Question about Sanyo Xacti Video Cameras
My waterproof sanyo camcorder is not working
It stopped working after it had been used in a swimming pool on holiday the pool was only 1 metre deep
  • 673 Answers
Just let it dry in room temperature for a day. Then try switching on. If it still doesn't work take it to a store.
Posted on Oct 30, 2012
3 Suggested Answers
SOURCE: manual
Go to http;//audio.manualsonline.com good luck
Posted on Jun 30, 2008
duane_wong
  • 6826 Answers
SOURCE: My sanyo xacti waterproof model
I couldn't locate your Xacti E1 6 MP waterproof camcorder on the Sanyo website.
Posted on Jul 23, 2010
Pool deep end
you might want to check with a professional to see if you can get a liner to fit that and it will be safe
Jun 24, 2014 | Pool & Spa
I have a jandy ray vac pool cleaner that just goes in circles in the deep end of the pool.
look at instruction manual there is a setting you probably have to set
Jun 01, 2014 | Pool & Spa
Swim p3 player stopped working
The battery maybe flat. The charger or charging cable maybe faulty.
try a different cable.
Jun 04, 2012 | Finis SwiMP3-1G Waterproof MP3 Player...
My sanyo vpc-cg20 monitor shows updide down how do i fix it
http://us.sanyo.com/Cameras-Camcorders-Previous-Models/VPC-E1-Waterproof-Digital-Video-and-6MP-Photos
The above is a description.
I checked the online FAQ's and support, but didn't find an upside down image on monitor problem.
So, I think your best bet for your waterproof camera is to have it serviced by Sanyo.com.
http://us.sanyo.com/Customer-Support-Service-Center-Locator
Jul 24, 2010 | Sanyo Xacti VPC-E1 Camcorder
How deep can we dig for oval deep-end pool
This blog has information about sinking an above ground pool. It is normally recommended that you do not sink the pool entirely into the ground becuase of pressure concerns and the risk of collapse. Generally, you leave 1-3 feet of the pool above the ground and install a deck or similar feature to make the pool appear to be in the ground. The type of pool liner that you have (expandable) is best for this practice, but it can be done with overlap or regular beaded liners also.
http://backyardcity.wordpress.com/2009/06/02/the-above-ground-pool-goes-underground/
May 08, 2010 | Intex 18 ft x 48" Easy Set Inflatable...
I have a Rule 1800 H53SP-24 Swimming Pool Cover Pump. Everytime I plug it in it trips the breaker. Did not have this problem with the same pump a month ago. Tried in GFI and all other outlets. Any...
Hello. There are several possible issues here which are all fairly easy to investigate. Begin by bringing your pump, cord and hose into a warm space for 24 hours to thaw everything out, warm it up and dry it out. Then try it. If it works, you know you have one of the problems described below:
1. Sometimes a circuit breaker wears out and needs to be replaced. Try your pump on a different circuit, insuring that you are using a different circuit breaker. IF it works there, the solution is to replace that worn circuit breaker. 2. Check the impeller and remove any clog, blockage, debris or residue. 3. The 24 foot cord on your pump might have a cut, or a scrape on it. If it does, water is getting into the insulation and causing the circuit breaker to kick. Check your cord thoroughly and if you do have a break in it replace the cord or repair it with a waterproof repair. 4. Your pump motor may be worn or faulty or have a water intrusion. In that case the only fix is to replace the pump. 5. The drain hose could be frozen. If it is, that blockage could cause the breaker to kick. Always ensure that the hose runs consistently downhill.
If you would like to contact Rule, you may do so at the following link: http://www.rule-industries.com/
Regards, Joe. Please rate my answer. Thank you and happy holidays.
Dec 26, 2009 | Rule 1800 H53SP-24 Swimming Pool Cover...
Video Cameras Logo
91 people viewed this question
Top Sanyo Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Mark Magill
Mark Magill
Nicola Conroy
Are you a Sanyo Video Camera Expert? Answer questions, earn points and help others
