Question about Exercise & Fitness
Error codes cyclone sx9.0 max pro tread mill has ''err 1'' on display when you try and start it up, its had very little use, ony about 10 hours in two years, anyone have a user guide or know the error codes??
  • 1 more comment
  • carl1968 Jan 15, 2009
    thanks for that mate, i will have a look and report back.
  • Anonymous Feb 19, 2009
    im getting S I code and it wont start
  • Wendyc50 Feb 23, 2009
    I have similar issue. My tread mill, Lifestyle 8.0ESP is old but has been a great treadmill. I am getting error codes EEEE and PO, also says to call customer service before further use. Can anyone help with these codes?
I get a 51 code on the treadmill, I think the relay is bad, Can I get parts for this? Pat please respond to dme@gmx.com
Posted on Jan 30, 2009
Error 1 is many times a speed sensor error. Make sure the speed sensor is in place, working and sending signal to the motor control board.
Posted on Jan 15, 2009
I have a fuel fitness tread FT94 and an errow code keeps coming up E6. What does this code mean and how can it be fixed ? tread mill will not start up
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.Check for treadmill error code
http://electro-medical.blogspot.com/
Mar 08, 2016 | Exercise & Fitness
I don't have users manual for pro fitness tread mill keep getting a fault saying E1
https://www.google.co.uk/search?q=Star+Trac+Pro+S+Treadmill+manual&ie=utf-8&oe=utf-8&gws_rd=cr&ei=-N_0VMutKufR7Qb_-IHgDw
youll find the manual
here is the service manual and maintance details you need to do
http://www.sportsmith.net/images/product_support%5Cstartrac%5CTechnical%20Manuals%5CTreadmills%5CSvcMan%20ProTread.pdf
Mar 02, 2015 | Startrac Fitness Products Star Trac Pro S...
How do you fix error code eo1 and err
For one, you have a multi-cooker, it is not a pressure cooker. Try posting your question in the Slow Cooker category.
Oct 03, 2014 | Euro-Pro Ninja 3-in-1 Cooking System
Tread ajustment
under the shroud cover there is a bolt that loosens the tension on the belt...be sure the belt sensor "sees" the belt as that is why you have an E-1 error code
Dec 03, 2013 | Exercise & Fitness
Turn tread mill on. counts 3 seconds and the belt does not move. the console goes blank after 8 seconds then e1 flashes.
follow this steps and fix it. See the diagram attached. God bless you
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.6698c5a0-3470-4d34-bd47-9422824cf011.gif
Of course you must lube the deck belt. see the video attached.
Sep 20, 2013 | Exercise & Fitness
How the error e02 on fit king treadmill be repaired
Dear sir,
I am having a treadmill of Fitking model no. W590 it is showing error code e02.
Kindly suggest what to do. I am eagerly waiting for ur response
Rgds
Yash Pal
Jul 15, 2013 | Exercise & Fitness
Soft strider by healthrider tread mill does not function and the error code PO comes up any suggestions?
1) Please exchange batterires for a new ones.
2) Tight the flexible cables from keypane vs display board.
3)Tight the connector from display board vs lower board(Main motor board)
4)Adjust the reed sensor switch by 1/8" or 3mmsSee the diagram attached.
5)Measure input voltage for 115 Vac to input of main motor board
6) Measure input for power supply for +5VDC to main motor board.
7)Measure output voltage for +5vdc to Display board.
8) Finally see the block diagram that I am attached that I did for people like you. For easy diagnostic and troubleshooting.
Sincerely. Merry Christmas.
Ernesto CuaddraManagua, Nicaragua.12_24_2011_4_58_14_pm.gif12_24_2011_4_58_29_pm.gif
Dec 23, 2011 | HEALTHRIDER R60 SoftStrider Treadmill
Lubed belt but display still says lube belt and I cant do anything how do i clear the display I have the horizon gs950t
After lubrication you have to reset your treadmill settings. Then only the message will go off. To reset the tread mill do the following.
1. Hold the "Stop" button for three seconds to reset the treadmill and clear the current workout selection or screen. The console will reset but will save any accumulated data
2. Press and hold the "eTRAK" button for 10 seconds to reset the console date. This permanently deletes any previously accumulated data
3. Press and hold the "Stop" button while pressing the Speed "+" button. Hold for five seconds to reset the console after applying lubricant to the machine. Lubricant application is usually only necessary when you receive the "LUBE" error
ok
May 04, 2011 | Horizon Fitness Horizon T90 Treadmill -...
How can I reprogram Nissan pulsar car radio a battery change which has deleted memory? panel shows error message only ERR.
You will need to turn the ignition on (do not start the car) turn on the radio and leave it on for anywhere between 1 - 3hrs untill it prompts you for a code.
There is a internal timer which adds time depending on how many times the code is entered wrongly.
Do not start the car, or turn off the ignition or radio during the 1 - 3 hr period.
Hope this helps.
Thank you
Adam
Apr 27, 2008 | Audio Players & Recorders
Exercise & Fitness Logo
1,164 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
