Marantz amplifier pm-44se setup manual - Audio Players & Recorders
petraman7
  • 1175 Answers
SOURCE: Can I remotely control speaker outputs on the Marantz PM 8003?
HI...
You need an 8 ohm stereo "L-pad"
Try partsexpress.com
or
mcmelectronics.com
Posted on Jan 09, 2009
  • 66 Answers
SOURCE: Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
Posted on May 05, 2009
  • 4 Answers
SOURCE: sound probem of marantz amplifier at right side.
sure it is not the speaker?
switch them and check
Posted on Mar 02, 2010
petraman7
  • 1175 Answers
SOURCE: marantz amplifier pn 50
www.stereomanuals.com
Posted on Apr 14, 2010
  • 65 Answers
SOURCE: can i connect a subwoofer
Ideally you would use a signal processor between the source and amplifier/ new sub, but if you have multiple sources the easiest way would be to run an active sub (with an amplifier built in) from the TAPE OUT of the amplifier.
Have a look at this: http://www.superfi.co.uk/extras/BandW/BW_ASW610_manual.pdf
Figure 5 illustrates what I have described.
Posted on Sep 09, 2011
Marantz pm 520 dc, service manuals and schematic diagram
As a former authorized service center for Marantz in the 80's, I probably have the manual for a cost.
Apr 28, 2014 | Marantz Audio Players & Recorders
No power going into my marantz 44se amp.
Check AC main fuse inside the amp located next to the power transformer, if the fuse is open, just put another and if it blows let the amp as is, because if you put more fuses and blow them you just add more damage to the amp, let me know your results.
Oct 12, 2013 | Marantz Audio Players & Recorders
The fuse keeps blowing in my marantz pm-57 amplifier. It says it takes a T 2.5A 250V fuse. I can only find 2.5A 250V fuses. What relevance is the ''T''.
Goo day sir, the T on the fuse has nothing to do on you marantz fuse blowing up, chances are you amplifier is shorted, check you IC amplifier/power transistor for shorts. Check also your speaker impedance. usually they are 8 ohms. You can use a technician's multitester device to check the impeadance. An imbalance or mismatch speaker can cause a fuse to blow and destroy your amplifier. hope this helps.
Jul 31, 2009 | Marantz PM-15S1 2-Channel Amplifier
Marantz pm 15 s1 amplifier and marantz sa15 s1 Cd player
There really is no point in  connecting the two components with an optical (=digital) cable, if you didn't want to use the SA-15s DAC- and analog output section you might aswell have bo bought the chiepest one you could find...
To get better sound than the SA-15s analog outputs can provide, you would have to spend a load of money (not as much as for the SA-15 but quite a bit) on a DAC - and the DAC would only work with CDs, you would still have to use the SA-15s analog outputs to listen to SACDs.
So in conclusion:
-Use the SA-15s analog outputs
-If you have other digital sources that you want to use - if you care about their sound quality - you can sell/return the SA-15s, buy the chiepest CD-Player you find (only look and feel matter) and spend the rest on a good DAC. (note: SACDs won't play on this setup)
I'm using a PM-15S1 with a DAC (Apogee Mini DAC, Studio-Equipment, nominal price ~1000$, got mine 2nd hand for 400€ ) myself. A DAC is usually the better choice over an expensive CD-Player - especially if you've got other digital sources (PC, ...) - but you'll probably lose a lot of money if you sell the SA-15, so think about it (IF you're still thinking about it, I realise that your question is 8 months old...)
anyway... have fun with the PM-15, it sure is beauty
Jan (Hamburg, Federal Republic of Krautistan)
Jul 01, 2009 | Marantz PM-15S1 2-Channel Amplifier
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
HI...
or
mcmelectronics.com
Dec 21, 2008 | Marantz Audio Players & Recorders
Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
Marantz pm 7200
Could be a power supply failure or a Power "On" switch failure.
Kev
Feb 23, 2008 | Marantz PM7200 2-Channel Amplifier
136 people viewed this question
 Grubhead
Grubhead
