Question about KitchenAid Refrigerators
Where is the drain tube KTRF22MT
Water accumulating in bottom of refridgerator. Clogged drain tube?
fridgetech
  • 473 Answers
SOURCE: clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Posted on Oct 07, 2007
jgwhomeequip
  • 1902 Answers
SOURCE: Defrost Drain clogged
Take a spray bottle with VERY hot water and spray it down the drain line
Posted on Jun 02, 2009
Testimonial: "Good advice. Wife called repairman before I could apply. Repairman did same thing, but with pressureized."
jumptrout51
  • 3361 Answers
SOURCE: I have a GE TOP Freezer Model # TBX21JABLRBB
Turn off the fridge. Remove the rear freezer panel inside the freezer. Take a hair dryer and thaw the ice in the drain trough at the rear of the freezer. After it is clear, pour a 1/4 cup of bleach into the drain hole. Adjust the front leveling legs on the fridge to make the fridge tilt slightly to the rear.
Posted on Jul 06, 2009
  • 93 Answers
SOURCE: Water accumulates inside the refrigerator, Kenmore, Mod. 71194100
You get to it from the freezer. Remove the back wall in the freezer and you will see it there. Unclog it with some wire or check to see if it has ice over it.
Posted on Sep 14, 2009
  • 1891 Answers
SOURCE: Drain tube does not drain water from defrost
if drain tube s clean the water should go through it . try running a speed od cable through it . it must not be clear .. mm
Posted on Jul 01, 2010
Water pouring out of the bottom
Oh you don't want that.
Jun 18, 2017 | Refrigerators
Why is water leaking from inside?
If your refrigerator has automatic defrost, condensate drains to the bottom, then through a plastic or rubber tube into the evaporation pan underneath. Sometimes the tube becomes clogged, causing the condensate to accumulate in the bottom and leak out. The tube should be unclogged to restore normal drainage.
Sep 21, 2015 | Refrigerators
SBDE520T Side-by-side. Why does water accumulate on bottom?
The drain tube to the defrost water pan may have become clogged.
Aug 08, 2015 | Amana Refrigerators
Why do water accumulate at the bottom of my fridge under the vegetable tray?
If your refrigerator is frost-free, the water accumulates during the defrost cycle and should drain through a tube at the bottom into the evaporator pan underneath. The tube may be clogged or broken.
Dec 18, 2014 | Refrigerators
I have water accumulating at the bottom of refridgerator and i think my drain hole is clogged but i can't locate it. Can you help?
Hi and welcome to FixYa. I am Kelly
If the drain is clogged you must do a manual defrost by unplugging the unit, removing the freezer contents and directing an external fan into the freezer compartment for just over 2 hours. (It will make a water mess so be ready to tend to that mess!) The reason you have to do this is that there is ice in the drain and the only way to defrost the ice is to warm things up until the ice melts. The water that eventually accumulates where the ice in the drain funnel has formed does a good job of insulating the remaining ice in the funnel so it takes about 2 hours for everything to melt.
Once the ice has melted:
- Remove the rear fiberboard cover in the compressor area and locate the end of the drain tube for the compartment drain. Make sure the end of the drain is clear and that the the plastic drain pan is clean. (This can be quite unpleasant!) Clean it as necessary and make sure to remove all the muck from the drain pan / basin.
- Next us a vacuum on PRESSURE / Exhaust and direct air into the end of the drain tube. Have a 2nd person listen for air-flow in the freezer compartment passing through the drain tube to make sure it is clear. The pressure will float any debris UP out of the drain funnel and clear the drain in most cases so you do not have to take things apart to clear the drain.
- Once your sure the drain is clear re-load the freezer contents and return the unit to normal service. Just make sure to re-install the rear cover AFTER cleaning the condensoer coils and condenser fan area. (DO NOT use anything sharp on the condenser coils! You can puncture the coils and cause a coolant leak!)
This should stop your water leaking at the bottom of your refrigerator.
Should you not be able to clear the drain.... using the method above; I need the make and model number of your refrigerator so I can use parts diagrams to show you what to remove to gain access to the drain and clear the obstruction.
Thanks for choosing FixYa,
Kelly
Mar 24, 2011 | Refrigerators
I have ice accumulating at the bottom of my JennAir side by side refridgerator on the freeezer side. any idea why ?
First make sure the door is sealing properly.
If it is at the bootom of the freezer behind the backpanel is a drain hole this has become clogged. To unclog try some warm water and a piece of wire. Pour in about a cup of warm water to melt the ice then run a wire down the tube. This is where the water from the defrost cycle goes. There is a drain pan underneath to catch the water. for a diagram go to www.appliancehelponline.com and enter your model #.
Mar 23, 2010 | Jenn-Air JCD2389G Side by Side...
Leaking water in front left side
hi tom
yes the drain tube may be glogged and when the unit defrosts the water just flows to the bottom of the un it then eventally out, if you have a clogged drain, you will see water on a pretty reglar basis
8, 10, 12 hours
the drain pipe is behind the back wall on the freezer, if you take that off you will se an ice build up, remove that ice and clear the drain tube
you may need to pull out the machine and remove the tube from the back to ensure that it is entirley clear
Oct 20, 2009 | Refrigerators
Water pooling & freezing in the bottom of a kenmore model 795.75252400 freezer compartment
The problem is the water drain tube in the freezer is clogged. As the evaperator goes into deicing mode the water from the evaperator is not going down the drain tube. Instead it's over flowing those two air ducts to the refridgerator and causing your water problem. But it's not as simple as simply clearing the clogged drain tube. You need to install a heating element inside the drain tube to keep it from freezing during the deiceing process.
Sep 04, 2009 | Kenmore Refrigerators
Kenmore Refridgerator leaking water into refridgerator compartment from freezer compartment
You most likely have a clogged drain. When you freezers goes into defrost every 8 to 10 hours. The frost that is melted during the defrost drains from the freezer either down through the fridge or out the back and down. Either way it drains into a pan under the fridge. This tube is either clogged or the drain it's self inside the freezer is. Most of the time I find peas stopping the water from draining from the freezer. When the water can't drain it leaks through the bottom of the freezer into the fresh food section of the fridge. You will need to fix this because it will cause other problems. The water that cant drain from the freezer refreezes and will end up destroying the foam in the bottom of the freezer. Water will also leak onto the controls located in the part between the freezer and fresh food section ruining you controls.
Please rate this solution
Sep 01, 2009 | Kenmore Refrigerators
Refrigerators Logo
41 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
