Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Washer shakes and makes a lot of noice when spinning.
Just started today. opened the back up and every thing looks in order. i ran it with the washer empty and it was as smooth as can be. then put a wet towel in and it was bouncing. thoughts? dmm
  • d_mackool Jan 10, 2009
    sorry it was more violent than just balancing. when i look into the back i see the weight balance the surrounds the front of the barrel has come off..so i am now trying to figure out how to get the front of the washer off. thanks dmm
  • jenniferg101 Feb 12, 2009
    Our Bosch Nexxt Series washer does the same thing. It vibrates so much it shakes the whole laundry room! Help!!!
  • 57 Answers
It should have seld leveling legs on it. Tilt the washer foward until the foot pads are off of the ground then set it back down. do this a couple of times then check for wobble from corner to corner. put in a small load of socks or shirts or something light. make sure you spread them evenly around the basket. Does that solve the problem?
Posted on Jan 04, 2009
My maytag washer is shaking violently on the rinse cycle
I am currently having the same issue with my Maytag A482. Not sure if you have found a fix yet, or if you have replaced your washer. My washer runs fine until it nears the end of the cycle, when it begins to spin and shake violently, enough to loosen the leveling feet and rock back and forth. I pulled the front panel of the machine off (two screws near the base in the front, and two clips at the top) and ran a load through it. It ran fine until the end, when the machine started shaking violently. I did notice a few small pieces of roundish felt looking material sitting on the bottom, which after some research looks like it may be the damper pad. I found these online:
Damper pad 203956
Replacement Damper 203725 for MAYTAG Laundry Appliances A482
I am hoping this will resolve the issue, I will order them this afternoon and install them once they arrive. I really hate to replace such a good washer with a new high efficiency unit, which all seem to have terrible reviews after a few months/year of use.
Aug 25, 2014 | Maytag Washing Machines
I have a Westpoint Frontloader washing machine. Everything goes well untill it starts spinning. Then is starts shaking and there's a lot of noice. We did make sure that it is level. What else
It is so common that the washing machine can maketerrible noise in many ways and is a common fault. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that machine isvibrating when it is running then the motor /drum suspension has to beinspected. Since these fittings are located on the underside of the machine itis important that you look for the noise with a good inspection lamp. Manuallyturn the motor and drum and listen for the noise, if so the motor bearings, thedrum agitator shaft and fittings must be checked. Also the suspensions whichinclude the shock absorbers and springs, the body clamps must be checked to bein correct alignment and not changed in position. Tightening of themounting is also very important. Finallyin most cases a drop of OIL or smear of grease on the moving parts cane solvemost issues.Check this link :http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.htmlFor replacement of bearings check for tips on thisvisual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Jul 05, 2012 | LG Washing Machines
Kenmore - high pitch noice during spin cycle
Sounds like bearing squeal,providing no leaks or shake leave meantime
Jul 01, 2012 | Kenmore Washing Machines
Have a Roper (Whirlpool) top load washer Model RAL 5144BWO, that vibrates excessively. I ran it without any clothes, and still vibrated excessively. I watched it go through the spin cycle with the lid...
Hi, Well it sounds like either one of the tension springs that hold the outer clear tub to the frame down below came off or broke, or that the basket or gearbox shaft is warped. One other thing to try is the back feet on those washers are spring loaded to take out some of the vibration, if those feet arent level it will make the washer shake. it is easy to reset those so they are level. Stand infront of the washer and grab the back of the unit and pull it towards you so that you raise the rear legs, then simply set it back down. To check the spring you will have to take the outer shell off and look at the springs that are at the bottom of the tub assembly holding the tub down on the frame. Good luck and I hope I was some help.
Dec 09, 2010 | Washing Machines
My ge washer wssh300g1ww does not spin out clothes well
Hello, I too bought one of these washers(WSSH300G1WW). After about one year of operation i noticed that the low spin cycle was making noise so look at it and it was just making noise and not spinning. canceled the cycle restarted the machine but this time set the spin speed to high instead of low, it works on high. im guessing its the clutch in the machine that is faulty and really cant affoard to fix at this time. The thing is i liked to use low spin cause the thing would shake violently on high even with a small load. So now when it spins or i start the machine i make sure theres nothing close that its shaking will cause to fall and break. I also bought the matching dryer (dsxh47eg1ww) it too has problems, the bearings that hold the front of the drum up are going out, thing is i dont over load it and it seems that they went out or started to go out very early as my clothes were getting caught inbetween the drum and the dryer 2 months after i bought it. Im 42 years old so i remember when we had REAL washer and dryers. When quality was revered by companies and consumers. Those old machines ran for years (maybe even decades) without problems, replace a belt from time to time. Now days your lucky to get five years out of an appliance. I know these ones arent going to see 5 years. their about 2 years old and im ready to go find some 1970 model year washer and dryer, rebuild, give a custom paint job to call them retro.
Jan 22, 2010 | General Electric WSSH300G Front Load...
ON SPIN CYCLE MY FRONT LOAD WASHER SHAKES VIOLENTLY
I have a four year old Andi front loading machine, and just in the last week it has started to move violently during the spin cycle and move across the room.
The last time, the movement was so severe that the machine was cutting itself off and then trying to spin again.
I couldn't control the machine and I just had to turn it off at the wall.
Feb 24, 2009 | Frigidaire Washing Machines
Loud banging during spin cycle
please balance your washer and use smaller loads
Mar 18, 2008 | Kenmore 43052 Front Load Washer
Our washer shakes badly at the spin cycle
look on the back and take the shipping pins out there are 4 bolts on the back of the machine the only only ones that are 1/2" socket size or 7/16" pending on the machine.
Jan 04, 2008 | Washing Machines
Please look in the back see if the shiping bolts /rods have been removed it should show you in the manual about this
Jan 03, 2008 | GE WCVH6260F Front Load Washer
Washer appears to be out of balance
Double check the screws holding the washer to the pedestal to make sure they are tight and make sure all the jam nuts on the leveling legs are tight. Loose jam nuts are the most common cause of this.
If they are tight, loosen the right front leg and screw it up until the weight is off the floor. Then run it back down until it contacts the floor. Put the washer in high spin and tighten it down to the floor until you get the spot where there is the least vibration. Tighten jam nut, and check it again in spin with a load of clothes.
Post back and let me know how this works.
Oct 18, 2007 | Whirlpool GHW9100L Front Load Washer
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
136 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
