Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Hi i have a new sewing machine i havent even used for a cpuple of days and the thread keeps gettind stuck around the bobbin. I checked that it was all threaded correctly and I cant see why it keeps doing this. Usually when you put your material in you want to sew the grid guides the material where you would like it to go but now the grid doesnt seem to be moving the material so it is jamming again please can you help me????
  • johanna829 Feb 01, 2009
    thanks for your help on this it was a new sewing machine so i took it back as the feed dogs werent working.
    Thanks again
    johanna
    Thanks again
    johanna
    Problem Solver:
  • 10 Answers
Not a solution, just some ideas -
Have you checked that your feed dogs are up?
Is the tension of the thread on the bobbin even?
Posted on Jan 11, 2009
New Singer 1507 user - cotton jamming everytime
try this link for a free manual just in case you don't have one
http://www.singerco.com/uploads/download/36952a1312a6d8436174ef874f3662471a946b64.pdf
if the fabric is real light weight you may have to use a stablizer
also check to make sure the needle is the right one for the fabric being sewed..
make sure the bobbin is turned the correct direction, try putting the bobbin in the opposite direction..
if the machine keeps jamming, take it back up where you bought it and show them what it's doing and see if they can help you..
Jun 20, 2013 | Singer 1507
Stitch tension problem - bobbin thread lies flat or bunches. If you increase the needle thread tension there is no improvement - even at the highest needle thread tension the bobbin thread is a mess. Any...
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 16, 2011 | Consew 7360R-1 Mechanical Sewing Machine
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
I have the error message that there is a mechanical problem and the guide says that the machine is stuck??? How would this be repaired?
Good day!
Good day!
Jun 05, 2011 | Feiyue FY100 Computerized Sewing Machine
Bobin jumps when sewing
Could be in around the wrong way, poorly wound or not under tension correctly. Or even the wrong bobbin for this machine.
I suggest that you check that the bobbin is correct, ie do you have several that came with the machine and are they all the same in shape and diameter? Consult the manual if you have one.
Nextly, wind a fresh bobbin taking the thread from the spool through the tensioner (if your machine has one on the top) and then onto the bobbin. Keep a little tension on the thread spool with the handle of your scissors to ensure that the bobbin winds smoothly and evenly. Use your finger tip to nudge the thread to fill all areas of the bobbin. You want a neat smooth wind so the thread will then flow smoothly off the bobbin when it is in the machine making stitches.
Now, load the bobbin into the bobbin holder or bobbin case as per your manual, ensuring the thread is correctly into the tension spring and bobbin is rotating the right way around.
Now thread up and test sew again.
Apr 09, 2011 | Brother Sewing Machines
I have a zig zag dressmaker and i have tried puting my tension on every setting, flossing the thread, made sure my feed gogs where in the up position. and i use european thread. My thread keeps wrapping...
may I suggest to put a new needle in
clean the bobbin area where the feed dogs are for lint & also use that can of air for pc's in the bobbin area
some machines have a problem in the bobbin area & can pull the fabric in the bobbin area when the thread comes off the thread take up lever
I hope my suggestion help you
Nov 20, 2010 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
73 people viewed this question
Top Singer Sewing Machines Experts
Bargain Box
Bargain Box
Mike Cairns
Mike Cairns
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
