Question about Reebok Exercise & Fitness
Need to unassemble to move treadmill
Trying to move treadmill need assembly manual
2 Suggested Answers
  • 3567 Answers
SOURCE: Hi! I need the assembly
It ain't rocket science. Have the dealer put acid in the battery so it is ready to go into the frame pocket. It should come out of the crate with the rear wheel already mounted. The controls on the handlebars should already be mounted as well. Put the handlebars in position and bolt them in place. Put a box, or whatever you have, underneath the frame to get the front forks higher than the axle on the front wheel. Now put the front wheel assembly in place and insert the front axle. Add the washers and nut and tighten the nut. If the bike has headlights, remove the glass bulb assembly and hook up all the wires. Match the color coded wires; Black to black, blue/white to blue/white, green to green and so on. Mount the shift and rear brake levers if not already mounted. Ad fenders and turn signals and whatever else needs mounting. Install the battery, red wire to the positive battery terminal, black wire to the negative terminal. Now put some gas in the tank and turn on the gas petcock at the bottom of the gas tank. Note; some bikes do not have an actual valve for the gas. Turn the key on and watch for smoke from the wiring. If you hook the wires up wrong they can burn. If all is well, ( relax, all should be well ), go ahead and kick start the engine. Again, watch for anything odd. Now re-mount the headlight assembly and go for a test ride. Adjust the clutch and brake levers as needed. All done! You may want to ride over to the dealers and let them look at it just to be sure all looks okay.
Posted on Mar 11, 2011
HOW DO I UNASSEMBLE TREADMILL TO MOVE OUT
The opposite to when you assembled it.
May 14, 2018 | Exercise & Fitness
Nordictrack 1900c treadmill making a horrible loud screeching noise when turned on
Sounds like your belt is slipping. Check your manual, it'll probably tell you how to service it.
Jan 25, 2015 | Nordic Track Exercise & Fitness
Disassemble
You should look into Youtube for a vid of dissassembly and reassembly. Youtube is a wonderful tool as techs love to teach.
Also, typically, the entire upper structure folds flat onto the walk belt for easy storage.
Here is a link to the Owners manuel. It will show you assembly, so you can simply work in reverse.
Looks like it may be easier to remove the feet once you have it folded.
ProForm 990 Cs Treadmill English Manual
Good Luck
Jan 13, 2014 | ProForm 990 CS Treadmill
Does Epic 425 MX parts can be removed? I cannot move the Treadmill in to my house due to too bulky for any door. Help!
Yes please see your instr. manual and follow the steps how to assembling and disassembling. if you do not have download for free
from www. fitness.manualsonline.com
God bless you
Nov 18, 2012 | Epic 425 Mx Treadmill EPTL88105 !
Moving nordic track 2750a pro too big to fit
Dear Sir:
You have the alternativa to fold the treadmills, and get help for another persons.
Please see the user manual from Life Fitness, and see the section how to fold the treadmill, and ready.
If you do not have the manual, go www.lifefitness.com see the customer service, go parts&manual, give you model and download for free. or to www. searsparts.com
sincerely. God bless you.
ernesto cuadra
managua, nicaragua
Feb 15, 2012 | Life Fitness 9700 Next Generation...
Want to disassemble proform xp 542 e
I will recomend Read your instructions or user manual, section unfold or assembly the treadmill.
If you do not have the owner or user manual, go to the web page. www.proform. com then customer service, and then parts & manual, give your model, serial number, and download free, and ready.
However you must take carefully and pacience with this. sincerely.
Nov 19, 2011 | Exercise & Fitness
Is there an online repair manual for the Golds Gym Advantage Treadmill? I'm trying to solve an incline problem. The incline does not go up when I push the incline button. I just get a series of beeps...
Your owners manual describes how to perform an incline calibration. Here are the instructions.
Start the machine running. Press and hold the incline up button. While the numbers are changing, remove the safety key. Reinstall the safety key. The treadmill should rise to maximum incline, then lower to minimum. After completing the cycle, the treadmill should function correctly.
If not, you may have a damaged wiring harness (caused during assembly) or a defective incline sensor.
If the sensor is defective, you will need to replace the incline motor.
Mar 01, 2011 | Exercise & Fitness
I have a used Weslo Cadense 927 treadmill. I need to adjust the the tread, it's rubbing the side.
When you purchased the treadmill it came with an allen wrench to assemble the machine. That is the adjustment tool.
Inspect the rear plastic cap (the adjustment bolts are there) make sure it is not damaged. If the plastic is broken, it will need to be replaced. This job is not easy. If it is not broken, adjust the belt as follows..
If the belt is already rubbing, locate the adjustment screw at the back of the treadmill on the side that is rubbing.Adjust that screw tuning it 1/2 turn clockwise. Move the belt manually 3 full rotations.. If it is still rubbing, turn another 1/4 turn. Again move the belt manually 3 rotations. Once the rubbing stops, run the machine slowly and watch the belt from the back of the machine..
Dec 16, 2010 | Cadence Weslo 927 Treadmill Walking Belt
Need to disassemble NordicTrack X7i trainer to move it. Don't have the manual
To get the manual go to iconservice.com and select the manuals link. You will be asked the model name or number. You can download a PDF file of the manual for free. Use the assembly instructions only backwards and you will be able to disassemble the machine.
Aug 10, 2010 | Nordic Track Nordictrack Apex 6500 Reflex...
Exercise & Fitness Logo
Top Reebok Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Howard
Howard
Are you a Reebok Exercise and Fitnes Expert? Answer questions, earn points and help others
