Question about HP Photosmart C7180 All-In-One InkJet Printer
INK sYSTEM fAILURE ON c7180- eRROR: 0XC18A0206
I SEE PEOPLE HAVING SIMILAR PROBLEM BUT DON'T SEE WHAT STEPS THEY TOOK TO RESOLVE THE PROBLEM. PLEASE HELP.
I displayed the ink status and looks good.
Thanks,
Alice
  • 7 more comments
  • aavarce Jan 03, 2009
    I followed the instruction and did something while trying to correct problem. After step 10, it came back with the same problem plus this message:
    Ink System Failure
    The ink system has failed and can no longer print.
    Refer to printer documentation.
    On the printer window, it displayed the same error: Ink system failure with the same error code except the last 3 character,
    Error: 0xc18a0306
    I tried to clean, does not look dirty. I kind of wipe it with tissue paper, put back the ink cartriges, did not help. The message did not go away.
    I don't understand:
    Hold down instant share & photo tray buttons while plugging in power cord
    This means I should pull the plug out first from the wall. I don't see where the instant share and photo tray buttons are. I see the photo tray that is being pulled out, not buttons. Where is instant share buttons?
    Thank you.
    u need to open the printer and replace this ink carriage assembly cable to solve this problem 100%.
    This is getting complicated. I am not a technician. I am afraid to touch anything or where to begin. I don't know what cable or card to look for or where they are located.
    I leave in Middlesex, NJ. Is there a Repair place I can bring this to be fix? I promised to send this printer (once fixed) to my daughter in Japan who is in the U.S. Navy. I thought it would be a simple problem.
    I tried to follow the instruction. Even before I put back the ink cartiges, the same message appeared on the LCD of the printer for the same Ink system failure and the same error code. I put the ink back and put the USB back. Nothing happened. I tried to ignore the message and tried to print anyway, I got an Error-print message on the file I was trying to print. What else can I do. Help.
    These inks are too expensive. Anyway I opened a brand new box of the cartriges and replaced each one. The message is not gong away. I press okay. Message came Geniun HP Ink cartriges installed. I tried to print my test file. It did not print. Print status on the computer showed "Error-Print. I tried to do regular copy from the glass, press Start Copy, them the same messaged appeared for the INK system failed. Same error code.
  • aavarce Jan 04, 2009
    This is the best result I got because I was able to make a photocopy of a document on the glass. But when I tried to print a file from the coputer, I am getting Error-Print on the print status from c7100 displayed on the computer. I think I am getting close to solving the problem, but need more help.
    I am not getting that Ink System error anymore from the LCD of the printer, but I cannot print file from the computer. I am getting Error-Print e status from the computer when I check what happened to the file I want to print.
    Your responses were very helpful, besides I learned something. You are very quick in responding. I appreciate very much your help and attention to try to fix my problem.
  • 2,427 Answers
Click start then printer and faxes..
turn off the printer and then delete the icon in the printers and faxes for the printer..
unplug the printer from the computer, restart the computer, plug the printer back in and turn it on..
That should solve your problems..
Posted on Jan 04, 2009
  • 818 Answers
1) press * and # at the same time
2) press 1, 2, 3 and “support R0632M” should display
3) press > and “information menu” should display
4) press > and “configuration menu” should display
5) press OK and “hardware failure status” should display
6) press OK “failure status: clear”. Press OK to clear
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer off, unplug power cord for 2 minutes, plug cord back in then turn printer back on.
    Scholar:
  • 86 Answers
Hi!
Let us perform some steps to isolate the issue and find a fix for it.
Please perform the following steps and let me know the message that will be displayed on the printer.
A. - Press and hold the “*” key.
B. - Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release in sequence the “1”, “2” and “3” buttons.
screen says "support" R0631M
2. Press and release the right arrow button until the display says “System Configuration Menu”.
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
CustomerName: made a buncha noise, and it didn't print a diagnostic page
Is the error message still being displayed on the printer?
Let us print a self test page to check the functionality of the printer.
Press Setup menu on the All-in-One then scroll using the arrow key and select Print Report then select Self Test Report.
