Question about GPS
Production year of gun
64132
  • 673 Answers
You must mention it in more detail.
Posted on Oct 30, 2012
Looking for an Iver Johnson double barrel receiver
Going to be a pretty impossible task. Numrich is your best bet and although Iver Johnson are still in business, they don't want to get involved with old guns.
  • IVER JOHNSON Accessories ' Numrich Gun Parts www.gunpartscorp.com > Manufacturers Need gun parts and accessories for IVER JOHNSON? Look no further, Numrich has everything you need right here for IVER JOHNSON.
  • iver johnson gun parts ' eBay www.ebay.ca > Search > iver johnson gun parts Find great deals on eBay for iver johnson gun parts and top break gun parts. Shop with confidence.
  • Iver Johnson Gun Parts: Bob's Gun Shop www.gun-parts.com/iverjohnson Iver Johnson Arms Company Gun Parts; Bob's Gun Shop. Gun Repair Parts for Iver Johnson Guns, Many Obsolete Parts that hve not been available in many Years.
  • Iver Johnson Gun Parts - Schluder Shots https://www.schludershots.com/.../iver-johnson-gun-parts.html American Arms Gun Parts; AMT Gun Parts; Astra Gun Parts; Australian Military Gun Parts; Beretta Gun Parts; British Military Gun Parts; Browning Gun Parts
  • Iver Johnson Arms www.iverjohnsonarms.com We do not have any parts, guns, records, or info related to the older Iver Johnson products.
  • Sep 29, 2016 | Optics
    Year that smith & wesson 38 cal hand gun was made
    You have to go to a library and use The Standard Catalog of Smith & Wesson
    Mar 01, 2016 | Smith and Wesson Security Products M&P HPA...
    Stevens model 311a,where is the serial number. I can not find one.
    All the Stevens factory guns made from 1948 till the passage of the Gun Control Act (requiring serial numbers) had a date code roughly stamped on the center bottom of the action either just in front of the trigger guard or just behind the hinge. The stamp is a letter for the year and a number for the month of manufacture, stamped inside of a circle or oval. "A" represents 1948 and each succeeding alphabet letter represents the next year. "O" and "Q" were not used.
    I don't know what the letter codes on the action flats mean. The 311A is a model number; there were several letters used with the number 311 to identify the various small changes in the gun over the many years of production..
    Apr 27, 2015 | Optics
    What are the difference between airsoft guns and traditional guns?
    Airsoft guns refer to replica firearms primarily used in airsoft that are capable of firing plastic pellets through a piston driven by compressed gas, spring and electricity or battery. This type of gun is non-lethal and capable of offering more realistic replicas. You can upgrade your airsoft guns with cheap airsoft gear too.
    Sep 18, 2014 | Ics MP5A5 Airsoft Gun
    I am looking for a replacement hose for my Blue Max pw2200/03435. Does one exist? If so, where can I get one?
    Here is a site that shows the lightweight blue max power washer hose
    http://www.shopping.com/Psi-Blue-Max-2200-Psi-High-Pressure-Gas-Power-Washer/products
    It looks to be a right-fine chinese product manufactured using the technology we paid-for and developed over the past 50 years and then gave away with our jobs overseas.
    If you bump up to professional power washers..
    Power washer hoses are interchangeable as long as the quick-connects on end of hose can unscrew.
    We used power washers a couple times a week. When I needed a new hose, I went to the hydraulic hose shop. They make steel-wound hydraulic hoses for tractors and heavy equipment.
    Search 'hydraulic hose in Your-town-your-state'
    If the quick-connect ends of the Blue max hose do not come off, check the quick-connect end attached to machine. If it comes off, you can buy a new gun and hose. If the quick connect on the blue max machine does not come off, then the life of your machine is directly related to the life of that single quick-connect fitting.
    Search 'power washer guns'
    Here's a site with guns like we used
    http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
    Oct 15, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
    I have purchased three milwaukee screw guns in the past year and a half and all four of my batteries will not charge. when my first set stopped working i had to purchased another screw gun and within six...
    The same thing happened to me. There is normally a 2 year warranty on the batteries from Milwaukee. You can't return them to the Home Depot, you have to send them back via a local repair center.
    You won't be able to exchange the batteries at the repair center. The repair center sends them back to Milwaukee and Milwaukee will send replacement batteries. You will probably be able to find the closest repair center on line.
    Sep 15, 2010 | Milwaukee Tool Garden
    Bad air leak out of handle can it be fixed
    Depends, older Vacula 010 guns were easy to fix with new o-rings on the valve (there should be 2), the newer 020 guns can leak and seem not to be repairable, even with new o-rings. Unfortunately the older guns have been out of production for 4-5 years, replacement parts are not available. But the o-rings are a common size o-ring, easily sourced.
    Dec 16, 2009 | Vacula 4" Full Flow Blow Gun
    Delivers the product but has a pulsating spray Binks Model 7
    There is actually very little in the gun in the way of parts. The outer front nozzle unscrews, then the inner nozzle (you need a thin open-end wrench). The fluid and air controls unscrew from the back with loose springs. The fluid needle pushes out the back and the air valve unscrews from the front side of the handle (you may need to remove the trigger to get the valve out). The only critical area is outer and inner passages of the two front components. Soak the entire gun and parts in gun cleaner for an hour or two, then blow everything clean with compressed air. Lightly lube the trigger bearing, fluid needle (not the thin part), and air valve assembly. Put a little light grease on the threads of the two controls and their springs. Don't oil anything around the nozzle. Hopefully, you found a wad of paint in the gun body after soaking it. After reassembly, check the air flow first which should not pulsate. If it does, check the air line with a blow gun--does it pulsate? Check the regulator, hose, and air filter if it does. If the air delivery is good but the gun still pulsates while painting, check the paint supply system. Hope this saves the gun--I've had a Binks gun for many years and it was well used before I got it.
    Oct 08, 2009 | Binks Model 7 Conventional Suction Feed...
    GPS Logo
    15 people viewed this question
    Top GPS Experts
    Will Halftowaite
    Are you a GPS Expert? Answer questions, earn points and help others
