Question about Mtd Genuine 9460897 Snow Blower Auger Clutch Cable
Mtd snow blower 8 hp oil capacity
Need to know the oil capacity on a 8 hp MTD snow blower?
  • kbkirby
    kbkirby Nov 05, 2012
    the information provided on the oil changes and amounts used was most helpful. Thank you for your help.dd a Comment
  • bcharais
    bcharais Nov 07, 2012
    no prob glad to help.
    Sergeant:
    Champion:
  • 278 Answers
What engine do you have? Tecumseh those are usual 18-21oz Not sure with briggs, but will be around a 1/2 qt (16oz) start there. Add a little at a time to bring level up. get back if you have and need more specifics.
Posted on Nov 03, 2012
3 Suggested Answers
  • 5 Answers
SOURCE: oil change
if this model has a fill tube on it- turn the unit on its side to drain.
Posted on Feb 06, 2009
SOURCE: how to adjust a 9460897 mtd snow blower auger
On the handle end (usually) of the cable is a curved metal connector. Attached to the connector is a threaded rod with a nut. Attach a pair of pliers to the threaded cylinder that the threaded rod goes into. Loosen the nut. Turn the threaded cylinder into the threaded rod to tighten or out to loosen. When you have the correct adjustment, tighten the nut back down onto the cylinder. To be correctly adjusted, pull the cover off the auger belt and push down on the handle. The spring attached to the cable at the pulley end should stretch out when the handle is fully depressed. Spring tension keeps the belt tight. iaff801.jpg
Posted on Feb 15, 2011
Where can I get parts for it.
I recommend eBay.
Jan 12, 2016 | Garden
MTD Snow Flite model 316230500. Where can I get belts?
I have already answered you twice with this information!
They have there own forum.
http://www.snowblowerforum.com/forum/mtd-snowblowers/1397-mtd-snow-flite-snow-blower.html
You don't need the part number, you just need to measure the length, or you can phone and say;
I have a snow flite brand snow blower model.316230500. Serial no.811262, send me a belt for it.
All the belts are here
http://www.jackssmallengines.com/equipment/mtd/snow-blower/belts
and here
http://www.mtdparts.com/equipment/mtdparts/parts/machine-types/snow-throwers
Dec 24, 2015 | Garden
Model # 627804x79a. Spirit snowthrower. How much oil does it take?
what does the manual tell you about engine oil
Nov 24, 2015 | Garden
Craftsman 32" 10 hp
3600+/- 20rpm. That's the top end, I'd say idle should be between 1200 and 1500, but I don't know what model motor it is. I'm assuming its a Tecumseh snow king engine
Nov 22, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Lost my manual,what engine oil to use for my troy bilt tb4bp gas blower ?
You can find your manual here:
http://manuals.mtdproducts.com/mtd/Safety.do?BrandCode=10001&pid=235248&model_num=TB4BP&serial_num=100063&filename=769-03148c.pdf
You must choose accept to open or download the manual.
769-03148c.pdf is the file name.
Or go to this page and click View manual after entering your model and serial number:
If you do not know your serial number enter 100679 and you will still see your manual.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001
7.9 Mb download! The informatiion you seek is in the manual on page 8.
SAE 30 SF or SH or SG (3.04 fl oz total capacity to be changed every 25 hours)
Thanks for choosing FixYa,
Kelly
Aug 29, 2011 | Troy-Bilt 32cc 4Cycle Backpack Blower
I have a 8 hp snow blower,I would like to know what the oil capacity of engine and what type of motor oil i should use.What weight oil?and can you use regular sae motor oil automotive type non detergent ?
Your question as I received it did not specify the engine make, but most 8 hp Techumseh, B&S and Powermore engines take 22 to 32 oz of oil. Buy a quart, put two-thirds of the quart in the engine and check the level with the dipstick or fill hole. Add more if needed to come up to the "full" mark.
All the manufactures and Craftsman recommends 5W30 for 4 cycle winter use.
You can use regular sae oil, but I prefer to use Mobil ONE or a heavy duty oil because air cooled engines run hotter than car engines. Look for a SC/SD or greater rating on the bottle.
Change your oil once a year.
Feel free to as any other questions about your snow blower. Don't forget to rate this answer!
Jan 12, 2011 | Garden
I would like to download the manuel for the craftman 5hp snowblowermodel # s247.996640
The model number of your snow blower is actually 247.886640. That's why nobody else could figure where to get your manual.
Here is the link to the manual:
http://www.managemylife.com/mmh/owner_manuals/25129/CRAFTSMAN-Snowthrower-Gas-L0308228?brand_name_search=247.886640
Feel free to ask any other questions. I know Craftsman Snow Blowers. Please remember to rate this answer!
Dec 28, 2010 | Garden
MTD YARD MACHINE SNOW BLOWER DOES NTO SHIFT INTO
Many times moisture attacks the hexagon shaft that the friction disc assembly slides on. It slides from side to side on the shaft to create Reverse 1 & 2, and the other end creates 1-6 forward. With a wire brush and sandpaper, clean the rust from the hexagon shaft, at the same time lubricate the friction disc bearing with penetrating oil and with a soft hammer, tap gently until the assembly starts to slide on the hexagon shaft. After all the rust is removed and disc assembly is sliding, apply a light film of graphite grease on the shaft. You may want to re-lubricate on a yearly basis.
Jul 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Mtd Genuine 9460897 Snow Blower Auger Clutch Cable Logo
1,433 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
