My frezzer once in while as water on the floor only once in while about every four months Kenmore model # 106 9555923
[email protected]
Hi!!! You could have a plugged drain line. Open your freezer door and remove the bottom tray and look to see if you have ice on the bottom if you do then its a frozen drain line get a hair dryer and and apply heat to the bac evaporator fins and all the ice..sometimes also some sxs refrigerator model leak a small amount of water right after you use it..Good luckk..
I have the same problem with my Kenmore model 106. Occasional water on the floor every few months. I do not have any ice on the bottom of my freezer.
Recently it got worse. When I used the water dispensor on two occasions water poured out within 20 seconds onto the floor underneath the freezer. I figured it was related to the water dispensor so I locked the dispensor and didn't use it. Later that night water poured out on the floor again. So I guess it's not related to the water dispensor.
Any ideas?
thermostat not working
how to level
