Sound coming only out of two speakers+subwoofer only
Sound only coming out of two speakers + subwoofer
  • 673 Answers
Is it used in a computer? If so, change the control setting in the audio settings panel.
Posted on Oct 30, 2012
3 Suggested Answers
Drummernick
  • 440 Answers
SOURCE: Subwoofer will not work when connected
cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
Posted on Feb 11, 2008
Ganx
  • 113 Answers
SOURCE: Subwoofer sound cutting out.
Hiya by rattling i am assuming like something loose/fell off etc (rattling sound or distortion on the speaker itself is different, speaker could be damaged or braiding damaged that 'Might" make the speaker come in and out.) Something could have come of the PC board and may not be to serious. Probably protecting as not 100%. It may be as simple as resoldering the part but if not sure on your side i would advise seeking some help. Best of luck
Posted on Jul 13, 2009
I bought logitec speakers but withought subwoofer is there any way i can connect them to the pc withough the subwoofer or no?
the speaker with the subwoofer may not work as the speaker needs a power supply to boost the sound from the PC.....even if you connect to the sound jack of PC using some adaptor it may not give out the required sound.....i mean it will need amplifyer, the job of the amplifyer is normaly done by the big box that comes along with the speakers (called subwoofer).....
Nov 08, 2010 | Logitech X-230 Computer Speakers
Dear Sir, I hav dell vostro 1015 laptop with windows Xp Operating system. I have purchased 4.1 subwoofer system. When i am connecting subwoofer to pc audio output & all 4 speakers to back of...
Recheck your wiring and instructions. If your woofer is self powered perhaps the amp is no good. Actually it better have amps since the laptop output will not power those speakers.
Mar 31, 2017 | Computers & Internet
Jul 13, 2009 | Altec Lansing VS4121 Speaker
No sound coming from ACS 48 Altec Lansing speakers
Hi janros123 - I don't know if this will help - I have a subwoofer ACS48 that needs satellite speakers (they are blown). Want to buy my subwoofer or sell your satellites? I will buy your broken subwoofer, too...thanks, and good luck! Greg illdooyoo at gmail dot com
May 16, 2009 | Audio Players & Recorders
No sound from subwoofer
Yes. The sound you are playing should be 2.1 sound system compatible only then will the woofer work....sodeep
Mar 20, 2009 | HP GM326AA 2.1 Speakers
Want to use only subwoofer of HK695
The problem is that you need the satallite speakers , they have the volume control on them which thats why you only hear the subwoofer.. yes , i tried other speakers to it and no sound either.So you will need the satellite speakers it come with.. good luck!!
Dec 28, 2008 | Harman Kardon HK695 Computer Speakers
Computer speaker problem
Make sure the cable connected to INPUT directly connected to your sound card on GREEN plugin
Best Luck!
Dec 05, 2008 | GE Ultrasonic 2.1 Subwoofer Computer...
Feb 11, 2008 | Velodyne CT-80 Subwoofer
have you checked for the continuity of the wirings? check for the resistance of your speaker from it jack..... it should measure close to 8ohms or 4ohms using a digital multimeter (DMM). check also the sub out jack of your reciever if there is a signal from it using your main speakers if they come with jacks also (turn the volume low to prevent damage to other speakers you connect on it!
Nov 07, 2007 | Tannoy Sensys 7 Speaker
Subwoofer has a constant vibrating tone that will not go away
I suspect that what you are hearing is the 60 cps of the mains. If the humming sound is coming the subwoofer itself, then it is possible that you have a defective/leaky capacitor in the power supply section of the subwoofer. In the subwoofer, if the buzzing sound is coming from anywhere else other than the speaker itself, then it is possible that you have a loose transformer again in the power supply. Unless you are comfortable working with testers and soldering irons, I would suggest an electronics technician who should be able to diagnose and fix it for you.
Apr 02, 2007 | Dell Powered Subwoofer Set A425 Computer...
 Grubhead
Grubhead
