Question about Mitsubishi Televison & Video
My convergence is gone haywire - Mitsubishi Televison & Video
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
What is the model number of the set so I can try to help you.
Posted on Oct 31, 2012
  • 1 more comment
  • david_kennar Oct 31, 2012
    sorry should have done that from the beginning. Its a Mitsubishi VS55601
  • SD Tech
    SD Tech Oct 31, 2012
    be careful its a 1997 model so very little data on it---I will research it later and get back to you---see if you can determine which convergence chips it uses---two with a number like stk-392-110 right on the front of them on a large metal heat sink, and a better idea of how convergence is off.
    no it's newer than that. It's probably 8-10 years old. I checked it last night in the advance convergence menu and you can align the middle of the screen. The edges are very distorted on the red, blue is OK
Is it a difficult to replace the convergence amplifier modules on a Mitsubishi VS 50609 TV?
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this link
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2013 | Mitsubishi VS-50609 50" Rear Projection...
Zenith R50W46
you have bad convergance ic that need to be replaced.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 18, 2007 | Zenith R50W46 50" Rear Projection...
Dashboard Electronic haywire on 2000 Buick LeSabre
The proper way to say it is Instrument Panel Electronics have gone haywire. This is not enough information for anyone to make a determination. What do you mean? It is all digital and blinks, scrolls from left to right in non-sensical jibberish, all 8's or what? You must give us something to go on.
Jan 05, 2012 | 2000 Buick LeSabre
2008 jeep patriot wiring has gone haywire. took
Open the power distribution center box near the battery and remove the asd relay that should shut it down. as for the problem itself, it could be a bad relay, a bad ignition switch or some odd ball thing that needs testing to find.
Mar 09, 2010 | 2008 Jeep Patriot
My electric system has gone haywire. The tach
SOME GAS CAPS CAN BE VERY HARD TO REMOVE , IF YOU TRY WITH A PAIR OF LONG PLIERS YOU SHOULD BE ABLE TO REMOVE. THE TACH PROBLEM SOUNDS LIKE THE SPEED SENSOR MAY BE BAD
Sep 28, 2009 | 2001 Oldsmobile Aurora
I have a panasonic pt-51hx42. I was just
your convergence power supply blew a fuse & probably one if not both of the STK ics. Normally when this happens the short takes out the low value resistors connected to the ics.
it is common practice in the shop to replace both STKs and resistors
Jun 09, 2009 | Panasonic PT-51HX42 51" Rear Projection...
From Pericos
you will need two convergence ICs they are both STK392-110 you will also need the JVC convergence resistor Kit #1 the parts are available at the following link and they provide free step by step instructions with pictures so you can do the repair yourself.
Heres the link.
http://servicemanuals.vstore.ca/
Aug 10, 2008 | JVC AV-65WP74 Rear Projection Television
My tv is going crazy...major convergence problem
the convergence ICs are bad. replacing the ICs usually fixes it - they cost about 15 bucks each.
Aug 21, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Televison & Video Logo
15 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
