of the main board. Now remove the screws holding the door switch mechanism in place. Remove the spring that holds the outer part of the boot from the front panel. Now remove the 4 quarter inch screws that hold the front panel and door on the front. Now you can install the new boot with ease. I know it sounds like a lot, but it is not that bad. Just reverse the process when the boot is on the tub. Make sure to have the mark on the boot ^ lined up with the mark on the tub on top. Catriver.
Posted on Sep 06, 2007
huuum
  • 750 Answers
SOURCE: Plastic inside door is shredding apart
Hello kwheersink
Welcome,
Make sure you are not using to much detergent.
You should be using HE, or High Efficiency Detergent.
And only the amount that the manual for the washer tells you.
To much and it will slowly destroy your Seal and bearing. Plus any rubber or plastic parts it comes into contact with.
Definitely replace this now!!
How old is the washer?
Let me know how you do and the answers about your detergent habits.
Waiting your response.
Thank You Huuum
Please remember to leave a rating!
Posted on Oct 13, 2008
  • 16 Answers
SOURCE: Zanussi IZ12 bearings gone & plastic fragments in drum
Probably all parts inside drum is ok.Heating element is the only damageable item and a sensor.Changing bearings you must separate the drum, all screws in middle of drum must out and then bearing and zimmerring can be changed.Jan
Posted on Feb 15, 2009
  • 40 Answers
SOURCE: Loud noise during spin cycle
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Posted on Mar 10, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
I have an LG top loading washer, model WT4870CW. During the wash cycle the machine makes a grinding noise. The noise does not occur during draining and spin cycles. Any idea what could be the issue?
Is your agitator moving back and fourth, when on wash cycle
Could be your plastic agitator spline is stripped,
Take it out and check the plastic teeth is not worn inside.
Dec 25, 2014 | LG Washing Machines
LG direct drive washer makes a grinding noise with power and moving it by hand. how much to repair?
sounds like the bearings have worn out. probably expensive, requires the machine to be dismantled almost completely.
Nov 12, 2013 | LG Washing Machines
Zanussi zwf 1221w drum bearing replacement, is this an easy job to do
This is not an easy repair to carry out, it involves a complete strip down of washer, and removing the whole drum assy from the washer, and until it is stipped down, you will not know if the drum shaft is worn, if it is, then this puts it way beyond an economical repair.
Feb 02, 2011 | Zanussi FLA1001W Front Load Washer
I have a zanussi washer/dryer but lately its making so much noise !! its driving me nuts please tell me what it could be ?? thanks
Hi
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The bellows is a rubber sleeve that seals the suspended outer tub to the stationary cabinet front at the tub opening. Its purpose is to provide a water tight opening into the tub that can be sealed by the cabinet door, yet allow flexibility for the oscillation of the tub during the wash and spin cycles.
Outer Tub Assembly
The outer tub assembly is supported by two suspension springs and stabilized by two air shock assemblies. A cement counter weight is mounted to the front of the outer tub by screws. A counterweight is molded into the rear half of the outer tub. These counterweights prevent excessive oscillation of the entire suspended assembly during an unbalanced spin cycle.
Spin Basket Assembly
The spin basket is constructed of stainless steel. The circumference of the basket is perforated to allow water to flow through it as it revolves. A heavy steel shaft is pressed into the spin basket support which is then bolted to the basket. The spin basket assembly is entirely supported by two ball bearings pressed into the rear of the outer tub. A large drive pulley is mounted to the free end of the shaft that extends through the rear of the outer tub. There are three plastic vanes mounted to the spin basket to aid in the washing action during the wash cycle. The rotation of the spin basket provides both the washing action during the wash cycle, and water extraction during the spin cycle.
High pitch "jet engine" noise--A certain amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in drum or pump. Stop washer and check drum. If noise continues after washer is restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To prevent unnecessary noise and damage to drum, fasten fasteners and turn items inside out.
Squealing sound or hot rubber odor-- Washer is overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a thumping sound. This is usually normal. If sound continues, washer is probably out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for details.
• Shipping bolts and foam blocks have not been removed during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and rearrange wash load.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 10, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
Feb 15, 2009 | Zanussi IZ12 Front Load Washer
Whirlpool Duet GHW9100 Drum Knocking/Plastic Tub Shredding
This is joyce
The bearings is gone in the drum, causing the drum to rub and run the wrong way one the pully, yes it is very exspensive, I have the newer model.
let me know if I can help
thanks
joyce
Feb 13, 2009 | Washing Machines
Noisy during some parts of the cycle
it could be the concrete ring situated at the front of the machine. i had the same problem with mine 2 years ago.
Jul 29, 2008 | Zanussi FJD1266W Front Load Washer
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Apr 23, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
