Question about Kenmore 24032\24036 Top Load Washer
I am trying to replace a clutch assembly
How do you remove the clutch assembly from the gearbox
  • 198 Answers
Agitator needs to be disconnected, then tilt machine back disconnect pump and move out of the way. take 3 bolts holding the gearcase out an remove gearcase. Motor does not need to be removed unless you are going to replace the coupler. At the top of the gearcase there are 2 clips that need to be removed and wala, the clutch is easily taken off. reverse procedure, and reinstall gearcase. Be sure to rotate the brake and push up into the bell housing. if the brake comes down at all the gearcase won't reset into place. Good luck. There are detailed pics of this operation on the samurai appliance guru web site.
Posted on Jan 05, 2009
How to install rear oilseal crankshaft of 4hf1
Hi Herman, Remove the gearbox, the clutch assembly and the adapter plate. Remove the oil seal housing, push out old seal, replace with new replacement and reassemble in reverse order. Regards John
Dec 08, 2013 | Cars & Trucks
Transmission slipping
This normally means your clutch is worn down and needs replacement. Much less likely is that the clutch pedal travel needs adjustment.
Replacement of the clutch requires removal of the gearbox and is much easier with a shop hoist. I'd recommend replacing the pressure plate assembly as well.
Jul 31, 2012 | 2003 Toyota Corolla
Need to open gearbox
Hi, you need to put a large screwdriver into the front port, then undo the clutch dog
Jul 17, 2012 | Kenwood Food Mixers
Remove gearbox from engine bay
remove the whole lot its easier in the long run
Feb 10, 2012 | Cars & Trucks
PrEngine is running, gearbox linkage can be seen moving looking down from engine - when driver puts lever into gear, gearbox not engaging - with or without clutch applied. Possible areas which could...
Unfortunately the problem will need investigating. There must be a problem with the flywheel / clutch assembly or the gearbox itself. The fact that you can move the gear linkage indicates that there is no drive in the gearbox ( ie not turning). The only items that effect this are the clutch / flywheel assembly or the primary shaft in the gearbox.
The gearbox will have to be removed and the above checked.
Sep 08, 2011 | 2001 Volkswagen Golf
Where is the clutch located on a mazda rx7 1986? i need too change the clutch since the clutch went out?
The clutch assembly is located inside the 'bell-housing' which is the flared forward section of the gearbox. Hence, the tailshaft and gearbox need be removed to inspect clutch condition.
Oct 31, 2010 | 1986 Mazda RX-7
How i repair the clutch
By replacing used clutch pieces with new pieces after removing gearbox & clutch assembly.
Mar 17, 2010 | 2001 Volkswagen Beetle
What is the easiest way to change my shifter shaft on a 1999 yz 125... i put that my bike was a 2003 because they didnt have the option of a 1999...
Remove gearlever,drain gearbox oil,drain coolant,remove powervalve actuator cover,place small allen key in slot provided & remove bolt on actuator,remove radiator to waterpump hoses,remove clutch cover,slide shaft out from left to right,(If clutch hub is in the way remove clutch assembly),fit new shaft ,reassemble,replace gearbox oil & coolant & bobs ya uncle.
Nov 16, 2009 | 2003 Yamaha YZ 125
2001 hyundai clutch is slipping- how do you get it to stop? Is there an adjustment- something that needs to be cleaned or replaced? The pedal is fine- everything seems to be moving/adjusted ok there- the...
If your clutch is slipping the clutch plate is worn out and will have to be changed. This involves engine and gearbox has to be taken out - then the gearbox has to be sperated from the engine to remove the clutch assembly and replace the clutch plate with a new one.
There is no adjustment on this clutch as it is hydraulic and therefore is self adjusting.
Hope this helps. Please remember to rate my answer. Thanks.
Jul 17, 2009 | 2001 Hyundai Tiburon
Kenmore 24032\24036 Top Load Washer Logo
87 people viewed this question
Sal De
 Brian Main
Brian Main
