Question about Bosch MUM6630 Universal Series Stand Mixer
Bosch universal mixer
My mixer was working fine until I tried to mix the frosting without letting it come to room temp (after it had been in the fridgerator). I have 2 bowls: The one with the frosting in it that was forced- The bolt on the bowl now moves freely (spins around). I then got out the other working bowl. I started making cookies. At first it was ok whipping eggs and a little sugar. Then when I got a heavy load of dough, the bowl began to spin too. Any help will be greatly appreciated,I love my mixer. Thanks, Nancy
Sounds like the belt came off when you tried to mix the frosting while it was cold. Just too much of a load. It will have to be taken apart and the belt put back on.
Posted on Aug 29, 2008
Never used new bosch universal plus making bread started rattling sound
I do not know a lot about this machine. I am a DIY fix anything. It sounds like one of the mounting points on either the motor or the gearing gave way. Regardless it is new, send it back & have it fixed or replaced. Sorry, I know that is not what you wanted to hear, but is safest considering your investment.
Mar 10, 2014 | Bosch Universal Plus 6 Qt Mixer With 800W...
Kitchenaid Mixer Planetary becomes sluggish when met with resistance.
The problem will be with the worm gear, if the gear is not stripped then check that the locating pin for the worm gear is not broken or missing. Occasionally the plastic gear can detach from the aluminium boss between plastic and shaft. The worm gear is the 99.9% place where drive can slip. Afterthought, I suppose the planetary pin is not missing or broken??
Jun 28, 2013 | KitchenAid KSM150PS Artisan Series Stand...
Black and Decker Spatula Smart Hand Mixer
1990? Dump it and purchase a new one
Mar 17, 2017 | Food Mixers
The mixer simply doesn't turn on. Worked fine yesterday. Today it seems like it's just dead
HI.Let me jusk ask if yiou also tried to connet to another socket.Let me just clarify that the motor itself did not work /rotate as well.Prior to that situation,have you tried to mix more than what is the capacity of your mixer.If possible motor was overworked/that's why its coil was burnt.There. are possibilities then. First might be that the mixers terminals inside will no longer engaged properly that's why it opens the circuit.Second the motor isn't working because the rotor and armatures coil was burnt because it runs beyond its maximum wattage capacity that's why it draws much current beyond the rotors coil capacity.Did you mixed something heavy.the motor works heavier the last time you used the unit?
Jul 23, 2011 | KitchenAid KSM150PS Artisan Series Stand...
My mixing bowl seems to be locked onto my Bosch Universal machine, cannot get it off. Anybody have a solution. I've tried turning it, using a crow bar, etc. the drive shaft still turns but bowl is "...
I had (have) the same problem with mine. It would stick occasionally and then one day it wouldn't come off at all. The bowl would unlock and turn like it should but wouldn't lift off. After much time and effort I did manage to get it off and found that the splines on the shaft were scored. When I examined the receiver part, the lugs (splines?) on it were worn allowing the shaft lugs (splines) to overlap the base lugs and thus becoming jammed.
I cleaned everything completely and made a batch of bread dough and it's stuck again.
I think the base receiver needs replaced but it may be part of the transmission and maybe the whole thing needs replaced, I don't know.
I sent an email and left a message with Bosch service and will post again when I hear from them.
I have used the mixer for about 4 years and love it but this problem shouldn't happen I don't think. It seems like a design flaw to me.
Dec 15, 2009 | Bosch MUM6610 Universal Series Stand Mixer
My mixer just started smoking while i was mix some
Your mixer may still be good, let it cool down and then check it out, If it runs OK then there is no problem. The motor in your mixer probably over heated from trying to mix bread dough which will make any mixer work hard. These mixers will get warm when over worked but unless heavy smoke was coming out and you were getting a burning enamel smell it is probably OK. Let it cool and try it but I suggest you not use it for bread any more.
Oct 08, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Where can I buy a Bosch hand mixer, it comes in a pack with a separate mixing bowl . I bought one years ago but it has only just ceased working.
No I havent found a dealer because Bosch no longer make the hand mixer. I cant afford to pay anyone to help me find an outlet for the Bosch mixers.
Sep 14, 2009 | Bosch Food Mixers
Bosch MUM6630 Universal Series Stand Mixer Logo
571 people viewed this question
Top Bosch Food Mixers Experts
Paul Bade
Marvin
Marvin
Are you a Bosch Food Mixer Expert? Answer questions, earn points and help others
