Question about Kenmore 46462 Front Load Washer
Non-stop draining at whatever cycle selection
My Kenmore HE2 is just 14 months old. It worked fine until yesterday. Now when it is started at whatever cycle selection, it just drains without stopping even though there is no water inside. The stage indication lights - Add garnment and Door locked are on but the drain light is off. Would anyone be kind enough to enlighten me as to how to fix it? Many Thanks
  • John Hoy May 20, 2007
    Thank jsrock516 for the response.
    Thinking that it was a control unit problem, I bought a new microcomputer but the new unit did not help!
    While perplexing, I then disconnected the harness from the water level pressure sensor. The machine stopped the draining action. It was a faulty pressure sensor with pin 21 came in contact with pin 24 when not pressurised. I took the sensor apart and adjusted the contacts.Now everything goes fine.
    I should have adhered to the instruction. Only replace the system unit as the last resort. It is an expensive lesson.
  • aj2311 Nov 13, 2007
    During the washing cycle the washer stopped with water still in the machine. All the lights were blinking on the cycle and the door would remain locked. When trying to start it again there was an agitating sound that did not seem to have the washer finish the load. Was finally able to get the door open and out came some water. Quickly shut the door. A power outage helped restart the machine. I then turned the washer to quick cycle, however the washer made the same agitating noise and did not work. We have had this washer almost two years.
  • 5,911 Answers
Is your drain pump constantly running? If it isn't, check the standpipe (drain pipe) and make sure you don't have your drain hose shoved down in the pipe too far or the top sealed off. The stand pipe needs an air gap to properly drain, or it can siphon water from the wash tub. Symptom: Washer continually tries to fill or slow fills, but water won't stay in wash tub. Double check your drain line to be sure. It could be a simple fix.
Posted on May 19, 2007
  • Jeff Rockwell
    Jeff Rockwell May 20, 2007
    Sorry I couldn't have helped you more, but I am glad you managed to get your washer working again. A good "lessons-learned" for myself. I don't think I've ever seen this problem before.
The mower is 3 months old worked fine untill yesterday
the problem is either u have trash in the bowl of the carb or the float in the carb is stuck. either way u need to have someone look at it.
Aug 12, 2009 | Mtd 22" Yard Machine Push Mower
Kenmore (sears) oasis washer stops with 36 minutes left
The timer is failed.
Replace it.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Kenmore Oasis HE 27082 Top Load Washer
WASHER DOES NOT START
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Washing machine suddenly stopped working during cycle
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
Jan 01, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
PDW7880G-No power to control panel. Just stopped at the end of drain cycle
Solution Found!!
Checked for power to dishwasher. According to the manual, shutting off the breaker for more that 30 seconds resets the dishwasher. It did!!! The dishwasher works fine now. THANKS!!!
Feb 19, 2008 | GE 24 in. Profile PDW7880G Built-in...
Kenmore Quiet Guard 2 keypad
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Apr 08, 2007 | Kenmore 17342 / 17349 Built-in Dishwasher
Kenmore 46462 Front Load Washer Logo
125 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
