Question about Antari Z-300ii Fazer Fog / Haze Machine W/r-ships Free
Antari z300 low fluid indicator shows "low fluid" but the machine is filled with fogger fluid. All lights on remote do turn on, also the heater and fan works. There is a minimum amount of fog produced (almost not visible). there is fluid in the tubes from the tank to the pump. I tried to shortcut the low fluid sensor, but no change in behaviour. Please advise.
2 Suggested Answers
  • 5603 Answers
SOURCE: My Antari Fazer model#Z-300 II
Most fog machines require cleaning maintenance periodically. I would check the fluid lines are free flowing and unclog if necessary.
Posted on Jun 29, 2011
Boss DR-3 Dr. rhythm LED screen lights up by does not show any information. what can I do to fix problem?
take it appart. there is a conductive rubber between lcd pannel and the pcb use widow washer fluid without amonia to clean it
Jul 20, 2016 | Roland Boss Dr. Rhythm DR-3 Drum Machine
Our Antari Ice low lying fog machine is warming up (light goes green), however when you press the controller to produce the fog, nothing comes out. The fan is working, but no fog coming out. Any urgent...
check the fluid pump's output. you may have have a clogged or kinked supply hose to the pump or in the copper tubing from the pump to the heater. Also, check the power to the pump. if it's not the pump, then you have to consider a clogged heater block. This is common if the machine is not cleaned before storage. That's about all that can go wrong on a fog machine other than the switches on the controller. Good luck!
Oct 17, 2013 | Antari Ice Low Lying Fog Machine +
Is the flash sequence of the green fluid level indicator significant? Antari Z-300ii .
I have this one and i know also its features like 700 watt capacity and it is also provides fog fluid separately.
froggys fog
Mar 23, 2013 | Antari Z-300ii Fazer Fog / Haze Machine...
The "PROTECT" light indicator came on and now the
The protect light generally comes on when the is a short in the speaker cabling. as a test, turn on the mixer without any speakers hooked up. If it still goes into protect mode the problem is in the mixer. Take it to your local music store and have their tech look at it. if it doesn't go into protect, check the speaker cables by plugging them in one at a time. The bad one will send it into protect.
good luck
Sep 12, 2011 | Fender 150 Watt PA System
Even with the output turned to maximum the fog is thin and dissipates quickly. I have followed the cleaning instructions within the manual and I am still having this problem. What else could cause this?
A common problem is the use of the WRONG fog juice. Make sure you use the manufacturer's suggested product. Make sure you have the correct voltage. Use of a very long extension or attempting to run on a dimmer box also would cause the problem.
Jun 16, 2011 | Elation New Elation Ice 101 Low Fog...
No light shows where "On","Off
Not all on/off switches are lighted. You haven't even told us what device this is you have.
Feb 08, 2011 | Music
American dj mini fog, I conected to wall, but the machine doesn't gets hot, and not make smoke, why?
There are two switches/buttons on top... You have to both turn on the unit and also activate it with the second button OR using a remote plugin box. The heater takes a bit of time to warm up internally. You will not sense much if any heat outside the unit... They take a few minutes to come on. Make sure you use approved "fog juice" in the unit.
Dec 18, 2010 | American DJ Mini-fog - 450 Watt Fogger Dj...
DJ LIGHTS
MOST DJ lights are not protected to be used outside in weather.
Other considerations are visibility from highways and also aircraft. Certain lights could cause a problem for these two scenarios.
When outside, often the distances are longer and the light drops off as the square of the distance.
Laser types require fog to get the effect and there really isn't a way short of getting the weather to cooperate and give you fog to get those effects.
Between the laws of physics and the construction of lighting intended for interior use, what you are asking for is just not easily obtained.
The inability to control ambient lighting outside is a real problem. Many of the DJ things require a fairly darkened room. The sky glow from a city is enough to kill off the effects.
May 19, 2010 | American DJ Flash Beam Lighting Effect
Antari Z-300ii Fazer Fog / Haze Machine W/r-ships Free Logo
111 people viewed this question
Top Antari Music Experts
Vito Vacirca Jr.
Are you an Antari Music Expert? Answer questions, earn points and help others
