I NEED PANEL BOARD MODEL KDL32L5000
BRAVIA REMOTE CONTROL PANEL BOARD MODEL KDL 32L5000
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
This is the part number of the panel: 3-870-746-01
Posted on Oct 31, 2012
SOURCE: remote codes
I had same problem. use five digits or
10000
Works for me on 2004 sony wega
leroy
Posted on Jun 25, 2008
  • 4234 Answers
SOURCE: Need a Replacement LCD Panel Module for a Sony Bravia KDL-32S2000
I don't have a listing for the model that this is posted under, but the replacement panel for similar model KDL-32s2010 is $2232.55
I would expect the cost of your replacement to be similarly priced. If you post your specific model, I will attempt to get the exact price and part number.
Dan
Posted on Feb 16, 2009
SOURCE: How to enable "Bravia Sync" on KDL-40V2500
I also have the same problem and was wondering if you ever found out the answer to this problem Peter?
Posted on Feb 21, 2010
welcomejee
  • 10594 Answers
SOURCE: My Sony Bravia KDL-40D3000 no longer responds to
Remote sensor seems bad in your KDL-40D3000 that will be replaced because it is unable to receive remote infra red signals and remote has been tested on other tv and found good.
Please replace remote sensor in tv to get it fixed, local tech will help you to solve this problem.
Thanks.
Posted on Mar 27, 2010
SOURCE: el tv no enciende, solo lo intenta, se escucha un
He tenido el mismo problema varias veces, la tele parece completamente muerta. Es un problema con el modo de ahorro de energía. Si la televisión no tiene señal de entrada en uno de sus canales hdmi o vga, entra en modo ahorro de energía, encendiendo la luz de stand-by. No he determinado en qué situación aparece el problema, pero creo que es cuando, estando en stand-by, se desconecta la alimentación. Para resolverlo, desconecta la televisión del enchufe, a continuación desconecta TODAS las entradas traseras de señal, audio, vídeo, hdmi, vga... todo. Espera unos segundos, enchúfala y escucharás un click. A continuación, debe encender normalmente.
Posted on Dec 18, 2010
Back lights come on for a frw sec then go off i replaced the back light board still the same thing
Fault to its main board. Control voltage to back-light should be from it. Now it do not. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 09, 2015 | Sony Kdl-32l5000 32" Lcd Flat Screen Tv...
Ir receiver not working
Fresh batteries in the remote control first and foremost. Also check the white buttons on top that the "tv" is selected. If it doesn't turn red, remote might be bad or need cleaning depending on age/condition. A little (very little) bit of grease or vaseline on the battery connectors is a good fix if they are corroded. be careful don't get that on your skin, use gloves.
Mar 24, 2013 | Sony Kdl-32l5000 32" Lcd Flat Screen Tv...
Kdl32l5000 no power
Sony 32L5000 Power supply not likely gone bad unless the fuse blow. If there is a click sound and vold meter read 3.3v (standby) on the far top right terminal mean you power supply still good. If no led light on the front that is the bad main board (board with tuner box and RCA, hdmi plug) My replace and work like a charm.
Nov 18, 2011 | Televison & Video
I bought a Sony LCD HDTV Model KDL 32L5000 in Dec 2010 and the picture is now showing a 4 inch wide purple and green vertical line on the right side of the screen. What is causing this problem and how can...
THE CAUSE IS LCD PANEL IN BAD CONDITION OR T CON BOARD IN BAD CONDITION THE T CON BOARD IS CHEAP THE PANEL IS VERY EXPENSIVE, TH T CON MAY BE COLD SOLDURE IN THE PROCESOR.
Sep 08, 2011 | Sony KDL32L5000 32 in. LCD HDTV
I have a Sony Bravia 32" t.v. model number KDL-32L5000. My t.v. turns it's self off periodically. I have looked at the sleep mode and it shows it is off. Could there be something else that may force...
The same thing happened to me. I went to Menu. Click the bottom item and when it opens, click on ECO. Now turn off both Power Saving and Idle TV Standby. It is mostly caused by the Idle TV Standby, though. Good luck!
I am still working with the loss of the IR capability. I sadly found the Warranty docs when it had ended...
Jan 19, 2011 | Sony KDL32L5000 32 in. LCD HDTV
Code for Channel Master CM-7000 Digital TV converter box ? I need code number for Sony TV
If you do the setting up using device codes scan correctly (page 25 in the user guide ) it worked with my sony bravia KDL-32L5000.
Oct 26, 2010 | Channel Master (9537) Remote Control
Tv manual for kdl-32l5000
You can download the manual as a PDF from the Sony support site: http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDL32L5000 . The Operating Instructions book is the third link from the bottom under Manuals.
I hope this helps.
Sep 18, 2010 | Televison & Video
Sony model KDL-32L5000 does not respond to the commands of its remote control model RM-YD028. We have been using a Direct TV remote as well to control volume but its not reacting this remote either...
If the only thing not reacting is the audio, then the audio board or the main board has gone bad. Enter the model number and tv make on you tube to get more detailed info.
Dec 15, 2017 | Sony KDL32L5000 32 in. LCD HDTV
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
