Question about HP Office Equipment & Supplies
Scanner has red lines
When I scan any document or picture its covered in red lines
    Scholar:
    New Friend:
  • 43 Answers
Clean the flat bed of the printer with a lint free cloth
Posted on Nov 09, 2013
2 Suggested Answers
checkitright
  • 1362 Answers
SOURCE: Brother MFC 8440 Scanner has a line
Whoaaaaaaaaaaa!!!!!!!!!!!!!!!!!!!!!!!!!! No need to da all that. Lift up the Doc feeder and look at the SMALL strip of glass, you will see a dot or something on it, clean w/alcohol. Voila taken care of. the dot ( pen mark, white out, etc...) makes a line because the document is Moving and that dot now looks like a line to the copier. :)
Posted on Sep 26, 2008
When i scan an document the scanner put one red line on the photo. this red line appare when print the document.
Have you cleaned the glass platen of the scanner lately? Sometimes a single particle--or smudge--can cause similar issues.
To be sure, try some glass cleaner. If this fails to work, try the following link to HP's latest driver page, especially the 'firmware upgrade' link toward the bottom:
>>CLICK HERE
Hope this helps!
Feb 24, 2011 | HP Designjet 4500 Pass-Through Scanner
When , I scan using the top loader, a red line appears
I would say to clean the glass where the scanner bulb is parked. Just lift up the cover and clean the glass. if you look close you could see a red mark on the glass. Steven
Feb 04, 2010 | HP LaserJet CM1312 All-In-One Printer
How do i use my scanner
If you have loaded the software for the printer/scanner.
Go to your HP director Icon and start this program.
you should see your Scanner / printer listed under Select device.
You can place a document/picture in the document feeder on top.
OR you can place the document / picture directly on the glass.
(Lift the hinged lid to reveal the scanner glass)
Don't worry the document feeder uses a different scan wand.
Now document / picture in place select the Scan document or Scan picture icon from the HP director. Depending on which type of document you have placed in / on the scanner.
Scanner should warm up then scan presenting you with a preview image. From here you can decide what and where to go.
You are not limited to just the HP director.
Other applications can use the twain source to activate your scanner software. This will transfer the scan to your application.
Irfanview is a prime example. Image viewer that will let you "Acquire" and image from you scanner. Be sure to select the twain source.
Nov 10, 2009 | HP OfficeJet J4580 All-In-One Laser...
When scanning a document why do I get a green line running vertially through the document?
Possible hardware problem with the scanner.
Do the ff:
  • copy of a picture or document
  • scan of the same picture or document
If the line is still existing call the kodak technical support; Your printer is in need of repair
the number is 1800 421 6699
Aug 20, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Whenever I scan a picture or document I get a line going down the middle of the page. When I print the same document the line prints down the page. THIS only happens on the scan not when I print from the...
first of all try to make a copy..when you make a copy if you get lines..then clean the scanner glass and the rollers..if its still the same..connect the printer directlu to the wall outlet and then check
Mar 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Scanning 35 mm slides
SOUNDS LIKE A SOFTWARE CONFLICT.BUT IM NOT SURE
Jul 28, 2008 | HP Scanjet 4470c Flatbed Scanner
Black line scanning on digital sender
Yes. There will be an access cover / lid where the document goes in.
Open the cover, and you will see a thin glass, called the 'scan glass'.
Look in the middle of the glass. You will most likely find a glob of white-out, or ink on it.
Use rubbing alcohol to clean off the culprit.
Welcome to scanner / fax / copier troubleshooting 101!
Jun 18, 2008 | HP 9200c Flatbed Scanner
29 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
