Question about Radio Communications
Autotuner problem with Kenwood TS=450SAT
When using the built in autotuner on my Kenwood ts-450SAT when I push the tuner button it clicks in for a fraction of a second and shows a perfect match on the SWR meter. I can then change the frequency and bypass the autotuner and when I transmit the swr still shows a perfect match. I know the antenna is not resonant at that frequency but the SWR meter still shows a perfect match ratio 1 to 1. The autotuner does not roam around at all on any frequency but just gives a quick click and shows a perfect match everytime. Can anyone tell me what is wrong here and how to fix it? Thanks for any advice on this.
73,
Gale WB9RWW
email wb9rww@wmconnect.com
  • wb9rww Jan 07, 2009
    Don't you read the solutions? I sent it myself in answer to your email recommending that I pay for a solution. Just forget the whole thing!!!
Sorry, I did not realize that this was a fix-it-for-hire place. I thought it was a place for free advice
I will take my problem elsewhere.
73'
WB9RWW
Posted on Jan 04, 2009
Kenwood TS-2000 Power up fails
You will likely have to do a reset on the radio. The method to do this is hard to find in the manual. I have inserted it below. It usually works for me. Doing a full reset will reset EVERYTHING. It is essentially a last ditch attempt to get the radio going again. I hope this helps
PARTIAL RESET
Perform a Partial Reset if a key or control does not
function according to the instructions in this manual.
The following data is NOT erased by performing a
Partial Reset.
• Memory channel data
• Menu settings
• Antenna tuner preset data
• ANT 1/ANT 2 data.
Reset the transceiver by pressing [A/B]+ POWER
ON.
• "HELLO" appears on the display.
FULL RESET
Perform a Full Reset if you want to erase all the data
in all the memory channels. In addition, this function
resets all the settings that you customized, to the
factory defaults (i.e.- menu settings, antenna tuner
preset data, etc.).
Reset the transceiver by pressing [A=B]+ POWER
ON.
A confirmation message appears when performing
the Full Reset. Press the [A=B] key to proceed.
Otherwise, press any other key to cancel the Full
Reset and return to normal operation.
When you perform the full reset:
• All frequencies, modes, memory data and AT
preset data are set to the factory default values
(refer to "INITIAL SETTINGS", above).
Nov 24, 2016 | Kenwood TS-2000
Tip
How to Play TS Video Files on Computer? There are many worldwide TV channels...
There are many worldwide TV channels like ABC, NBC, CBS, TNT, ESPN so that we can enjoy movies as we like. Is it possible to record TV shows? Of course, yes. You may find DVRs, TiVo Premiere to record your favorite TV series. You can also use TV tuner to record videos. PCTV nanoStick is one of the USB DVB-T TV tuners, which you may use to record ABC/TNT/ESPN videos.
If you record TNT video files on PC with PCTV nanoStick, you may find the output videos in .ts format. The TiVo Premiere can also produce .ts videos. To play the recorded videos on computer via home network, you may find the .ts file format is not a good choice. The general However, you can convert .ts to .mp4 for easy playback on computer players like Windows Media Player, VLC media player, QuickTime Player.
Here are the simple steps to convert recorded TV shows to computer for easy playback.
Step 1. Load recorded ABC/TNT/ESPN videos to Aunsoft Video Converter.
Run Aunsoft Video Converter as the TS Video Converter on your PC, and click the "Add" button to load the recorded videos for conversion.
Step 2. Choose H.264 MP4 output.
Click the "Format" option and choose Common Video > H.264 Video(*.mp4) to convert recorded videos from .ts to .mp4 for playing on any computer. The file format .mp4 is compatible to almost all computers, and the video compression with H.264 will keep video in high quality with small file size.
Step 3. Convert TS videos to MP4 for PC playback.
Click the convert button under the preview window and the TS video converter starts converting recorded ABC/TNT/ESPN videos to MP4.
After the videos are transcoded to MP4, you can put the videos to NAS to archive the videos, and watch the videos on computer via home network. No matter your videos are from TiVo Premiere, PCTV nanoStick or DVR for TNT videos, ABC videos, you can then freely enjoy movies at home. Aunsoft Video Converter is the partner for your recorded videos for playing .ts files on computer. If you are using iMac/MacBook Pro, you can use the Mac TS video converter to facilitate HD video playback.
on Jul 15, 2010 | Cell Phones
I have a KENWOOD TS-940SAT HF Transceiver that powers up with the TX indicator on, no power output and no receive.
Very little information about the situation of the transceiver is provided, it might be a complex one. The Kenwood TS-940SAT features a built-in automatic antenna tuner covers the amateur bands 160 through 10 meters. It is advisable for you to reinstall the transceiver and follow the right set up step to see if it works out eventually.
Apr 18, 2016 | Computers & Internet
How to install a voice synthesizer into a Kenwood ts 570
This should be of some help to you...
http://www.manualslib.com/manual/86121/Kenwood-Ts-570d-Ts-570s.html?page=64
Mar 02, 2015 | Kenwood Radio Communications
Why does my Kenwood TS 790 E when pressing call button causes C2 fault on display?
http://www.iw2nmx.it/Kenwood%20-%20Trio/TS-790%20Instruction%20and%20Service%20Manuals%20plus%20mods/TS-790%20Instruction%20Manual.pdf
Jul 14, 2014 | Kenwood Radio Communications
Kenwood ts-2000 internal antenna tuner fail to tune
it's not failing to tune, it shutting off as tuned. 1.25:1 is below it's threshold to tune
Feb 05, 2014 | Kenwood TS-2000
Kenwood TS-450S won't load on new 20M dipole.
Surely you've checked connections, etc.----could balun have gone bad? Also are you using an external tuner? Lots of MFJ tuners will "screw up" once in a while. Open it up and inspect it
Dec 31, 2008 | Radio Communications
TS 2000 KENWOOD TRANCEIVER
I have the same problem with my TS2000 , in VHF I can heard small signals only if I turn on the PRE Amplifier ...
It start just few hours of use .
Jul 31, 2008 | Computers & Internet
Radio Communications Logo
437 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
