Question about HP PSC 2210 All-In-One InkJet Printer
"Check color cartridge" error message
My printer (PSC 2410) gives me an error message "check color cartridge" when it is powered on. I have checked and replaced the color cartridge many times, with no change. We have tried to turn off and on the printer, with no change. The printer is totally disabled, and will not function, even with the black cartridge. Please help!
Nikki
  • 52 Answers
Try resetting the printer to factory defauts. Hold down the # and 6 buttons. Pull out the power cable while holding these buttons down. Keep your fingers on these buttons and put back the power cable. It should now show (full/partial reset). Follow the prompts and setup all your original features. If this fails then you might have a hardware problem.(Carriage assembly or Cartridge Holder)
GOOD LUCK
Posted on Jan 03, 2009
I do not want to use color cartridge in my hp psc 2410 printer. But without installing this cartridge, the printer is not working
Inkjet printer require both cartridges to be installed and have ink to go online. There is no way to bypass this function. If the printer does not detect the cart when it tries to perform a head clean cycle you get the error you have displayed on the screen. All inkjet printers are like this not just HP.
Apr 11, 2013 | HP PSC 2410 All-In-One InkJet Printer
Ican't align print cartridges .I change the color cartridge (57) and now when i start the printer i receive a message "Press OK to print Allign page" . The printer start the operation and...
Your color cartridge does n't print well
in order to have a success alignement
check if the expire date has pass
you need to replace the color cartridge or refill it
by this easy method
Jan 17, 2011 | HP PSC 2410 All-In-One InkJet Printer
Error message "Remove and check color cartridge"
There may be debris that is blocking the communication between the cartridge and the printer. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
Mar 19, 2010 | HP PSC 2410 All-In-One InkJet Printer
I get the message "remove and check print cartridge" on my hp 2410 printer. I Replaced the black cartridge and still the same. I do not use color and have had cartridge in for a couple of years. Any way...
I don't think so. Printers usually won't print unless it can detect both cartridges. It doesn't matter whether the colour one is empty or full, as long as it can detect it you can usually still use black.
Sep 25, 2009 | HP PSC 2410 All-In-One InkJet Printer
Won't print gives error message above power and function push button incorrect color cartridge installed---was working fine yesterday no cartridge was done...
uninstall and reinstall printer and make sure u follow the promp and put the right cartridge in the right spot....black and color....2 different chambers
Apr 19, 2009 | HP PSC 750 All-In-One InkJet Printer
Hp psc 2410 photosmart check color cartidridge ?
I'd clean the cartridge connections on the printer, try a new cartridge and refrain from using reinked cartridges.
Jul 23, 2008 | HP PSC 2410 All-In-One InkJet Printer
Print cartridge error
try to take out the ink cartridge and check if there are any leaks inside. check also if there is still ink left in the cartridge. have the ink cartridge replace and the printer cleaned.
hope this helps.
fixya!
Jan 29, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
144 people viewed this question
Seeker5211
Seeker5211
