Question about Philips GoGear SA3245/37 Digital Media Player
I transfered too much music, filled the memory, cannot delete
I have the 4GB sa32xx it was working fine, Itransfered moe music as it was downloading, it says memory full, cnnect to pc an delete some songs. I tried this but it will not stop attempting to download the songs, will not go to menu I connect to pc, it says not connected. I took it to Best Buys, geed squad, he worke on it for 30 min. could not do anything with it.
  • 4 Answers
Take a pin, hold down reset button, after about 30secs of holding it, try to power it on, if ur lucky nuthing is gone, if ur unlucky, it will be back to factory setting, with 0 downloaded files
Posted on Jan 04, 2009
I bought a 4 gb PNY flash drive and i used it to transfer music from one computer to another. after dragging the music to my itunes i deleted all the files on the flash drive. i went back to transfer more...
Plug in the drive -go to my computer and find it right click and go properties - look for folder options -choose show hidden folders -- you will probably find a folder called( trash) delete it and you should get your space back
Apr 13, 2011 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Music in music library shows corrupted cannot delete
Connect ur phone to ur PC in Data transfer mode.
Make sure u can view hidden files in ur pc.
Open E:\private\
where E: is ur memory card drive name
Delete all the files in "private" folder.(u can copy and save all the files before deleting incase anything goes
Disconnect ur phone and restart it.
Open music library it will refresh itself automatically.
Mines working fine now....
Nov 18, 2009 | Nokia 5800 XpressMusic Smartphone
KS360 LG cant download music
go on to file and you can move them to external memory then they should play
Jul 25, 2009 | LG KU990 Viewty
I use a Philips Sa32XX 4Gb version go gear . memory full and ...
I just managed to get this problem worked out, added a bunch of music then it would just freeze up while it said "Updating." I finally got Windows to recognize it by plugging it in while starting up the computer (dumb luck), just plug it in right after the first Windows screen shows up. Not sure why it worked, but it worked twice for me. Once I got Windows to recognize it I could finally go in and delete a couple things to make space for all the system files the thing needs to run. At that point the Philips device manager also recognized it, and let me repair it (at this point it will tell you to unplug it, then hold down the back button, plug it in, and don't let go of the back button until it tells you to). Might also try the hold down the back button and plug it in trick first to see what it does, it might just work that way too. At any rate, make sure there is some free space on it before you unplug it and try to use it, otherwise I imagine it will mess up again. Also, to note, mine said the firmware upgrade failed, but everything works fine. It took quite a while for it to update after I unplugged it, but I guess that is normal. Best of all, I didn't lose the rest of the stuff I had on there!
Jun 02, 2009 | Philips GoGear SA3245/37 Digital Media...
AUDIO FILES
your car stereo apparently only recognizes mp3
your ripped cds are probably in a different format such as wma (windoes media audio).
when ripping a cd choose mp3 as the encoder instead.
it should work
about changing order:
the order is alphabetical, you can change the order if you change the name. adding numbers in the beggining of all filenames should do it
Jan 01, 2009 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
MP4 digital player
yes it's better you reformat that so it will be clean and then reinstall again;
hope this may help;
Regards,
VOTIT
Aug 01, 2008 | Electronics - Others
Problem with saving in the memory card
try to download FEXPLORER. this software is very friendly to user. Many function can be made with FEXPLORER others cant. on fexplorer it has a inbox that you can see and move or copy it and transfer through your memory card. At the same time FEXPLORER indicates the memory size of each drives like your phone memory and your memory card. By the way paste the music files from your inbox to the music folder of your memory card. i hope that helps! pm me if you need assistance about that
Charcois
Jul 22, 2008 | Nokia N70 Cellular Phone
Sansa e260
The e260 works with microSD cards. Your 4GB card is actually a microSDHC card and won't work in the Sansa.
With a microSD card, simply put music tracks into a folder called "MUSIC". When the card is installed, the Sansa will see the additional tracks.
Jul 14, 2008 | SanDisk Sansa e260 MP3 Player
Downloaded music from my computer, all plays fine from memory card and phone memory, but unable to access music player. displays updating then switches phone off, and phone switches back on...
transferred all my files onto my computer, then proceeded to format the memory card whilst in the phone. transferred all the files back onto the memory card and bingo the music player works fine. Strange that the memory card was from my samsung e900 and worked fine.
Apr 27, 2008 | Samsung Cell Phones
Memory full.
the phone memory must be free... so transfer all your datas from phone memory to memory card...........
keep some 20 mb free phone memory and then try..
it will surely transfer
Feb 17, 2008 | Sony Ericsson Walkman® W880i Cellular...
Philips GoGear SA3245/37  Digital Media Player Logo
142 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
