Question about Plantronics Radio Communications
Mic is not working on plantronics cs530 headset, person on the call cannot hear me
  • 3 Answers
SOURCE: Plantronics headset S10
First, try a headset that you know works.
Posted on May 10, 2008
keekus
  • 83 Answers
SOURCE: USERS ARE SAYING PEOPLE CANNOT HEAR
1. Check the configuration dial on the left hand side of the base to see if another setting works better. The recommended setting for most phones is 1.
2. Make sure your speaking (transmit) level is not too low. First, try increasing the volume on the telephone. Secondly, the master transmit controls are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting. You can fine tune this setting with the Plus (+) and minus (-) buttons on the back of the base that are above and below the picture of the microphone.
3. Double check the battery has a full charge. To check press down on the headset into the base station to ensure it is in the base in the correct position.
The Amber Charge light on the base will flash while charging and will stay solid amber when fully charged.
3 hours = full charge
Posted on Jul 18, 2009
keekus
  • 83 Answers
SOURCE: I am getting feedback with Plantronics CS70 Wireless Headset
Echo is usually caused by the transmit (speak) level on the unit being set too high.
1. First, try lowering the volume of the telephone. If you still hear an echo, adjust the volume of the headset itself.
2. The master transmit controls of the headset are the ABCD switch settings on the bottom of the base. A is the lowest and D is the highest setting.
3. You can fine tune this setting with the plus (+) and minus (-) buttons on the back of the charging base.
4. If this doesn't fix the echo, try moving the configuration dial on the left side of the charging base. The recommended setting for most phones is 1.
SOURCE: mic on ps3 headset does not work
how do you pair it ... my light wont turn purple...
Posted on Dec 27, 2009
SOURCE: USB Headset mM/N:A-0374A mic problem
I get a problem when gaming all the sound of the game is on the outside of the map and its not with the sound properly
Posted on Dec 29, 2009
How come people can't hear me from my headset?
Volume only has to do with the sound level you hear.
The only thing that affects the sound the other ends hears is the microphone, Have you tried moving the mic? Has the headset ever worked properly?
If the other end hears you at all, then the headset SHOULD NOT be muted, but it's worth checking out. They put the mute switch on the underside of the boom mic and sometimes people hit the switch by mistake when moving the boom.
Aug 17, 2014 | Plantronics Voyager Legend
Plantronics Noise Cancelling headset H261N hearing others problem
where is the other end of your amplifier connected? To a computer, to a phone?
Did you connect correctly the mircophone to your amplifier and from your amplifier to the correct plug?
Oct 20, 2007 | Plantronics (43-1960) Headphones
Tip
What to check if Plantronics cordless mic does not work but earpiece works fine
If the party you call cannot hear you, check two things:
1- while on phone with the party, change the configuration dial on the headset base to 1. (We have Nortel phones and it must be on 1 for headset and mic to work with Nortel phone sets.)
2- Push IN on the headset volume control. Pushing IN activates or deactivates to MUTE feature on the headset.
Hope this tip helps you.
on Feb 22, 2016 | Plantronics CS55 Wireless Headset
Bad echo in ear piece while talking
You can try adjusting the volume and see if any results. Try to verify if it is a hardware defect by using a Bluetooth piece and if you get better results.
Nov 08, 2013 | Plantronics CS530 Wireless Headset System...
My m100 bluetooth always calls the wrong person.
Plantronics M100 always calls the wrong person:
Unfortunately this is a common occurrence. We say one name and it says, "did you say..." something totally different. I think that most of us has had that experience. The Bluetooth headsets that have a longer "boom" type mic will pick up your voice better and have a better chance at hearing your voice properly the first time. Models like the Plantronics Voyager Pro+ and the WG100/B have a boom type microphone. The WG100/B also includes a UBS Bluetooth adapter so it can be used on a pc.
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/bluetooth-for-mobile-phones/voyager-pro-bluetooth-headset.html
http://www.headsetsdirect.com/plantronics-bluetooth-headsets/computer-mobile/wg100-b-savi-go-wireless-headset-mobile-computer.html
Good luck from Headsets Direct - 800-914-7996.
Aug 04, 2011 | Plantronics M100 Bluetooth Headset
I hooked it up to my ps3 but i can't hear any volume from the game. i ahve an adapter. the mic works but i just can't hear anything
Per Plantronics the Gamecom 367 headset is not compatible with the ps3. Plantronics did say the Gamecom 777 will work with the ps3. Please see the link below for the Gamecom 777.
Plantronics Gamecom 777
Good luck from Headsets Direct!
Apr 24, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
When I plug in in my plantronics 367 closed ear gaming headset all I hear is the sound I cant get the mic working
This is a plug-n-play headset, so no special software is necessary for it to work properly. You want to make sure the leads are plugged into the right jacks on the computer and that the jacks are live.
Apr 18, 2011 | Plantronics GameCom 367 Closed Ear Gaming...
Mic not working (plantonics headset)
Your exterior mic MAY have been the one ACTUALLY working rather than the one on the headset. Some mics require a battery for the mic part to work, Not sure about your particular Plantronics. If it has a battery, then check the battery as the receiver part does not use it but the mic MAY use it.
Oct 06, 2009 | Plantronics Radio Communications
Radio Communications Logo
1,203 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
