Question about MidiLand MLI-699 Computer Speakers
I have no sound
I plug the speaker into the speaker port and there no sound so i went to volume control and it say something about mixer software
  • 238 Answers
Try downloading the audio codecs for that matter. Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
*Drop me a comment and i will assist you.
Best regards
Posted on Jan 04, 2009
I just set up my water dancing speakers... one of them doesn't emit any sound. Lights and water work...just no sound. Is this normal?
no it is not normal. Did you plug in the 3.5 mm plug into the headphone or speaker out port ? The Usb cable just powers the speakers. Check computer has both left and right speakers volume set correctly . Check the speaker icon right click on it . Check
Mixer and volume control .
Dec 18, 2016 | Audio Players & Recorders
Audio will play on internal speakers only
Are you plugging the external speakers into the right port? Try plugging them into the Headphone port if there is no external speaker port. Make sure you have the external speakers turned on and the volume turned up. Also make sure you have the software in the computer to have the volume turned up and not muted. Check the audio sound properties and make sure the volume is turned up and not on mute.
Click Start/Control Panel then look for Audio or Sound and check the volume.
You can also click the megaphone at the bottom right near the time to adjust the volume and check for mute.
May 12, 2012 | Dell Inspiron Mini 10 Notebook
How can i get sound in my pc.. i have lost the sound or volume
Check you have not accidently muted the sound on the desktop icon ( speaker icon)
Check the (green?) line connector is plugged into the correct port on the sound card or chip
Check that the audio driver appears in the sounds tab in the control panel (double click sound icon)
If the driver is missing, re-install it
Also while in there, check the tabs for the volumr mixer etc and see volume is set at max for line out
If those steps fail, check the speakers are getting power and the indicator light is on
Finally, test the soundcard with another speaker, or use headphones if no speakers available
Dec 30, 2010 | Dell A215 Computer Speakers
MY OLD INSIGNIA SPEAKERS (WITHA SUB-WOOFER) WENT UP SO I GOT A SIMPLE 2 SPEAKER INSIGNIA 2.0 POWERED SPEAKERS. NOW I CANT GET ANY SOUND. ANY THOUGHTS?
1. Try looking in the taskbar of the Windows screen and selecting the volume control ( a speaker icon) check the mixer see if the volume is not muted or in the "0" position
2.Check the "input port on the sound card where you connected the new speaker assembly.
3. Check the volume control knob on the speaker assembly to see if it is not in the off or lowest volume position.
4. Check the new speaker by connecting them to another computer that has the sound already on and working this will let you know that the speaker assembly is good.
6. check the sound card drivers to the internal sound card that is on the mother board if this is where your sound card is located. Use the "manager" to see if it is working properly. If not then do a "reinstall of the sound card drivers or use the "update feature in the hardware window for the sound card to install the latest version of sound card drivers.
I hope this helps. Have a great day!
Sep 25, 2010 | Insignia 2.0 Speaker System (2-Piece)
My a205-s6808 toshiba laptop right speaker sounds bad. its like a hushing sound everytime the bass plays. it sounded great and then one day it happened. this is my bestfriends birthday present last year...
It may be as simple as the balance controls.
You can get to these by selectin the volume control mixer and double checing that they are set to the middle
NOTE these are not the main volume control ones but the smaller slder usually at the top or bottom of the mixer display depending on the sound mixer software used.
If it is windows 7 then double click the speaker icon and select mixer
now click on the speaker icon
select levels
at the right hand side are options for BALANCE and adjust as needed
Windows XP is as follows
ouble click on the volume control from the taskbar or sound options from control panel and the balance sliders are at the top above each volume control
Aug 19, 2010 | Toshiba Computers & Internet
No sound from my dell vostro 200 at work...plugged speakers in green port ....when I hear sound it is very low.
Right Click on the speaker icon on your desktop in the lower right corner. Open volume mixer and slide bar upwards to increase the volume.
Nov 04, 2009 | Dell A215 Computer Speakers
Where can I download a mixer device
Unless they are USB speakers they would not need a mixer or drivers device.
Plug in ONLY the regular wired speakers and ONLY to the green port on the back.
Make sure they are powered up and the volume is about half way.
OK now you need to call up ether the sound card application or preferably the windows volume control from the bottom tool-bar.
Click Open Volume Control.
A box with sliders in should appear. make sure that volume control, wave, sw synth, aux, cd player, line in
are all about half way and that none of them have ticks in the box at the bottom.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else)
Now close the slider box.
Put a normal music CD in your CD/DVD player on the computer and set it to play with windows media player.
You should now have sound out of the speakers.
Double check again and make sure it all works.
If you still have any problems check your hardware list and make sure thee are no exclamation marks by any sound hardware (excl. speakers)
These need to be sorted out first. for that you need to know what your sound card is and download the drivers (or update them)
Sep 01, 2009 | Boston Acoustics Audio Players & Recorders
Laptop sound works when using earphones, but speaker suddenly doesn't work without earphones. Have we accidentally pushed a button or something?
When you plug in headphones, very often they get accepted automatically and the sound port changes in the OS accordingly as well. But when you unplug them again, it happens quite often that the OS is not switching it over on its own (even still happens in win 7). Just go into the volume mixer panel/options and change the output back to the port of your speakers.
Aug 02, 2009 | HP Compaq Presario CQ50-211NR Notebook
Sound won't work without the earphones being plugged in
Make sure the speaker volume is turned up and also go into Control Panel, Sounds and make sure nothing is muted and all volumes are turned up. Also make sure the speakers are plugged into the sound jack in the back of the pc. The speakers also need power but since the light is on, it sounds like they are plugged in.
Apr 14, 2009 | E-Machines eMachines Desktop PC
No Volume oe sound coming out of speakers
try connecting speakers to another sound source or if you have access to a ohm meter, check impedance of speakers, should measure 4~8 ohms.
Jan 25, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
MidiLand MLI-699 Computer Speakers Logo
280 people viewed this question
Top MidiLand Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a MidiLand Audio Player and Recorder Expert? Answer questions, earn points and help others
