Question about Toshiba Computers & Internet
Wireless switch , key ?? how do i turn on - Toshiba Computers & Internet
  • Toshiba Master
  • 27,725 Answers
Power on the laptop computer and wait for the operating system to boot.
Right-click the wireless Internet icon in the lower right corner of the desktop.
This brings up a new pull-down menu.
Select "View Available Wireless Networks."
This brings up a selection of different possible Internet connections that are in range of the computer.
Select the wireless Internet connection you want to use.
If a password is required, you need to type it in now.
Wait for the laptop to connect to the Internet.
In a moment the computer is going to state it has successfully connected to the Internet.
click Start, Run type in cmd and click Ok to bring up a command prompt.
Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100.
Check your wireless connection properties under My Network Places.
Right click the wireless connection icon and choose properties.
From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked.
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
if still no joy
Let's first try to start the wireless service i.e. WLAN AutoConfig service manually.
To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok.
For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx
hope this helps
Posted on Oct 30, 2012
I dont know where the switch for wireless
Maybe you don't have your wireless turned on. Look onboth sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can togglethe wireless on or off. Normally you would Press and Hold the FN functionkey located at the lower left of the keyboard, then hit the correct F1 thru F12key that toggles the wireless. The correct F1 thru F12 key to hit willhave the wireless signal icon )))) on it. Or it might have the icon of a towerwith the wireless signal icon )))). Normally the screen will displayWireless On or Wireless Off when you toggle the wireless.
Jun 06, 2012 | Computers & Internet
Where is the wireless radio switch
Jun 05, 2012 | HP Computers & Internet
How can I switch my wireless LAN on?
Jun 05, 2012 | Sony Computers & Internet
Wireless capability won't turn on
Make sure you Press and Hold the FN function key then hit the F2 key.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
Some laptops might have a wireless button instead of a wireless switch located above the keyboard or on the front or sides.
Jun 02, 2012 | ASUS K40IN Notebook
HOW TO TURN ON HARDWARE RADIO SWITCH
Wireless Radio Switch??
Look for a button above the keyboard, it might be there or on the sides.
May 27, 2012 | ASUS U52F-BBL9 Laptop
Wireless capability Switch is off on dell vostro 1400.Is there another way to turn on switch.
There are three ways to toggle the wireless switch on/off, 1st, Fn + wireless button (F2 or F5), 2nd, the wireless switch on the side of the laptop, 3rd, it can be enabled or disabled under BIOS setup (Tap F2 when turned on the laptop).
Jun 30, 2011 | Computers & Internet
Wireless communication switch is disabled. I am not able turn on wireless communication switch. I was wondering if Toshiba a135-s4527 has a built wireless hardware????Vista SP2
When you say oyu cant turn on the wireless switch does that mean after flicking the switch usually located on the front or side of the laptop it sitll doesnt work. or have you tried holding the function key (fn) and hit the wireless symbol key on your keyboard it looks like the letter i with circles around itusually on the f8 key. by holding fn then f8 key it should turn it back on
May 07, 2011 | Toshiba Satellite A135-S4527 Notebook
I cant get any wireless signals because its says wireless capability is turned off it says to use the switch to turn it on but there is no switch. how do i turn it back on
Depending on your operating system, you can often just troubleshoot the problem and Windows will automatically turn your wireless adapter back on. If this doesn't work, it's likely that there's a physical switch on the laptop that needs to be in the "on" position otherwise it won't work. It may also be a function key combination. If this is the case, look for a little wireless symbol on your F1 through F12 buttons, then hit the function key "Fn" (usually right next to Ctrl) along with the appropriate wifi key and it should re-engage.
Mar 05, 2011 | Acer Aspire 4520-5582 Notebook
My dell xps m140 wireless switch, where is it located on the computer. I need to switch to wireless
Hi Devoo,
I got your issue , in your dell laptop to turn on the wireless switch in your keyboard press the Function key Fn+F2 simultaneously
(Fn key is in left side of ur space bar, near Alt key) automatically your wireless switch will be turned on and you will be able to go online wireless .
I am sure this will work.
Thanks & Regards,
Prema
Oct 06, 2010 | Computers & Internet
Wireless networking
the key combo is F2 + Fn key (the fn key is located on the bottom row all the to the left) a little blue light lights up that looks like this ((o)) that lets you know it's on. press the combo again to turn of wifi communications.
Nov 15, 2008 | Gateway 7330GZ Notebook
Computers & Internet Logo
18 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
