Question about Health & Beauty
Shaver make a grinding noise
When turned on, shave makes a grinding noise in blade area. have cleaned heads. need to take whole shaver apart and clean.
MsCtrl
  • 6 Answers
SOURCE: Shaver head warning light
Here is a link to the owners manual for the HQ7785 Electric Shaver. If this is the wrong model, your manual may be listed at this site as well.
http://personalcare.owneriq.net/manuals/mfg/philips/hq7740.html
Posted on Apr 16, 2009
brector3
  • 1610 Answers
SOURCE: How to lubricate Norelco 3405 shaver?
The sewing machine oil should work fine.
This model has 4 screws on the back. You must push up the trimmer to see two of those but the other two are in plain view. Remove screws with a flat jewelers screwdriver or you can purchase a special removal tool from shaveroutlet.com here:
http://shaveroutlet.com/screwdriver-access-tool-for-norelco-shavers-and-some-braun-p-262.html
Once the back cover is removed, you will be able to see the motor. It is attached to the gear housing by two metal clips. Remove the clips and you can lift the motor out. Apply a couple of drops of your oil to the pinion gear on the 'front' of the moto and a drop to the small indentation on the back of the motor.
If you still have noise. you will need to lubricate the gears. Temove the gear housing by removing the 2 screws that are on either side of the motor. The gear housing will then come off. The front and back of the housing are held together by plastic snaps on the three corners. Gently pry them apart to seperate and reveal the gears inside. Lift the gears out and apply a light form of grease to where the gears fit onto the back of the gear housing. Vaseline should work well if you have nothing else.
Reassemble in reverse order and it should run very quiet when you're done
Posted on Jan 26, 2010
SOURCE: I took my shaver apart to clean it. i put it back
THERE IS A SMALL PLASTIC CLIP THAT GOES BEHIND THE BLADE PART, LOOKS LIKE A VERY SMALL "U" LONG AND FLAT. HAD THE SAME PROBLEM, FOUND AND RE-INSALLED THE CLIP AND BINGO
Posted on Feb 15, 2010
brector3
  • 1610 Answers
SOURCE: I have a norelco arcitec 1050 shaver. I can't
See link below for user manual. Everything you need to know is in the manual.
http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
Posted on Feb 22, 2010
Testimonial: "thanks for the response to my question. the information that was given helped tremendously. "
brector3
  • 1610 Answers
SOURCE: During shaving the shaver makes
Most likely, the noise is caused by vibration of a broken piece of plastic in the swivel fframe. If this is the case, the part required to fix it for model 8585 can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-8000-series-activator-motor-drive-unit-p-36.html
You will also find an instructional video for disassembly at the link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
Posted on Dec 10, 2010
Tip
How to use an electric shaver
If you are a using an electric shaver for the first time, I hope that this article will get you going. Proper techniques will ensure the best, closest shave possible. Maintaining the razor by properly cleaning and recharging it will also ensure that the razor works correctly and does not malfunction during use. Proper care and maintenance of the electric razor will also ensure that the razor will last for years to come. Consider this article as a shaving-best-practices template for your first electric shaver.<br /> <br /> Firstly, clean your face and dry it. Electric shavers do a better job when your face is clean. Turn the electric razor on and begin shaving against the direction of hair growth, moving the shaving head linearly and in circles. Circular motion Stretch the skin with your other hand to make the hair stand up straighter so the razor blades shave closer.<br /> <br /> After shaving, turn it off and rinse the cutting heads under warm water. You can also use jet clean system once a week to clean your shaver. Make sure that you charge it for the time specified in user manual. Overcharging may cause damage to the battery.
on Mar 03, 2011 | Health & Beauty
Replacement blades
You will find blades for model 3405LC at shaveroutlet.com using the link below
http://shaveroutlet.com/norelco-philips-hq56-super-lift-and-cut-replacement-heads-p-249.html
Jun 23, 2014 | Norelco 3405 LC Electric Shaver
The norelco shaver i have does not shave
If the shaver is running ok but does not shave well, the blades either need cleaned or replaced.
