Question about Vacuums
How to fix hose on samsung vacuum#9068g quietstorm
It is broke where it enters the cleaner
4 Suggested Answers
  • 78 Answers
SOURCE: replace an external hose to a D07 vacuum cleaner
remove the handle from the body of the unit slide the handle all the way out there is a small button on the plastic coller press it in and pull the handle free lay the hose on the floor and at the base of the hose there is a hook put one finger under the hook and just between the hose and the body you will see a clip that is locked into the body put your thumb on the clip pull it towards you and as you do this lift the hook and the hose coller will come out it can be hard to get it out so take your time
Posted on Oct 20, 2009
  • 313 Answers
SOURCE: vacuum cleaner shut off if you try to use the hose or off beater
With the cleaner on. move the cable where it enters the cleaner through a rubber grommet. There is a common fault with these cleaners that the cable breaks at that point. soon the cleaner wont work at all until it is rewired.
Posted on Jul 25, 2010
Daniel S
  • 4323 Answers
SOURCE: Kenmore Model 116 28014700 intuition
Hi
To remove the broken part from the latch use a small screwdriver to release the tabs on the latch on the connector. When latches are released the latch assembly and the plate will slide out of the connector. When the plate is removed the adapter and hose will slide off the connector. Release the tabs that hold the hose to the adapter and put the hose on the new adapter.
You need to position the terminal plate inside the adapter before sliding the adapter and hose on the new connector. The latch and terminal plate have to slide under the small guides on the connector. Its reverse of removal. Please check the pictures in the below link, it may help---
Link 1
Link 2
Link 3
Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 06, 2011
Doesn't suck
Vacuum Cleaner Repair Help
How to Fix Vacuum Cleaner
How to Fix Vacuum That Lost Suction
If there's ample suction but the machine won't pick up material, check the hose for blockages. Disconnect the hose from the vacuum cleaner and inspect it for any cracks or holes. If any are found, use duct tape to repair them - it might not look great, but it does the job! Where there's a blockage in the vacuum cleaner, clean it out by pushing a long, thin object like a broom handle through the entire length of thre hose. You can then reconnect the hose and try the vacuum again. It's worth checking the hoses a few times every year for cracks or splits.
If everything else appears to be fine but the vacuum still won't pick up, take a look at the brushes. Turn the vacuum cleaner upside down and clean hair and other material from the brushes, especially at the sides.
How to Troubleshoot Vacuum Cleaner DoItYourself com
Jul 24, 2015 | Dyson Ball DC24 Bagless Upright Vacuum
Brush won't turn
sounds like ya belt is broke.
Feb 15, 2013 | Carpet Pro Commercial CPU-2T Vacuum...
The tools hose on a bissel powerbrush carpet cleaner leaks
Sorry to hear you are having issues with your BISSELL deep cleaner. Your upholstery hose should not leak when used. There is a small o-ring on the end of the hose that may be missing, or if the tool is cracked it could leak. A service center could better help you identify the problem. Here is a link to find your nearest BISSELL Authorized Service Center: http://www.bissell.com/service-centers/?zip=Enter%20your%20zip%20code&distance=50&cid=ccsocial
Sep 25, 2012 | Bissell Carpet Cleaner Powerbrush Deep...
I have a Samsung 4320 vacuum cleaner which has started making a loud blowing noise as if the hose is split. I can't find a split in the hose and it isn't blocked. Also it isn't picking up very well. ...
Most vacuums have an air duct on the hose to adjust the amount of suction. If this becomes opened, you will hear the sound you've described and the suction will lessen. Check the wand and the hose and see if you notice a sliding piece that can be moved to enlarge or decrease an opening in the wand or hose. Use this to close the opening and your machine should work as it's supposed to.
Hope this helps and good luck!
Mar 07, 2011 | Samsung Easy 1300 Lightweight Compact...
Vacuum cleaner shut off if you try to use the hose or off beater
Jul 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a 9068G and when I plug into the electrical outlet and press the "on" lever, I get nothing. The machine actually quit one time while I was vacuuming. Is there a fuse problem or a reset button? ...
There is no reset button or fuse, yo have a clog / reduced air flow, causing the motor to over heat and turn off. First change the bag, then remove the wands and carpet tool from the vacuum. See if the machine turns on. If not the main motor will need to be replaced. If it turns on and you have suction, check the wands or carpet tool for a clog.
Apr 16, 2010 | Samsung Quiet Storm 9069 Vacuum
Bissell Pro-heat 2x model 8920
There is probably a bad solenoid in the machine that controls the water out to the floor, you would be better off taking it to a repair place because it is a big mess of hoses and wires.
Jun 29, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Samsung SC8571 VACUUM CLEANER
Either check your local region of EBAY for any vacuum cleaner repair specialists who may be able to sell you a replacement hose/parts OR enter your postcode in Australia for this Samsung customer service:
Dont forget to rate.
http://www.samsung.com/au/support/repairlocation/ServiceLocationsMain.do
Jun 13, 2008 | Samsung Vacuums
Vacuums Logo
32 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
