Question about Car Audio & Video
Fix bass on rca audio/vedio componet? - Car Audio & Video
    Master:
  • 444 Answers
Go ionto your menu.
Posted on Oct 30, 2012
What is SW 5.1 3000 ?
5.1 is surround sound 5 speakers and one BASS box front - rear center and bass.
Jan 14, 2015 | RCA Audio Players & Recorders
How do I set the equalizer to my own custom settings on my RCA RS2635?
Hello
Press "Preset EQ" on the main unit, or "EQ" on the remote control to toggle among FLAT,ROCK,POP,JAZZ, CLASS. The display show the selection briefly. Press "Bass Boost" to turn ON/OFF boosting the bass frequency. OK.
Dec 03, 2010 | RCA RS2635 CD Shelf System
I don't know how to hood up DVD player to T.V, Can you help Please?
On the back of the DVD player there are three outputs RCA jacks (yellow= Vedio) (white=Audio) (Red=Audio) It will say video out and Audio out.
On the back of the TV you will have the sane connectors on the back. Look for Video 1, there will be a yellow input and red and white audio inputs. and conect the outpit of the DVD player to the input of the TV, with RCA cables you can buy any where they sell TVs
Oct 16, 2010 | Audio Players & Recorders
Hook up
Hi:
This type of hook up is only for television viewing, to view the DVD you might consider purchasing some componet cables, they are color coded so hooking up is a snap, on the back of the DVD player you will see three RCA type connections Red/Green/Blue. componet cables are also these colors, connect one end of the cables to it coorsponding color on the back of your DVD and the other in the same color connectors labeled componet 1 input on the back of your television. You will also need a red and white RCA connector also for the audio as this is sound, a total of 5 connections will complete the hook up. Or you can go the simple route and use RCA type cables that come as yellow/red/white but for the best picture use componet cables this will allow you to watch your movies in HD.
Apr 27, 2010 | Sylvania Dual Deck DVD/VCR
Jiggling cable causes video and Audio to goes crazy
if you are a technician fine this are some procedures.
i if your A/V audio/ vedio from dvd are working than concentrate tuner and a RF amplifier stage,
ii if A/V not working than take your tv to a repair shop, cause it will involve, tuner, mixer, detecters, vedio and audio amps, take it to shop to save money-
Mar 27, 2009 | Televison & Video
T.V. went off during thunder strom- now nothing(no audio/vedio only clicking.
IN WICH STATE ARE YOU? IF YOU ARE IN MD-DC-VA WE CAN GO THERE AND TRY TO FIX IT
CAYPIANAN@YAHOO.COM
Oct 22, 2008 | RCA Scenium M50WH187 50" HDTV
I plugged int he rca's but he the lowest sounding bass possibe
kicker subs arnt ment to hit the lowest bass, unless you go spend a **** load of money, im talking 3000 wat amp, ant some 15' or bigger subs. the most commen kickers are 12' subs, so im asuming you have 12' subs, if not, this (said lightly) should work. try turning the bass boost screw on the amp to the middle of its turning range. this will offer the greatest balance between high and low bass. if you want more low bass, turn it past half. if you want more high bass, turn it down. i have mine set to mid range, but i also recently purchased 2 18' kickers. with every new set of subs, you should spend at least 15 min tuning the amp to get the best performance. every sub is different. hope this helps, good luck.
Jun 27, 2008 | Kicker KX800.2 Car Audio Amplifier
No audio with CD/DVD but works fine with aux and FM
Check the cable between the media centre and bass module for signs of damage (if its buried in the wall / under the floor and you can't check it, assume it could be damaged).
however, this sounds like a fault with the Digital Analogue Converter - this coverts the digital audio on a disc to analogue information the amplifer can use to produce sound. Contact your retailer for exchange / repair.....
Jan 12, 2008 | Bose 3·2·1 II System
Soung prob
Tune the gain on your amplifier powering the sub. Turn the Bass Gain on the amp all the way down and crank up your system to as loud as you can stand. Adjust the bass Gain until the Speaker begins to distort, then back off a little bit. This way you can crank it up and not get Bass Distortion early.
Nov 28, 2007 | Ultra Linear UL-1600M Car Audio Amplifier
Weird sound
get a portable player with a head phone jack get one of those cables with a headphone plug on one end and RCA's on the other plug the portable player into the amp and hit play. If you get Boom then the RCA grounds in your head unit are blown and only a repair shop can fix that. Also double check all grounds making sure they are solit with the proper gauge wire. Under the rear seat belt bolts is a prime connection point. Check with different RCA's
Jun 15, 2007 | Solid Audio F11D 1-Channel Amplifier Car...
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