Posted on Jan 03, 2009
  • 4,472 Answers
Http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
Being that you are continuing to have this issue. Follow this link locate the nearest service center. Contact them and they will give you an estimate on repairing the printer. If you need any other assistance please let me know. Also please take a moment to accept and rate my solution accordingly.
Thank you,
Lee
  • 192 Answers
Hp does have a suport site which they are very knolagable on to fix the problem.
    Genius:
  • 1,199 Answers
This should fix it
7) press CANCEL
8) press CANCEL
9) press CANCEL
10) turn printer OFF, unplug power cord for 5 minutes, plug cord back in then turn printer back on.
  • 916 Answers
7) press CANCEL
8) press CANCEL
9) press CANCEL
    Sergeant:
    Champion:
  • 334 Answers
Just simply replace the ink Cartridges. Did you replace them with new or refurbished.
  • Greg Wilkins
    Greg Wilkins Jan 04, 2009
    This is from the hp website,
    The product displays an
    0x ...
    error code when printing (for example
    Error: 0xf0af8004
    ). These error codes indicate that the product has an internal condition.
    Solution one: Reset the product
    Use the instructions below to resolve the issue by restarting the product.
    1. Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
    2. Open the cover of the product and remove the print cartridges.
    3. Close the cover and wait for the
      Insert Ink Cartridges
      message to display.
    4. Disconnect the power cord from the back of the product and wait for one minute.
    5. Reconnect the power cord. If the product does not automatically turn on, press the
      Power
      button.
    6. Open the cover and reinsert the print cartridges.
    7. Close the cover. If prompted, print a calibration page.
    8. Reconnect the USB cable, and try to print a print job from the computer.
    Solution two: Service the product
    If you have completed all the steps listed above and are still experiencing a problem, service the product.
    It says if this don't fix the product have it serviced, This is from the people at HP
    Brigadier General:
  • 8,619 Answers
Hi
Close the cover and wait for the Insert Ink Cartridges message to display.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
You need to download a patch from the link to fix it
http://h10025.www1.hp.com
    Sergeant:
    Novelist:
  • 326 Answers
I had 1 of my customer experiencing this problem.we tried every method of resetting and also replaced the cartridgesbut it didnt solve the problem .printer showed the ink system failure error even though the cartridges were fine.actually its a problem of the cutoff cable between the ink cartridge carriage assembly and logic card.and so its not able to detect ur cartridges and showing this error.u need to open the printer and replace this ink carriage assembly cable to solve this problem 100%.hope it will help you too.
  • HP Master
  • 6,487 Answers
Try doing this steps:
Hold down instant share & photo tray buttons while plugging in power cord , printer will power up & you will see 12345 on lcd screen, pull power plug and then plug it in & turn on the unit is reset & will start purging ink system...
If still the same problem you can try to update the firmware of this printer and that will help to solve this problem.....
  • 177 Answers
Hello and welcome to FixYa!,
Please Remove the Ink Cartridges for 5 Minutes and Clean out the inside for any Dust and Debris left behind, Remove any Plastic tape on the Ink if there is any and Try Again!
Hope this helps -- P3NGYJ03
    President:
  • 2,110 Answers
Did you removed plastic tape from ink cartridge before you install?
  • Sibananda Jena
    Sibananda Jena Jan 03, 2009
    1- Turn off power and unplug from power source.
    2- Open right side of printer (looking at the front).
    3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
    4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
    5- Unplug power source.
    6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
    7- Plug in power source and turn printer on (Printer prepairing occurred.
    8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
  • HP Master
  • 19,396 Answers
Follow the instructions here to reset the code: HP ink system failure error, HP maintenance error,
  • Ginko
    Ginko Jan 03, 2009
    All you have to do is the following:
    "1) press * and # at the same time
    7) press CANCEL
    8) press CANCEL
    9) press CANCEL
    then turn printer back on."
    If this did not work call HP, they will ask you to download a software patch that can solve the problem.See Contact HP
  • Ginko
    Ginko Jan 03, 2009
    Can't you simply Contact HP, they will ask you to repeat once again the operation I told you, then send you a software patch to fix the problem, then if it still does not work they will give you a quote to have the ink pump replaced.
    It is quite simple, I wonder if you can read my comments.
    Thanks.
