How do i install hard drive for s 5500 - Computers & Internet
  • 673 Answers
Here is the quick guide to installing the new sata HDD.
http://www.easeus.com/resource/install-sata-hard-drive.htm
Posted on Oct 30, 2012
Logitech Cordless Desktop 5500 Revolution Keyboard Mouse Software won't load.
Toby Christensen,
You may need to choose if your OS is 32 bit or 64 bit when installing the software for the mouse and keyboard. Click the links below for resolutions.
Logitech 5500 Keyboad and Mouse
Logitech 5500 Keyboard and Mouse FAQ's
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Jan 17, 2013 | Dell XPS 8500 Desktop Computer; Intel Core...
Can a recovery set up H/drive from T 5500 be run on a t7400. would like to just change them over instaed of all data transfer. cheers
you can try it but due to the large difference in Chipsets and system configurations it will most likely blue screen on boot if it boots at all
I would expect you can migrate data but the windows and driver installs will need to be done from scratch
Jun 03, 2011 | Dell Precision T5400/ T5500/ T7400/ T7500...
Hard drive is no good cant connect
Re-seat the hard drive, this may correct the problem.
If the go to the BIOS setting and check if the BIOS can detect the hard disk, if not the the hard disk is faulty.
To get your laptop working, replace the hard drive and install Windows on the new hard disk, then install the Acer laptop's device drivers and your programs.
To install the laptop's device drivers then -
Download the drivers from the Acer WEB site.Make sure you select the model of your laptop and the XP or Vista version ofthe drivers you that require and it matches the Windows version that isinstalled on your laptop. Use this link to get to the Acer support: -
http://www.acersupport.com/drivers_download.aspx
You may need to download the drivers using a computer that has Internet access, then copy these drivers to the Acer and install these drivers.
Feb 07, 2011 | Acer Aspire 5500 5570-2609 Laptop
Can i use an external hard drive to run an operating system (XP)
Yes. You can run an OS from an external hard drive. You have to install the OS to the External hard drive and will have to boot from the USB. I have tried that for Fedora Linux OS but not for XP. Basically all Operating systems boots up in the same manner. So definitely, its possible with windows XP also.
Thanks
Sherbaz
Sep 21, 2010 | Acer Veriton 5500 PC Desktop
Software appears to not install completely on my laptop. When I open the AIO Center all icons are grayed out and printer showing disconnected. This printer is also intalled on my desktop. Had a little...
I had trouble installing this from the installer on the desktop. It would quit the process before being done.
I solved this by coping to an available hard drive the installer, and when running the installer from another hard drive it installed fine.
Jun 27, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Missing support/installation cd
I had the same problem.
There is a cd that came with the server called "IBM RAID Support" that is a must have to reconfigure the hard drives.
It took me a week to find the ISO image.
I will upload the cd via FTP and send you the link.
Apr 07, 2009 | IBM Netfinity 5500 M20 4RY (86624RY)...
Acer aspire 5500 hard drive
I have used norton ghost to do just what you're wanting to do.
1)run ghost on a desktop pc,hook your 60gb hd to your pc as a "slave"(using adapter).
2)"clone",or"create image"of the hd to a folder (on desktop)
3)swap hd's(on desktop)
4)format new(250gb)drive as "ntfs"
5)open ghost,and do a "restore"-of the saved image folder-TO new hd,re-install new 250gig in laptop.
///YOURE done!!!
-now you will have a back-up(old hd,AND image file folder.
Dec 18, 2008 | Acer Aspire 5500 5570-2609 Laptop
How to re-connect Epson CX 5500 after I changed my hard drive.
If the technician who changed your hard drive was able to transfer ("clone") the system from your old drive, all you need to do is plug your printer/scanner in and it should work. If he was not able to do this and you have a new Windows installation, you need to use the CD that came with the printer to re-install it. Just connect up the printer to the computer BUT DO NOT TURN THE PRINTER ON UNTIL TOLD TO. Start the computer and when Windows has loaded, put the CD in the CD drive. The CD should start the installation process - just follow the instructions. If you do not have a CD, download the necessary installation software from the Epson website.If you don't know how to do this, report back and I will provide more help.
Oct 19, 2008 | Epson Stylus C48 InkJet Printer
Changing HHD on Averatec 5500
Hi Sunergos!
Replacing the drive is real easy! Diconnect the power and remove the battery. On the bottom of the laptop, lower right hand side, you will a panel, with one screw. Remove the screw, and lift the panel. The drive had a plastic pull tab on it. Lift up gently, and pull to the right. Don't lift too high. The drive will come right out. The Drive is held in a "tray" with four little screws. Remove those, and place the new drive in the same way. Just reverse the procedure, to install it, making sure the pins line up the with the female connector. Hint - wait 10 min or so before putting the drive in, or it won't recognize it. Newegg has a 120 gig drive for that lappy for $74. Upgrading my Averatec 5500, I ended up with a 3400+ CPU, 1 gig ram, and a 120 gig harddrive, that dual boots to Vista or XP, and is just as fast in either OS. Good Luck!
Dec 03, 2007 | Computers & Internet
Not reading software
Hi, If the PC still powers on and POST then should be reasonable to repair. Assuming that you have to replace the 80Gb HD, that will set you back something like 80USD. Physical replacement is relatively easy, you can do it yourself. Of course you would need the recovery CD/Windows installers to put in Windows again. Hope this be of some help/idea. Post back how things turn up or should you need further information. good luck and kind regards.
Sep 17, 2007 | Acer (91.AB033.041) 73 GB Hard Drive
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