You will find replacements for 8175XL model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq9-replacement-heads-p-252.html
Scroll down the page for tutorial video showing how to remove blades for cleaning or installation
Oct 07, 2011 | Philips Norelco 8175XL Electric Shaver
How can I clean my braun washable series 3 (330) shaver. better. I can take it apart so far but just cant get under the blades
This model uses a 'shaving cassette'. The blades can not be removed from the foil assembly. Braun's instruction is to simply rense the shaving head under hot running tap water. Unfortunately, this does not work very well over time due to the poor design of these parts. Once they become clogged up it is usually necessary to replace the cartridge.
If replacement is needed you will find one at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-series-3-shaver-foil-and-cutter-head-cassette-32s32b-p-835.html
Jul 27, 2011 | Health & Beauty
My shaving head came apart and I can not re assemble it, kindly give me instructions
Wife cleaned bathroom shelf dropping the Arcitec. One of 3 heads was not aligned properly, when I tried to re-seat it, this head came apart. To put it back together takes some finesse and patience. Take a coil of stamps, or some other small opening to rest the outer plastic shell head, then insert the metal screen which has notches (2 small, 1 large) and fit it in the plastic shell head. Next put the metal blade assembly on the screen. Next align this on the metal (thin) pivot. When the outer plastic head, and the metal pivot are aligned (small peg holes), you can place the thin inner plastic piece on and gently press your sub assembly and the backing plastic together, It will snap together and hold. Don't FORCE it, the holes must be aligned on the outer plastic, the metal pivot frame, with blades resting on the screen. It does snap together. Work with fairly bright light to see what you are doing. If this fails, invest in a new head assembly for about 15% of the cost of the whole razor.
Jun 10, 2011 | Norelco Arcitec Electric Shaver -...
I just purchased a Panasonic Arc IV nanotech wet/dry shaver. I've been using it in the shower, and it's very effective. However, I'm wondering if I'm using it correctly. The shaver's manual says it should...
You did not include the specific model number written on your shaver but I will try to address your questions the best I can without it.
Most likely, your shaver came with a cleaning station and charging station. The cleaning light would tell you it is time to use the cleaning station. After each shave, you should dump out the shavings and rinse under the tap. You should let the shaver dry without the cap on.
ShaverOutlet com ShaverOutlet com Shaver Replacement Parts Manufacturer...
Mar 27, 2017 | Panasonic Es8243a Arc Iv Nano Electric...
Shaver blades get stuck the moment I switch it on. The battery is fully charged.
For sure there is dirt or bits of hairr strcuk into the blades that make is non fucntioning. It is important that after every shave you must clean the blades with the brush that comes along with the shaver. Now use the brush to clean, use some good light oil on the blades to make it free. Now let it run for a while. Use a tthin cloth to dry off the dirt. Now repeat the oil on the blades and use .
Your shaving should be perfect now .
Sep 21, 2010 | Norelco 7886XL Electric Shaver
My Braun 7680 says "Oil"
Don't use vegetable oil on it. It will totally gum up. Get some shaver oil or sewing machine oil. Clean the shaver and put 1 drop of oil on your finger tip. With the shaver turned on, rub your finger over the shaving head. This will allow the oil to wick into the cutting area.
Oct 20, 2009 | Braun 7000 Series Foil and Cutterblock
Plastic retainer for the shaving blades is broken
You can buy a replacement shaver head and screens from an Oklahoma shaver business, electric shaver company.
Here's a link to their site and the page for the Norelco shaver you're looking to get parts for. The 3rd item down is the shaver head and screens, blades, etc.
I don't think you can get just the plastic retainer all by itself, as the manufacturer makes a complete head and blade as a replacement set, however, you can call them to see if they have just the retainer part you need. But frankly, it's likely a good idea to change shaver heads every so often to get the best shave, etc., so you might just want to spring for the complete replacement assembly part #HQ9 on this site for under $40.00.
http://www.electricshaverstore.com/get_list_143.htm
Hope you find this Very Helpful and best regards!
Sep 22, 2009 | Norelco Replacement Razor Heads for ...
Health & Beauty Logo
159 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
