Question about Panasonic KX-FL541 Plain Paper Laser Fax
Black marks on incoming fax documents and anything that is copied.
When I receive a fax or copy a document I get black marks the length of the paper. They look like skid marks. I followed the directions in the manual to clean the rollers, but that did not solve the problem.
  • 167 Answers
SOURCE: Can't Copy, Receivers of Fax get Full Black Blank Page
REPLACE CIS SCANNING UNIT HAPPY FAXING OMNIPRESENT
Posted on Sep 23, 2007
  • 106 Answers
SOURCE: Machine does not take "grab the document"
probaly you not remove all the paper check again
Posted on Feb 05, 2008
  • 31 Answers
SOURCE: receive a black copy
try this for uf490 and 4100
press function 7 monitor monitor monitor monitor *
you will enter service mode
press arrow down then locate for DIAGNOSTIC
PRESS START
press arrow down then locate for ADJUST SHADING
PREPARE A CLEAN SHEET OF PAPER AND PLACE IT TO WHERE YOU ARE PLACING THE DOCUMENTS BEING FAX
THE PRESS START
AFTER THE UNIT SCANS CLEAN BOND PAPER, PRESS STOP STOP STOP
THEN TEST COPY.
CALL US AT 3633636 FOR more assistance
Pantronics International Corporation
51-53 Gen Rosendo Simon st. Caloocan City Manila
Posted on Mar 11, 2008
leroyal
  • 2120 Answers
SOURCE: failed paper pick up
Yes, dump it.
Posted on Sep 20, 2008
ic0729
  • 212 Answers
SOURCE: rollers will not grab the paper through to fax or copy
You need to go and order the bottle called "roller rejuvination solution) from the website fixyourownprinter.com.
Cost under $20.00 and all you need to do is dab a qtip some of the solution and spread the solution from the qtip onto all the roller pin paper pickups.
Wait 10 minutes for it to dry and then test the fax again. It will now pick up single sheets afterwards.
Posted on Mar 19, 2010
Hp officejet 6500 instructions for receiving a fax? Thanks
You can receive faxes automatically or manually. If you turn off the Auto Answer option, you must receive faxes manually. If you turn on the Auto Answer option (the default setting), the device automatically answers incoming calls and receives faxes after the number of rings that are specified by the Rings to Answer setting. (The default Rings to Answer setting is five rings.)
If you receive a legal-size fax and the device is not currently set to use legal-size paper, the device reduces the fax so that it fits on the paper that is loaded. If you have disabled the Automatic Reduction feature, the device prints the fax on two pages.
NOTE: If you are copying a document when a fax arrives, the fax is stored in the
device memory until the copying finishes. This can reduce the number of fax pages stored in memory.
This section contains the following topics:
• Receive a fax manually
• Set up backup fax reception
• Reprint received faxes from memory
• Poll to receive a fax
• Forward faxes to another number
• Set the paper size for received faxes
• Set automatic reduction for incoming faxes
• Block junk fax numbers
• Receive faxes to your computer (Fax to PC and Fax to Mac)
When you are on the phone, the person you are speaking with can send you a fax while you are still connected. This is referred to as manual faxing. Use the instructions in this section to receive a manual fax.
NOTE: You can pick up the handset to talk or listen for fax tones.
You can receive faxes manually from a phone that is:
• Directly connected to the device (on the 2-EXT port)
• On the same phone line, but not directly connected to the device
NOTE: The automatic document feeder must be empty to receive a fax. If there are documents in the ADF, then the device will not be able to receive incoming faxes.
To receive a fax manually
1. Make sure the device is turned on and you have paper loaded in the input tray.
2. Remove any originals from the document feeder tray.
are documents in the document feeder, then receiving the fax will be
unsuccessful.
3. Do one of the following to answer a fax manually:
• Set the Rings to Answer setting to a high number to allow you to answer the
incoming call before the device answers.
• Turn off the Auto Answer setting so that the device does not automatically
answer incoming calls.
