Question about Toshiba TDP P5 Multimedia Projector
Toshiba TDP-P5 shuts down everytime I press "Power"
I have a Toshiba TDP-P5 and when I connect it to the power cable the light turns orange. However as soon as I press the Power button it the light turns green for a fraction of a second, I can hear the fan starting up and then it just shuts down.
  • m_koitsalu
    m_koitsalu Nov 02, 2012
    However do I leave it on standby for an hour and press "Power" it stars up fine and works for half an hour or soo.
  • 7 Answers
SOURCE: Toshiba TDP S8 projector shuts down suddenly
The reason why the projector is shutting off is so the lamp doesn't explode. It's more of a safety feature on the projector, you can reset the lamp and it might work for another 500hours. If the picture is still pretty bright I can get you the reset procedure, but be warn that when the lamp does eventually blow it could shatter the glass inside, so be careful, it shouldn't hurt the unit.
Posted on Apr 06, 2008
3bachelors
  • 52 Answers
SOURCE: Toshiba TDP-S8 Projector Inoperative
I have the same projector, and had the SAME problem.
After unplugging and taking on a trip it didn't work...it just lit up for 2 secs, and then shut off....
LEAVE it plugged in for as long as it takes for the light to stop blinking, and then it should start up on its own, or if you press the on/standby buton.
Be patient, hope this works for you too!
Posted on Sep 03, 2008
  • 3 Answers
SOURCE: No Power to My Toshiba TDP-S8
hi
Posted on Oct 26, 2008
Thank you very much for the precise answer!
Had the same fault but repaired mine.
As I only had a 1000u/16V at hand, I put it in instead the swollen 3300u/10V. It works as well.
BTW this cap was extremely hard to desolder, as its holes are very tight in the PCB.
some addition, how to take it apart: the only screw at the center of the bottom is obviously needs to be taken out, then only the plastic holds it in one piece. I used two credit cards (well, not credit cards, but magnetic hotel keys, but looks the same) to insert between the upper and lower chassis to separate them. The capacitor in question was on the bottom board, which has the power connector.
Posted on Jan 04, 2009
  • 22 Answers
SOURCE: Projector power problem
I HAVE THE EASY FIX!
I had this same problem & almost threw it away!
If you have had it unplugged for a while just plug it in & make sure the yellow power light is on, then leave it plugged in for about an hour or two. Do not try to turn on before at least an hour, then it can easily be turned on. Make sure you reset the lamp timer option. There & you thought it would be difficult & expensive!
Posted on Jan 09, 2009
Orange light blinking when turned on and doesn't project picture
First check your manual for trouble shooting the lights meaning. I think it is the bulb.
Jan 10, 2013 | Toshiba TDP T1 Multimedia Projector
How do you reset lamp hours on a Toshiba TDP-Tw420 projector?
1. Turn-off the projector by pressing the "ON/STANDBY" and unplug the power cord.
2. In the meantime, hold down buttons "ON/STANDBY", "MENU" and "INPUT and plug-in the power cord .
3. The lamp operation counter will automatically turn to zero.
4. Check if the lettering "0H" appears on the lamp operation counter in the status display.
Jul 31, 2011 | Toshiba TDP-TW420 DLP Projector
Toshiba TDP-P5, used unit. Startup image comes up ok. When PC is hooked up, the image does does not change from startup. Cables test okay on other projectors, the video port on the PC is working ok on with...
Try pushing the source/select button to make the projector look for a source. It is the button that looks like a bent arrow right in the middle of the 4 arrow buttons.
Jan 14, 2011 | Toshiba TDP P5 Multimedia Projector
Projector screen displaying "Searching" message. Does not recognize computer. Worked with one of your associates (Guru?) and we tried a number of solutions but none worked. She asked that I come back to...
If you are connecting to a laptop then you may need to hold the function button down and press F1, F2, F3 etc. there should be a sign with the latop on there and a sign with an external device (monitor,PROJECOR)
hope this information was useful to you.
Jan 21, 2010 | InFocus Office Equipment & Supplies
We have a Toshiba TPB P5 projector that displays all menus, and shows the computer display fine at first, but as soon as the video changes (new page, new window) the projector shuts off and goes to...
First check your video with ANOTHER external monitor. It may be the video output of the computer turns off (It often comes from a different driver than the main computer screen). This would then be a software problem...
Jan 09, 2010 | Toshiba TDP P5 Multimedia Projector
I have a toshiba TDP-S8 projector up until about a week ago it was fine but now when i try to turn it on either by remote or button on projector the yellow power light disappears then reappears about 5...
Check the color wheel if it is not turning when you hit the power button (light should flash) you have 1 or 2 loose caps on the bottom of the main board behind the audio input try to resolder them with low heat iron these are smt caps and very hard work on if you have not worked on this kind of job take it to a expert
good luck! ps make sure you glue them down
if you do get them to work to prevent a reocurance.
OR you have a power supply issue which
should be a swolen 3300 mf 10 volt cap
in the main power supply.
Aug 24, 2009 | Toshiba TDP-S8 Multimedia Projector
Toshiba Projector won't turn on!!!
I had the same. Try to press the "input" and "menue" buttons and plug in the power cable. No control light should be active after that. Press the "power" button and it should work.
Dec 19, 2008 | Toshiba TDP-S8 Multimedia Projector
Toshiba TDP-P5 projector
Possibky is overheating... I would put a fan on it and see if the time-to-fail changes,
Oct 03, 2007 | Toshiba TDP P5 Multimedia Projector
Toshiba TDP P5 Multimedia Projector Logo
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
