Candy CDB 854: Just installed, spin tested briefly. Now just lights and no function.
Hi, Per the titles, I've just had my new washing machine installed. The engineer put the machine on spin and it worked. He leaves, 60 minutes later I go to do my first wash and when I turn it on half the light are on and stay on. Turning the dial, pressing the buttons, nothing alters the lights that are on, and no programme starts. No error code appears. Just half the lights. It's now off on the dial and off on the wall. Does this sound like a fault? Will it reset itself by being off at the wall for a certain period of time? Many thanks, Lloyd
  • Lloyd Jenkins Oct 30, 2012
    This is a washing machine. Not a router. No matter how much I selected washing machine when raising the issue it kept choosing router! :)
  • 998 Answers
Turn the power back on, go through the instruction book to start the machine up. If its still not right, call the Service Agent. Its brand new and will be covered by warranty.
Posted on Apr 27, 2017
  • 1294 Answers
SOURCE: "Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Posted on Dec 02, 2007
  • 96 Answers
SOURCE: Zanussi ZWF1437W washing machine - wont start
The error message "Err" usually indicates that the wash program and option are not compatible. 40 degrees and 900 rpm Spin should be o.k.. I would try another wash program with no special options and see if the problem goes away.
Posted on Mar 07, 2008
serra_baby
  • 144 Answers
SOURCE: CNET CWR-854 Wireless G problem.
hello!
you may try this and see if this help solve your problem
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear
stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
if this still didnot work, maybe you need to upgrade the firmware of your router
Posted on May 05, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Wireless
Next to your clock on your notebook is there an icon that looks like a computer monitor with a radio signal to the right of it?
If so move the mouse over to it and press view available wireless networks.
Im not sure how to scan for it on the Wii. I would check to see if there is a scan funtion on it to look for it.
Does a Wii require a wireless network adaptor or is it built in?
Posted on Jun 13, 2008
SOURCE: ariston margherita washing machine
I have an old Margherita washing machine year 2000, my problem I don't have user's manual. Can you please provide me or teach me how to operate the machine?
Thanks & regards
ray salac
Posted on Sep 03, 2008
Where is the filter located on my candy CDB 115 Washer/dryer
https://www.manualslib.com/manual/450725/Candy-Cdb-115.html
Dec 09, 2017 | Candy Washing Machines
I cannot get my Candy GOFS262 on a 'SPIN ONLY' cycle? It just fills with water, drains and spins? I only want to spin some already wet laundry - HELP please?
this is a problem with these machine turn the selector anti clock wise slowly to spin as the contacts on the selector wear out or try clock wise but slowly some times this works
Jan 31, 2015 | Candy Washing Machines
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3319-candy-grando-washing-machine-series-fault-codes.html
hope that helps
Jan 15, 2014 | Candy Washing Machines
My candy GOFS262 washing machine is filling the drum to the top with water on every cycle but doing nothing else after that, the clothes jst sit there in the water, I've left it to see if something...
see this causes and fix it. God bless you
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission.
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Oct 11, 2012 | Washing Machines
Could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
Dec 10, 2009 | Candy Washing Machines
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
