Question about Logitech SPEAKER SYSTEM Z313 PC Multimedia Subwoofer Wired DVD Audio Headphone Stereo 25 Watt
Z313 no sound
Initial set up no sound
Phone plug on subwoofer plugs into phone jack on back of tower! Plug and jack are color coded green. If you plug into wrong jack you get no sound or intermittent sound. Also speaker cables have an on-off swith so make sure you are switched "on" or you will not get sound.
Posted on Mar 24, 2013
Wiring schematics for inside Z313?
Model Number: 184TBDR7324
Cat Number: Z313
Marathon Electric
Support
support
Sep 17, 2017 | Dryers
Schematic for logitech z313
I couldn't find a schematic but...
The red and black wires go to the subwoofer.
The white and black wires are main level inputs that go to the toroid.
The blue, green and black wires are the output from the rectifier.
Tthe green is your negative rail while the black is 0v and the blue is positive
Sep 05, 2016 | Logitech Audio Players & Recorders
Logitech Z313 Sound System Failure
On the basis of your description, you can conclude that your Logitech speaker system has failed.
Mar 18, 2014 | Sun -115H Computer Speakers
How do i hook up logitech speakers #z313 to my desktop i need a diagram
Phone jack on woofer goes into computer tower (should be color coded green) and power cable on woofer plugs into 120VAC. Speaker phone jack plugs into back of woofer. The speaker cable has an on-off switch and volume control as well as a phone jack for your headset.
Nov 14, 2012 | Logitech SPEAKER SYSTEM Z313 PC Multimedia...
How can I change tone setting
You could try volume control > advance > Tone Controls. This will only work if you have decent sound card. Grey-ed out with lower end hardware. The other option is to use a media player with an EQ. Like VLC or Winamp.
Aug 27, 2012 | Logitech Z313
Z313 one speaker stopped working
try swapping the speakers around if the problem still persists either the speaker is faulty or
the speakers plug/outlet is usually at the back of the computer you will have to open up the
computer to check the lead attached to the rear of the input plug make sure the connection is good
or you might have to clean the dust from your computer dust causes static which causes your computer to overheat and all sorts of problems
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your SOUND CARD dust causes static to build up in a computer causing it to overheat any many other problems:
hope this helps you
Oct 04, 2011 | Logitech Z313
I am having trouble with the speakers making any sound when I hook the speakers into the Rear Panel (RL RR) of my computer but the speakers work if I use them in the headphone jack. The subwoofer works...
The main reason why the rear speakers are not working because the sound you are playing are not surround sound or a not a stereo sound and check the setting of your speaker. There is an output sound in your speaker but to low because of the set up of your speakers. Try to set it in Hall, Church, or any set up you will notice that there is difference with there volume in every set up.
Jul 26, 2011 | Logitech Z313
We are hooking the speakers up to a new computer and we don't have the software
Threre is no software for these speakers. This is the installation guide:
http://www.logitech.com/repository/1411/pdf/27251.1.0.pdf
Make sure you have the proper sound device activated and volume turned up. If after speaker set up, you have no sound, get into your "device manager" and click on the box next to"sound, video and game controllers"(on right) and, righy click on each device that shows in the list. You should see "disable". If you see "enable" click on that and exit. You should have a speaker icon in your taskbar, lower right of screen. Right click on that and then on "open sound mixer" and, adjust your volume.
Jun 14, 2011 | Logitech Z313
Connected up z313 speakers. have motherboard HD sound installed with my windows 7. no sound coming from sub or speakers. can plug head phones into the z313 controller and listen to music. plz help
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
Jan 31, 2011 | Logitech Z313
Logitech Z313 how to install it in your computer
plug these speakers
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or
audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 11, 2010 | Logitech Z313
Logitech SPEAKER SYSTEM Z313 PC Multimedia Subwoofer Wired DVD Audio Headphone Stereo 25 Watt Logo
124 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
Jerry Umali
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
