Question about Dell Computers & Internet
Dell t3400 power for 2 hard drives
A friend added a second hard drive to my desktop but I dont know how to hook up the power cord(s) properly. Because he was short a cable, he borrowed the power supply from the CD rom and now that I have the proper power cord, I dont know where it goes. He's too busy to help me and I cannot load any software until I can use the CD Rom again. I need idiot-proof images and instructions if anyone is willing to help.
  • Shelby Oct 31, 2012
    Can't thank you enough - I greatly appreciate the time and trouble you went to in explaining this!
  • Dell Master
  • 5,660 Answers
Not a problem.
This is a general view of a SATA -> data cable, and it's respective connector on the motherboard,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
Note the L-shaped opening in the SATA data cable's connector, and matching L-shape on the SATA data connector on the motherboard.
Note also that a SATA data cable's connector has 7-pins
Between it, and a SATA power cable connector, the SATA data cable connector is the smaller of the two.
A SATA power cable has 15-pins,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
Note that it's cable connector opening is also L-shaped.
So is the matching connector on a SATA harddrive, or SATA optical drive. (CD/DVD drive)
A SATA power cable's connector generally has an area on it, that you depress with your thumbnail, and this releases a Lock.
Depress to install, depress to remove.
SATA data cable connector, Or SATA power cable connector; that goes to a Harddrive, or to an Optical Drive, is usually a 90 degree bent elbow.
The straight connector on the cable plugs into the motherboard.
(Can be straight connector on both ends through, but isn't CORRECT)
SATA connectors on motherboard;
IF, this Ebay link selling a Dell Precision T3400 Desktop PC motherboard, is correct, there are;
http://www.ebay.com/itm/Dell-TP412-Precision-Workstation-T3400-Socket-775-Motherboard-/360503300257?pt=Motherboards&hash=item53efabd0a1
1) FOUR Black SATA connectors
2) ONE White SATA connector
3) One Blue SATA connector
1 Black SATA connector, and 1 Blue SATA connector, at the bottom of the black Ram Memory slots.
1 White SATA connector, and 3 Black SATA connectors, right next to the where 24-pin ATX main power cable, plugs into the motherboard.
General example of said main power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
(Note* Color of connectors does Not matter )
Originally the Master harddrive, should plug into SATA1 connector on the motherboard.
If you look real close, next to all of those SATA connectors on the motherboard, you may see SATA0, SATA1, SATA2, SATA3, SATA4, and SATA5, printed right next to them on the motherboard.
The beauty of SATA:
DOESN'T MATTER WHERE YOU PLUG IN WHAT, on those SATA connectors.
Use ANY one you wish, and plug whatever SATA device into it, that you wish.
BIOS will find the SATA device.
No matter what SATA connector you plug into, and no matter what SATA device.
Kapish?
http://support.dell.com/support/edocs/systems/wst3400/en/ug/ug_en.pdf
What a minute, this news just came in.............
The Blue SATA connector on the motherboard, under the black Ram Memory slots, is SATA0.
The Black SATA connector next to it is SATA1.
If you have SAS harddrives (Serial Attached SCSI), the power cable's connector has a provision, to plug the SATA data cable into it also.
If you do not have that particular SAS power cable it's OK.
You can just use a separate SATA power cable, (90 degree elbow to harddrive/optical drive), and a separate SATA data cable.
For additional questions, or to have me clarify further on anything I have stated above, post in a Comment.
Regards,
joecoolvette
Posted on Oct 31, 2012
  • 1 more comment
  • joecoolvette
    joecoolvette Oct 31, 2012
    http://support.dell.com/support/edocs/sy...
  • joecoolvette
    Edit: Didn't correct; The master harddrive should plug into SATA0, not SATA1. I was thinking SATA1, SATA2, SATA3, SATA4, SATA5, and SATA 6. Not SATA0 through SATA5.
  • joecoolvette
    You're very kind the_becke310, Thank You for the rating!
map9966
  • 2351 Answers
SOURCE: The disk drives don't work!!
Hi mrkennx6, did you install windows Vista? If that's a yes try updating your windows through windows update. (Vista may have posted a fix for this issue).
If your not running Vista than try this.
1. Shut down your PC & unplug the power cord from the PC.
2. While facing the PC & looking at the front og the PC, remove the left side panel of the case. (Click the link to learn how to remove your computer cover).
http://support.dell.com/support/edocs/systems/dim1100/EN/SM/index.htm
3. Remove the power cable from the back of each cdrom drive.
Shown here at this link. http://support.dell.com/support/edocs/systems/dim1100/EN/SM/parts.htm#wp1088942
4. Re-connect your power cord & start your PC. Allow windows to finish loading. When it has finished, click the start button & shut down the PC.
5. Unplug your power cord from the PC.
6. Re-connect the power cords to your cdrom drives.
7. Close your case & re-connect the power cord to PC.
8. Power up PC & allow windows to load.
(Windows will re-install the needed drivers for your cdrom drives).
Good Luck!
If I can be of more service, just ask.
Mike
Posted on Apr 06, 2008
edisonfrelan
  • 113 Answers
SOURCE: Just purchased IBM Intelistation 6221..installing windows????
hi! try this. reboot your cpu, then press the CMOS setup key (del), then select load default setting, then go to hard disk detection settings, select the LBA setup. I believe you know how to manipulate the CMOS setup configuration. if still doesn't work out, bring it to the service center near you and ask for assistance, Im sure they would love to help you. Have a nice day!
