Question about LG Televison & Video
Tv does not show picture until 30 minutes to over an hour???
    Top Expert:
  • LG Master
  • 75,581 Answers
What is the exact model number?
Posted on Oct 31, 2012
  • Bill Myers
    Bill Myers Oct 31, 2012
    37LCD-UABAUSLLJM
  • The Knight
    The Knight Oct 31, 2012
    Sorry. I haven't heard about this Brand TVs so far.
robwan
  • 20 Answers
SOURCE: Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Posted on Nov 01, 2008
bluenadas
  • 203 Answers
SOURCE: Philips 42PFL3603 tv sound but no picture.
Hold a flash light to the screen after it goes off and see if you can see a faint picture. Sounds like your backlight might be cutting off. Repair can be expensive but some of the newer units don't require the entire LCD to be replaced.
Posted on Sep 27, 2009
ginko
  • 19396 Answers
SOURCE: The picture on my Panasonic
Hi.
Bad looking capacitors?
If the picture goes off, but the TV keeps having sound, then what is failing is usually either horizonthal or vertical deflection circuit, flyback, or high voltage multiplier. PSU may be responsible, but that is not the first possible culprit. Other faults like the AV tuner, or terminal input, are also possible but quite uncommon.
Repair is done replacing horizintal output transistor or IC, checking flyback transformer solder joints and windings, testing voltage out from PSU.
The most common fault causing the problem to go and come back after cooling is horizontal or vertical IC. Repair is done desoldering old IC and soldering new one with coolant paste. The soldering joints in deflection area, yoke and flyback must also be tested. As said, PSU is not really common fault causing this, let alone the capacitor thing.
The repair starts at about $100 (£80 in UK), and can go up in price, depending on the problems encountered by the tech. Repairing deflection problems in old CRT TVs is generally not worth anymore nowadays.
If you repute my solution helpful, then please take some times to accept the solution. Providing good repair tips requires time and skills, and your feedback is important for us.
Regards.
Ginko.
Posted on Oct 19, 2010
gopakumarg43
  • 75581 Answers
SOURCE: 19' flat screen TV slow
Hello
You haven't specified the Brand or Model number of your flat panel tv. Yet I'm answering to this enquiry, assuming that yours' is an ordinary 19" flat screen TV.
For most the TVs, this fault will be due to the base socket of the picure tube. You can locate this socket at the picture tube base card, directly soldered to it. This socket is otherwise commercially known as picture tube base. It connects the picture tube pins to the rest of the circuit, and can be detached from the base of the picture tube by a light backward pull.
You just open your TV and pull out the base card from the picture tube neck. Care should be taken not to shake the board sideways or up and down movement, as this may damage the pins of the picture tube, or can cause a crack in picture tube neck. The neck of the picture tube is very thin, relateve to other part of it, and have a chance to break easly. So be very carefull when detach the board out of it.
Resolder the base socket out of it, detach the Focus wire attached, in some cases, there will be an other wire too, screen voltage wire. Go for a same type and pin confuguration. You can select whichever companys product; provided the pin confuguration. The material used to manufacture it is very important. It should be of good quality; otherwise the fault will occur within a short period of time again.
If you wants any more assistance, get me through Fixya. Ok.
Posted on Nov 25, 2010
SOURCE: When you first turn on the tv the picture is
the picture tube is the problem of your TV so i think you have to go to the electronic technician to solved the problem of your TV because you cant solve it by your own.. your TV needs professional electronic technician..
Posted on Aug 29, 2011
My tv turns off after about 10 mins and sometimes a few hours for know reason
Ok not sure if this is your problem, BUT, I have done this before! If you hit the SLEEP button on your TV's Remote control you may be setting the SLEEP TIMER on your TV. It is made so you can watch a show and fall asleep on your couch and the TV will shut off after a specified time. On mine it is anywhere from 30 minutes to 3 HOURS! My remote says the word SLEEP over the timer button. not sure on yours
Hope that solves the problem, just hit the button until the word "OFF" shows on your screen.
Feb 27, 2011 | Televison & Video
Tv takes forever to turn on sharp television LC-32SB23U
This problems very common with sharp tv.The Main Turner Signal board have problems.Keep using it,when it stop and completely dead 20-30 on-off no backlight show up and picture.U know ur Tuner board signal board is dead, have to replaced it.
Jan 06, 2010 | Sharp LC-32SB23U 32 in. LCD TV
Plasma "warm up" is now up to 30 minutes and climbing
put a towel across the top of the tv so it can heat up faster and you will get your picture. be carefull!!
Jan 26, 2009 | Televison & Video
Nov 01, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
DLP tv trouble shooting
Try and clean the filters or the plastic fan guards.
Jul 30, 2008 | Home Security
Hi.
Yes it could be a cooling problem, If your tv has any filters remove & clean them ensure fan can turn freely & that nothing can or is snagging it.
http://dysonmanuals.inc.io/
Chris.
Nov 09, 2007 | Televison & Video
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Toshiba 42H81 - Constant jumping picture on scren
it needs the hyper module replaced might as well have em do the stk packs too its too old to be a lemon the part that was replaced was not new it was in someone elses tv and had problems there too the trick is to find someone that will fix it so it lasts
Dec 05, 2006 | Toshiba 42H81 42" Rear Projection...
Televison & Video Logo
26 people viewed this question
