Question about SanDisk Sansa e250 MP3 Player
Cant get the music from the computer to the player
We did what it said but when we open my computer it doesnt have the sansa thing to click on so we got the music from lime wire but dont know how to get it on the mp3 player
  • 8,596 Answers
Open Windows Media Player and see if Windows Media Player will recognize the player. If not, change the USB mode to MTP mode per the manual's instructions.
Posted on Jan 04, 2009
I cant find place to add music files to my player, SanDisk Sansa m240... I go to my computer open the files and find no music library
use windows media player... open WMP connect your player it should recognize it... use this to sync music to your sansa...you highlight the songs in WMP right click ... go to add music .. select sync .. once you get the songs into a sync list ... you just sync the sansa...
Oct 16, 2009 | SanDisk Sansa m240 MP3 Player
I want to erase every thing off my sansa
Ok, plug it in your computer, open "My Computer," open up your Sansa, open up the file named "Music," select all the files, right click them and click delete. Now go to the Recycling Bin and delete all the music files that were on your Sansa. Sometimes the Sansa doesn't realize that files are gone until you delete them from the Recycling Bin, crazy I know, but it's true.
Hope it helps!
Jun 07, 2009 | SanDisk Sansa e250 MP3 Player
Sansa E280R resets when i open Music folder
if that doesnt fix your problem try this...
1 connect your sansa to comp via usb cable
2 right click start on windows desktop go to explore
3 scroll down to your sansa's drive rifght click it go to properties
4 go to tools tab and click "check now" under error checking will take awhile and will erase your memory on the sansa but it will probably work again
I hope my post was helpful let me know!!!!
Mar 14, 2009 | SanDisk Sansa E280 MP3 Player
How do i get music from i-tunes to my sansa
ok plug up your sansa and open up it contents from its file in my computer,
then go to your library in i tunes and try to click and drag the files from your libray in i tunes to the sansa file it should work but if it doesnt then you have to go to your music file on your computer
and place the file from your i tunes in there and tranfer them to your sansa from there
HOPE ALL GOES WELL FOR YOU
Dec 28, 2008 | SanDisk Sansa Fuze MP3 Player
Cant remove songs
try opening it up in rhapsody or windows media player and delete the songs through there.:
  1. open either rhap or wmp
  2. the devices should be in a tab to the left (rhap) or on the top (wmp)
    1. for wmp, it might be in a tab in a tab
  3. click on the music "+"
  4. and from there delete the music
Apr 23, 2008 | SanDisk Sansa e250 MP3 Player
Cant i plug this thing into my xbox 360?
Go ahead and do this, in case the DB is corrupted:
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 25, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e280 not working
I had the same issue. Plug the player in your PC. Go to "my computer" right click the Sansa player. Go to Properties and then select the "tools" tab. Run the error check and the disc defragmentation
Mar 25, 2008 | SanDisk Sansa E280 MP3 Player
Poblems putting music in my sansa
The problem you are having right now is because windows media player doesnt recognize your sansa..You need to make sure that your device mode is under MTP mode...To check that you need click on tools, menu, usb mode..and its going to show you the mode..select the appropriate one..Then make sure your computer has all the latest update from microsoft...check to see if your device is listed under device manager..if it is uninstall it and reinstall it..to check to see if the device is listed under device manager...click on start menu, right click on my computer, right click on properties, click on hardware and then device manager..sometimes it might have a yellow exclamations mark next to it..right click and uninsatll it and reinstall it..But make sure you have that device plug in on the back of your computer instead of the front..Let me know what happen before you rate me..
I hope that helps
Please rate accordingly
Thank you
COmputerrep
Mar 23, 2008 | SanDisk Sansa e250 MP3 Player
Wont open music folder
The folder option won't work particularly well - use Windows Media Player instead. If you continue to have problems:
Feb 29, 2008 | SanDisk Sansa e250 MP3 Player
Deleting songs
Chances are that you are using windows xp. open up your sansa folder to where it says pictuer, movies, ect. look at the picture to see what to do. In your player folder click tools --> folder options --> View. Under hidden files and folders click 'show hidden files and folders, click ok. The music folder would now show up where the videos and pictures are. Simply open the music folder and delete the ones you do not want. By default the songs are sorted by artist --> album --> song.
Mar 16, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