4. If you are currently on the phone with the sender, instruct the sender to press Start on their fax machine.
5. When you hear fax tones from a sending fax machine, do the following:
a. Press START FAX Black or START FAX Color on the device control panel.
b. When prompted, select Fax Receive.
NOTE: Depending on your country/region, the device might receive the fax
automatically when you hear fax tones from the sending fax machine.
6. After the device begins to receive the fax, you can hang up the phone or remain on the line. The phone line is silent during fax transmission.
Jan 30, 2011 | HP 1250 Plain Paper Thermal Inkjet Fax
Brother Intellifax. When I make copies and send faxes there is a 2 inch black line on the side of the paper, but not when i receive faxes. Do I need a new drum? They run approximately 189.00 so any help...
It is NOT the drum. It is your document scanner. 2 inches wide is big so most likely it is not the typical scrap of paper or whiteout that gets stuck to the scanner glass. Lift up the ops panel where the documents are fed in to be copied. Look for a strip of glass that runs from one side to the other. Make sure there is nothing on the glass. At 2 inched wide it is more likely that you have some of the LED's that light up going bad. Under the glass is a row of LED's that light up to scan the document. If a block of these are not lighting up then this then causes the black band to show up. If this is the case then you will need to have the scanner repaired or buy a new machine which might be cheaper. No question tho, it is in the scanner as this is the only area that will cause clean incoming faxes but bad copies and outgoing faxes.
Good Luck and Thank You for using Fixya.
Sep 22, 2010 | Brother IntelliFAX 4100 Laser Fax
Black stripe running down left side of paper when
Open the top of the fax where your documents go in. There will be a thin **** of glass where the document is read. On the end that reads "dirty" is a smudge or some white-out that needs to be cleaned. You may have to clean it with some cloth wrapped on a flat tool. Do not scrap or scratch anything, just clean enough to get the dirt off. Then make a test copy.
Apr 29, 2010 | Brother IntelliFAX 1270E Plain Paper Fax
Wide black line down page
open the document lid. Check to see if there is white-out on the glass platen where the document rides across the scanner. Some units require the white roll to be taken off.
sometimes a black mark on this platen can leave black streaks on copies made on this machine, and even when they send to others.
Try to clean the platen glass.
Oct 15, 2009 | Samsung SF-340 Plain Paper Inkjet Fax
I have a black streak all on one side when i copy ?
If it is just when you copy and not when you print then it is a cleaning issue. Toner cartridge would cause the line to appear on copies, printouts and faxes. There is a piece of glass inside the auto document feeder that is probably dirty. Open up the document feeder as if you were clearing an original document jam. Look for a piece of glass inside the ADF, it will run the length of the document feeder. There is probably some dirt or another popular problem is white out. Clean off the glass with glass cleaner or alcohol and it should fix the problem.
Oct 04, 2009 | Brother IntelliFAX 4100 Laser Fax
Sent documents are received black
I bet if you make a copy for yourself, the same thing is true.
The scanner bulb (or led array) is dead - meaning there is no light coming on when you scan your originals to send a fax or copy. You would normally be able to see the light(s) light up, if you peek under the auto sheet feeder as your originals are scanning, if not, then it is dead.
Jul 16, 2009 | Sharp UX 340LM Plain Paper Thermal...
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Cannot sent fax because document too long
If you can copy the document, then you can send it BUT the receiving fax will probably have restricted length fax pages to prevent jammed documents at the sending end causing the receiver to use all the paper. If you have access to a service manual you can restrict the length of faxes sent and received on your machine. But it may be the receiver with the restriction.
Jul 01, 2009 | Canon FAX-L900 Plain Paper Laser
BLACK LINE 1" THICK ON FAX COPY BEING SENT OUT
I bet your incoming pages are clean right? The Laser is not used for outgoing faxes.
Lift up your document feeder and clean the scanner glass that the documents are scanned across
Feb 24, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Panasonic KX-FL541 Plain Paper Laser Fax Logo
35 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
