Question about Canon MV300 Camcorder
Canon mv300i Hi, My canon MV300i is coming up with the message to Eject tape after I load a tape. The tape is then stuck in the mechanism. Pleae Help!!
  • Korvar
    Korvar Nov 26, 2007
    My Canon MV300 tells me to eject the tape, but when I try to do that, the motors whir but the tape doesn't come out. So now my tape is stuck, and I can't use the camera, not even as a webcam connected to a PC.
  • Anonymous Sep 12, 2008
    The tape won't eject even though it tells me to, It slightly moves the tape, then stops
  • 128 Answers
SOURCE: Playback & Ejection Problem
Hi, You usually get an EJECT TAPE when the camcorder has found an internal problem and either the videocassette or the camera itself has developed a problem. In you case, it looks like you tape has a problem. Daniel
Posted on Feb 16, 2006
SOURCE: Tape won't come out!
I had the exact same problem, and just by dumb luck, I managed to get the tape compartment to pop open after trying hundreds of things. Maybe this will work for you too...who knows??? What I did was to first remove the battery and AC power to "reset" the camera (I guess). I then put the battery back in place and WHILE HOLDING THE CAMERA IN THE UPRIGHT (AS IF USING THE CAMERA FOR VIDEO) POSITION, I pushed the "Open/Eject" latch. VIOLA!!! Like I said, it may be dumb luck, but I haven't had the problem again. It may be that gravity helped to take the stress off the ejecting mechanism...dunno???? BTW, when I was having the problem, the mechanism would "click" 3 or 4 times while trying to move the tape out. Good luck!!! I hope this helps someone!
Posted on Aug 16, 2006
SOURCE: Message reads eject. won't eject
My camera did the exact same thing. I called Canon tech support and they advised to unplug power cord, remove large main battery, and remove smallbackup battery. The small back up battery is under a small door under the main backup battery. With everything disconnected, turn camera to "camera" and then to "vcr" and then to off. Wait a few seconds. Put everything back together and try to eject again. The tech said that resets all the mechanical parts. However, it did not work for me. They now want me to send it to them for a paid repair. I have done some research on the internet and this is a VERY commom problem and it usually costs about $150 to correct via Cannon. Many times the problem occurs again. I am very very frustrated. I pulled my camera out last night to get it ready as my wife is 9months into her pregnancy. Now, I have to send my camera away for 5-9 days. Really really upset.
Posted on May 29, 2007
SOURCE: Canon MV800i tape would not eject.
Put pedalfoot in camera, shake vigorously.
Posted on May 13, 2008
SOURCE: Eject tape message
We get the eject message and then it will not eject tape.  Any suggestions
Posted on May 29, 2008
Hi, I have a JVC HR-J658 VCR that doesn't eject tapes.
You mean a tape is stuck inside? Disconnect power and open up the cover. If the tape is stuck around the posts, free it and by manually turning the loading motor you can slowly get the mechanism to eject the tape.
Nov 05, 2013 | JVC HR-670 VHS VCR
Tape an catridge stuck
Unfortunately, the best chance you got of getting the tape out is to open up the video to release the tape.
Feb 08, 2008 | Aiwa HV-MX1 VHS VCR
I got an LG VCR GC980NW (MG 64) VHS VCR. I've wrongly pressed both the eject and play forward button at the same time. After that, the VCR shows both the 'EJECT' message and 'No Tape' signal, and then...
It is possible that the mechanism is out of mode as the front cassette loading mechanism and the tape forward loading mechanism have gone out of sync. Now it is important that the MODE of the system control is in the correct parking.
Hence I feel that the VCR must be opened and the mechanism reset-ted. Make sure that the tape loading has come back to the correct parking and also the cassette loading has returned, other wise remove the mechanism and reset.
Apr 05, 2011 | LG MG64 VHS VCR
Canon ZR85 Tapes will not go in, it will eject the tape. Why?
Sounds as if your camera has a mechanical problem with the tape loading mechanism. It is possible that it just needs a clean/lube, but otherwise it will need to be repaired or replaced.
Nov 30, 2010 | Canon ZR85 Mini DV Digital Camcorder
My canon MV300i has been running very well and it has been my trusted portable camera with some stunning images. However, just today, I slotted my tape onto the cassette case but upon closing the door it...
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively and the tape removed without damage. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Oct 03, 2010 | Canon MV300 Camcorder
I can't eject cassette from my Canon MV800i
The mechanical of the tape loading path is misaligned, Contact any expert for mechanical adjustment of the tape loading path, No worries it will work fine again, and this would not be expensive.
Thanks for using fixya.
Jun 16, 2009 | Canon MV800i Mini DV Digital Camcorder
Canon mv300i
I have glued a small plastic square over the "switch" on the cassette that presses down more on the sensor in the camera so it can sense that on the cassette and it should clear the tape cassette. Better still have a camera tech adjust the sensor in the camera. Good luck
Aug 25, 2008 | Sharp Viewcam VL-AH151U Camcorder
C:32:11 message flashes, cassette eject won't work, camera doesn't work
Just had this problem myself... called Sony. Here is what I did to fix this:
1. Turn off power
2. Open the LCD Display
3. Press "Reset" with paperclip/pen
4. Unplug ANY wires connected to the camcorder
5. Eject battery
6. Plug in DC charger
7. Power on
8. Attempt to eject tape
9. At this point, the metal tape holder comes out but refuses to open... slightly "close" the portion of the camcorder that has the button to eject the tape, and then open it fully again (you'll hear a click, this signals the device that the 'hatch' is open and to eject).
10. The metal door *should* pop out and allow you to withdraw the tape.
I've tried 4 different cassettes and about 2 seconds after hitting play, I get the error every time... my solution: Not going to try to play my tapes on the camcorder anymore... will find another player to play Hi8 MP cassettes. Unknown if able to record to tape as of yet.
Nov 24, 2007 | Sony Handycam DCR-TRV240 Digital Camcorder
Cannon ZR 60 camcoder Cassette copartment does not open
Loading unit problem is a common mechanical problem in camcorders. To remedy the problem, trained tech need to disassemble the mechanical system around the loading and replace few broken gears (plastics) and adjust it. Repair cost may run close to half of the new camcorder. If you really got to repair this camera for some sentimental reason or for special needs otherwise better to invest the repair charge into a new camcorder.
Mar 15, 2007 | Canon ZR60 Mini DV Digital Camcorder
Canon MV300 Camcorder Logo
321 people viewed this question
Top Canon Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
