Question about Golden Technologies BuzzAround XP3 Travel Scooter
Buzzaround Scooter green light comes on then starts blinking 5 or 8 times and won't go at all
2 Suggested Answers
wcdoc1953
  • 280 Answers
SOURCE: Golden buzzaround scooter - new around 2003?
If you go this link it will show you the connections for the battery pack wiring. Essentially there is a jumper between one of the positive terminals on one battery and one of the negative terminals of the other battery to give you 24 to 27 volts in series. The two remaining terminals are for the positive and negative output voltage and the charger connections (run in parallel). Please see the following:
http://www.goldentech.com/pdf/support/ride/gb101-service-manual.pdf
Posted on Feb 20, 2011
The error lite on Buzzaround Lite scooter flashing
5 flash code is the electro magnetic Brake. This is referring to the brake on the motor that can be released by the freewheel lever.
1. place the freewheel lever into the free wheel position. Ensure the scooter is in free wheel and move the scooter forwards and backwards a few times.
2. Place the freewheel lever in drive position, push on scooter to ensure it is in drive and does not move. Turn on key and press the throttle. If you have the same code again, call a technician to check the brake, chances are it needs replaced.
Aug 25, 2014 | Health & Beauty
I have a buzzaround model #gb 101. the light is green. but i noticed the reset button is pushed under the deck that you put your feet on. could that be why its not running? even tho the light is gree
Lift out the battery module below the seat. Turn upside down remove about 8 or 10 little screws. Look inside for a wire connection that came off one of the 2 batteries. Also check the inline little fuse. Check ALL wire connectors as a lot of these come loose. Note, the circuit breaker will be popped out if tripped, IN is OK.
Apr 04, 2014 | Golden Technologies Buzz Around 3 Wheel...
JVC LT46J300 Blue Light blinking TV won't come on all of a sudden
These blinks to standby light are fault indications, called blinking codes. From the number of blinks occur at one time switch on, you can get an idea about the faulty circuit stage inside it. Count it. Visit this site. It has details about blinking codes to many brand televisions.http://electronicshelponline.blogspot.com/Pull up older posts there, either by its left side bar, or see it in Timslide option
Jun 24, 2013 | JVC LT Televison & Video
Scooter turns on will not move; also shuts off intermittently when going forward
hi okay can you confirm that the rear axle comes away from the main body ? if so please check the connections here where the axle connects to the main frame, a big problem area on these types of scooters.
Regards
Dec 16, 2012 | Golden Technologies BUZZaround Lite...
Hp desktop blinking green light won't come on
mine does that when it's in stand-by mode. I just push the power button and it comes on....
Assuming you've already tried that....push and hold the power-button down for 5 seconds and the power SHOULD go out. *IF* it does not, then disconnect the power cord in the back for 1min....then reconnect and try to boot. If it *DOES*, then do the same...unplug the power cord for 1min and reconnect and boot.
Tallon41
Sep 14, 2012 | HP Computers & Internet
Sonic pride scooter won't move led light flashes 3 blinks then 1 blink?
the slot in the pot stem has to be dead centre..
1. Misadjusted throttle.
2. Broken throttle pot or throttle mechanism
Regards
Sep 02, 2012 | Pride Sonic 3 Wheel Portable Scooter
My sony kds 60a2020 won't come on. When I push the
That is a error code and in several of these sets it means thermal fuse is blown--Google the model number with owner manual or service manual to learn for sure.
Jun 07, 2012 | Sony Televison & Video
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
I replaced the ty-la1000 lamp and now when you turn it on the green light comes on then a yellow one blinks and won't come on what do I do
Which light is blinking yellow/orange and can you count how many blinks in 5 seconds its doing and let me know as thats an error indicator.
Jun 09, 2011 | Panasonic PT-43LC14 43" Rear Projection...
Led Flashes 5 times - Brake in freewheel or brake connection problem. How can I fix this?
Pull the key out of the plug or key switch. There is a freewheel/brake release lever sticking out of the top or back of your scooter on the driver's right hand side. Push this handle the opposite way it is now and try the scooter. If this does not work, repeat the steps above. It is important to do this with the key out of the unit or it will not reset.
May 10, 2010 | RTO Golden Buzzaround Lite Scooter Meets...
Golden Technologies BuzzAround XP3 Travel Scooter Logo
108 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