Posted on Dec 20, 2008
Code Blue
  • 86 Answers
SOURCE: emachine t2984 - need to diagram to install power & hard drive
There is 2 main cables you have to worry about to feed power to the system. One looks like a big rectangle block with a mess of wires attached. Make sure he is hooked into the system. Then if its an newer unit you will find a plug that has square look to it with just 4 wires attached and should plug in nearby the processor. (only newer units us this) Also if your dealing with the cant turn it on issue make sure to remove all cards off the board like the NIC, Video Card, and Audio Card. I am unsure as to weather or not your system comes with everything onboard or if its stand alone cards. If you still cant power on theres a bigger issue at hand and that maybe that your motherboard has blown.
Posted on Mar 16, 2009
crapiemael
  • 241 Answers
SOURCE: Dell Dimension 8300 - Can't Boot from XP Disk
When in doubt do without, that is remove the new hard drive cable and power, remove the DVD drive and try loading booting the XP from just this CD device. Enter the BIOS and check if the system sees the device. If it's not found in the BIOS then you'll never boot anything. Address it as the Primary device on the cable (I don't use CS) and see if the BIOS sees it.
If you get CD device seen in the BIOS then try to boot the CD in it. If it boots then power off and connect up your 40gb drive (optioned as Primary) on the other cable. Now power on as check the BIOS for the drive and the DVD device. If both are seen then boot the cd and try to load XP. After it's up and running install the other CD device as a Slave on one of the cables.
Posted on May 28, 2009
  • 3940 Answers
SOURCE: Hard Drive Upgrade to Dell Dimension 3000
Try this Boot to the BIOS
press ALT+E (single Beep)
ALT+F another beep
ALT+B system will reboot and re-detect drives
once done, you should be able to install XP on HDD
Posted on Dec 30, 2009
Tool prepair Bios Dell precision T3400
If this desktop can boot to BIOS properly, then you can download the BIOS file from Dell's website, make a bootable media (using other computer) and use this media to update your T3400 BIOS.
Mar 04, 2014 | Dell Precision T3400 PC Desktop
CD Drive won't open
a lot of info for what sounded like a simple question. i first thought that maybe you did not have the CD wiring connected properly? if the pc powers on, then that would be my first guess, check the wires you hooked up to the cd player. then 'if ' you have problems with the install of the OS, can the cd player read DVDs? software can be on dvd not cd so the cd player would not work. if you can get into dos, or select PF2 or PF12 on boot to see where your cd is in the boot sequence or even listed. more detail on what you have tried is required when trying to solve an issue. Many of you do not give enough info on what has already transpired in trying a solution yourself. good luck
Jan 12, 2014 | Dell Precision T3400 375W 32bit Computer...
Dell XPS 600 - BIOS does not identify or see either DVD or Cd drives>
Turn the computer off, unplug the power cord and open the case. Check the connectors running into the back of the drive. Make sure they're seated properly, as well as the slot on the motherboard the drive hooks into. If the BIOS still isn't seeing the drive after this, then there is either a failure with that slot on the motherboard or a failure with the drive itself. You can always take the drive out and test it in another desktop to make sure it's not your motherboard.
Mar 09, 2011 | Dell XPS 600 PC Desktop
How do you connect two hard drives to a computer?
1. For SATA, you just need a second SATA cable to plug it in and a power cable from the power supply.
2. For IDE, you will need a second IDE cable to plug the second hard drive, AND you will have to set both hard drives jumpers either to cable select or one Master and the other one Slave, based on which one you have the operating system.
Nov 12, 2010 | Maxtor Hard Drive
I had a issues with my power supply no after i
Check to make sure that everything is properly hooked up again. You hard drive may have power flowing too it, but it may not be hooked up to the motherboard and reading properly. Just check to see if everything is properly hooked into the right spots. If it is, make a comment on this letting us know and I'll see if I can figure it out from there.
I hope this helps.
Oct 14, 2009 | Dell XPS 700 PC Desktop
How do I add a second HD
Turn the machine off
Open the case
Look to see if there are IDE connector (Wide Flat cable with a connector usually grey)
If this is not present look for a SATA connector usually a small red or blue wire similar to a cat5e network cable
Scew your HDD in place in the rack connect the cable either IDE or SATA
If you have an IDE drive look for a 4 pin female connector from the power supply
If you have a SATA drive look for the connector from the power supply
Once all is connected then reboot you computer typically your bios should auto detect it.
Let me know what happens from here
Sep 19, 2009 | Dell Precision T3400 375W 32bit Computer...
Dell dvd drive
After you remove the case you will see 2 screws on each side of the drive (total of 4 screws) remove them and unplug drive then you can replace it.
Mark
Apr 06, 2009 | Dell Precision T3400 375W 64bit (bwcw9z6...
Hard drive is not detecting intermediately
try a different SATA power connection, sometimes they work loose and this issue occurs.
Apr 03, 2009 | Dell Precision T3400 PC Desktop
Steps to add new hard drive to my dell dimension 2300
YOu can refer to this site..they are all the same procedure in adding hard drive in a computer.
http://www.infohq.com/Computer/adding-second-hard-drive-review.htm
melnavz
Nov 10, 2008 | Dell Dimension 2300 PC Desktop
Computers & Internet Logo
487 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
