Question about HP LaserJet Office Equipment & Supplies
Frozen touch screen on hp laserjet 6040
The touch screen do not respond
4 Suggested Answers
SOURCE: The scanner on our HP
Follow steps given below:
In control panel click at printers and faxes,click at properties menu and select hardware component.
Click at the scroll bar given at the end and select use this device.
Your blocked printer will working.
Posted on Sep 23, 2010
BaronVonNuke
  • 1915 Answers
SOURCE: HP LaserJet M4345 - The
Calibrate the control panel
Use the following procedure to calibrate the control panel:
1. Turn the device off.
2. Press and hold the # key and the C key.
3. Turn the device on.
4. When a small white square appears in the upper-left corner of the control-panel display, touch
the square with a stylus.
5. When a small white square appears in the lower-left corner of the control-panel display, touch
6. Allow the device to finish the boot process.
Hope this helps.
Posted on Mar 11, 2011
seeker5211
  • 1089 Answers
SOURCE: I have a HP LaserJet
59.30 means that the fuser motor experienced a start up error.
If power cycling the printer won't clear the error you probably need a tech to troubleshoot and/or replace the motor.
Posted on Dec 09, 2011
Rooler kit error
1 Turn the printer off.
2 While pressing [- Item] and [- Value] turn the printer on.
RESET MAINTENANCE COUNT appears, followed by INITIALIZING.
After a few seconds READY appears.Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For HP Support
Apr 01, 2014 | HP Color LaserJet CM6040f MFP Q3939A...
Touch screen frozen
Did you try to pull out the battery and restart your phone? If not try it, if yes and it's still not working, you have to go to a service point to do the job for you.
Jan 28, 2012 | Nokia N72 Cellular Phone
I have a HP LaserJet 6040 with this error message 59.30
Sep 16, 2011 | HP Color LaserJet CM6040f MFP Q3939A...
I HAVE AN HP LASER-JET MFP 6040 WITH AN ERROR CODE 60.03 LIFTING TRAY ERROR
60.X ERROR To continue turn off then on The tray specified by X is not lifting correctly. Follow the instructions on the product control panel.
Aug 02, 2011 | HP LaserJet CP6015xh Printer
My touch screen doesn't respond to touch and I am unable to make copies.
Does it respond to any touches or is it greyed out? This problem can be caused by either a bad touch pad or a defective scanner. Try accessing other options on the front such as the administrative menu. If those work, then the scanner might be bad or locked? Lift the automatic document feeder lid and check the lock on the left hand side to make sure the scanner is not locked. Restart the machine as well, could be an intermittent problem or static discharge.
Jun 06, 2011 | HP LaserJet M3035 MFP Printer
HP LaserJet M4345 - The printer display is mangled, the touch screen does not respond properly to commands. Is there a way to reset it?
Hope this helps.
Jan 25, 2011 | HP LaserJet M4345 MultiFunction Printer
The scanner on our HP Laserjet 6040 MFP is blocked. How can I unlock it?
Sep 23, 2010 | Office Equipment & Supplies
588 people viewed this question
Seeker5211
Seeker5211