    Genius:
  • 1,142 Answers
Please try to reset the unit first
  • 2 more comments
  • Maanita Chadha
    Maanita Chadha Jan 03, 2009
    Solution
    1. Press the
      On
      button to turn the printer off.
    2. Unplug the power cord from the back of the printer.
    3. Remove all the ink cartridges.
    4. Wait two minutes.
    5. Plug the power cord into the back of the printer.
    6. Press the
      On
      button to turn the printer on.
    7. Install the ink cartridges when prompted.
    If the error code does not display, the issue is resolved.
  • Maanita Chadha
    If the
    0xc18xxxxx
    or
    0xc19xxxxx
    ink system error code displays on the front panel, service the printer.
  • Maanita Chadha
    Reset the product
      message to display.
      Power
      button.
  • Maanita Chadha
    HP and Compaq products
    800-HP invent
    or
    800-474-6836
    24 hours a day, 7 days a week for most products
    U.S.: English and Spanish for most products.
I have an HP Photosmart C6180 i get error 0xc18a0206
Welcome to Fixya.
Here's how to resolve this issue :
HP Photosmart Reset
Basically, this error denotes "Ink System failure" and can be resolved by Printer reset. Follow the easy steps and you should be good to go.
Thanks for using Fixya.
Aug 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
I recieve Ink System failure error message with error code 0xc18a0206 on my HP PHOTOSMART C7180 ALL-IN-ONE PRINTER.
The error that you are having is a hardware issue, it means your printer has an Ink System Failure. Believe me, there's no use going through troubleshooting for this one. Call HP and just Upgrade your printer. HP Printer Tech Support would be more than happy in giving you discounts and an extra year of warranty for $1.00.
Feb 03, 2011 | HP Photosmart C7180 All-In-One InkJet...
Hello, my HP 3210 printer has an ink system failure...error: 0xc18a0206 , i have followed almost every possible solution on the net...replacing ink cartridges, re-installing drivers and programs, unplug...
Follow steps below to reset Hewlett-Packard (HP) All-in-one Printer. Resetting your printer will reset your printer to its original state.
1. Without turning the unit off, unplug the power cord from the back of the product.
2. Press and hold “# and 6′ keys.
3. While holding those keys plug the power cord back in.
4. Wait until the screen goes blank before you release those keys.
5. Follow on printer screen instructions.
** Give me your feed back
Oct 02, 2009 | HP Photosmart 3210 Printer
Ink system failure Error: 0x05d1281
Ink system failures is a very serious problem on HP printer systems. Ifyou have this problem you should be ready to replace your printer.However there are still troubleshooting steps that you can do to try toresolve this problem. try this Ink System Failure Trouble shooting guide.
Dec 14, 2008 | HP Photosmart C7180 All-In-One InkJet...
Ink system failure
HP Photosmart C7180 will not accept new '02' yellow ink cartridge and repeatedly states 'printer does not have enough ink to ensure printer health. The empty ink cartridge must be replaced to resume.' This is the 2nd HP '02'yellow I've bought and it continues to say the same.
Sep 06, 2008 | HP Photosmart C7180 All-In-One InkJet...
HP Photosmart c7180: "Ink System Failure" error code Oxc18a0306
I get the ink system failure message on my hp c7180 as well as an error code of oxc18a0306.
Aug 24, 2008 | HP Photosmart D7160 InkJet Printer
Hp c7180 ink failure
Here is the exact sequence for the C7180. It worked great for me:
This is easily fixed with the following key sequences. You do NOT have to open the printer and unplug a circuit board.
7) press CANCEL
8) press CANCEL
9) press CANCEL
NOTE: I did this and the fist time the error came back. Do the sequence again (as I did) and the error will be replaced with the usual print cartridge initialization screens. Print a test page to make sure.
Jun 12, 2008 | HP Photosmart C7180 All-In-One InkJet...
Ink system failure
You can find a reset for the HP ink system failure at: http://www.inkbank.com.au/webcontent21.htm
It is for HP C7180 model, but might work with yours too...
cheers L.C.
Mar 13, 2008 | HP Photosmart 8250 InkJet Printer
HP Photosmart C7180 All-In-One InkJet Printer Logo
148 people viewed this question
Vinaya Kumar...
Vinaya Kumar...
Seeker5211
Seeker5211
