Question about Combi Centre DX - Mango
MicroGenus27 No Hot Water
I Have an Ariston MicroGenus 27. Central heating works fine but Often there is no hot water. when there is hot water the boiler will only fire up & heat to 40 on the front panel display. Other times there is no hot water at all. Engineer vivited but the boiler started to work fine just before he arrived & he was unable to provide any other assistance in this matter. Any ideas on what the problem could be?
    Problem Solver:
  • 16 Answers
Check HW and CH temperature probes check secondary heat exchanger for blockage check water pressure switch
Posted on Aug 17, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
I am not getting any hot water, only cold water, when I run my hot water taps. I have an Ariston Bravo water heater. Normally I have permanent hot water at any time. My central heating seems to be...
Sounds like the by-pass valve diaphragm. This valve detects that hot water is being drawn off at the tap and then diverts the mains input water across the heat exchanger. Very often it's the diaphragm inside the valve which is punctured or split.This can be replaced [depending on model] if you take apart the valve
. Remove the front panel and lower the control panel.The valve is at the bottom left of the boiler
Suggest turning off the service taps to the two heating pipes and the cold mains inlet pipes before tackling the valve
Mar 20, 2010 | Water Heaters
St6400c thermostat wont run the central heating independantly
This does not sound like a thermostat problem. I would be looking for a zone valve or circulator pump problem.
Nov 05, 2009 | Honeywell Programmable Thermostat Heater
I have a Baxi WM old boiler. Hot water only needed
there should be a switch which toggles between hot water only /// hot water + central heating /// & possible off on
Either on the boiler or on a separate timer control
Oct 19, 2009 | RTO Ariston Gl4.0 Instantaneous Electronic...
Boiler flames extinguish and reignite regularly
what about flame rectification probe (flame proving probe)
Nov 30, 2008 | Combi Centre DX - Mango
Ariston Microgenus 27mffi combi boiler
im an engineer and recently had exactly the same thing with this ariston boiler, i found out it was the the 'air pressure switch', this is a switch which is part of the ignition, it works in conjuction with the fan. when the boiler fires up the air pressure switch makes, if its faulty it can break the circuit mid flow and cause the burner to shut down therefore giving intermittent hot water and heating, theres a possibility that the aps tubes may be damaged as well so ensure they'e condition is good. hope this helps you
Aug 29, 2008 | Combi Centre DX - Mango
I have an Ariston Microgenus 27 Combi Boiler
I hate these boilers!
If the pump is not circulating change it. If the pump is ok you may have a blockage in the diverter valve
Apr 04, 2008 | Combi Centre DX - Mango
Combi Centre DX - Mango Logo
467 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
