How to fix toner low on Brother Intellifax 2820
  • 673 Answers
You need to replace with a new toner or refill the existing one.
Posted on Oct 30, 2012
  • 120 Answers
SOURCE: brother 2820 Says clear scanner jam and press stop
Make sure there is nothing caught where the documents go it. List up the scanner cover and look inside. It may need a separator pad or clean the feed rollers with some alcohol. Lawrence
Posted on Apr 23, 2008
leroyal
  • 2120 Answers
SOURCE: Factory Default Settings
Press Menu * 2864 (within 2 seconds) [MAINTENANCE MODE] press 01 (INITIALIZE)
Posted on Oct 07, 2008
leroyal
  • 2120 Answers
SOURCE: scanning with brother intellifax 2820
If it has a Centronic Port (printer) or a RJ45 port (network) the answer is yes.
You will need the scanning software, if you don't have it on CD from www.brother.com
Posted on Oct 15, 2008
  • 215 Answers
SOURCE: change toner error brother 2820 mach has new brother toner ctg
with machine on, open front cover, press the "options" button, you should see "replace drum?" press the "start" key then 1 then 0. display should show accepted for a couple of secs. then show cover open. close front cover and message should be gone. if not, you will have to contact Brother.
hth,
razors
Posted on Jan 28, 2009
  • 37 Answers
SOURCE: Time Change on Brother 2820
1.Press menu
2.Press 0
3.Press 2
4.Enter the last two digits of the year on the
dial pad, and then press Set.
5.Enter the two digits for the month on the dial
6.Enter the two digits for the day on the dial
7.Enter the time in 24-hour format on the dial
8.Press Stop/Exit.
Posted on Mar 02, 2009
I have a Brother fax and copy machine and have just replaced toner with a brother TN 350 cartridge and still getting message that toner is low
You didn't include the model, but here are instructions for the Fax-2820; it should work for any of the models that use the TN-350 toner:
  1. With the power on, open the front cover.
  2. Press the Options key. The display will read "Change Drum?"
  3. Press Start.
  4. Press 1 0.
  5. The display reads "Accepted" for about 2 seconds, then change to "Cover Open."
  6. Close cover. The "Replace toner" message should be cleared.
Normally, inserting a new cartridge (with the power on) will reset the toner counter, and you won't have to do any of this.
Dec 21, 2009 | Brother IntelliFax-2820 Laser Fax
Said low toner cartridge. Replaced cartridge,
what is showing toner life end ? rajcanon007@yahoo.co.in
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Brother Intellifax 2820 I keep getting a end toner life message after replacing cartridge
Make sure the machine is not in direct sunlight as the toner end sensor is photo-optic. If it's an after market toner or refill...good luck with that. Lastly remove the toner tap on top of it and shake it from side to side and reinstall. The toner may be caked up inside,
Jul 13, 2009 | Brother IntelliFax-2820 Laser Fax
Low toner msg stay on
open front cover, press "options" button & press "start" then enter "1" then "0". when display shows accepted, close cover.
hth,
razors
Feb 18, 2009 | Brother IntelliFax-2820 Laser Fax
Change toner error brother 2820 mach has new brother toner ctg
hth,
razors
Jan 23, 2009 | Brother IntelliFax-2820 Laser Fax
Put in brand new toner machines says toner is low.
plull the drum out...and clean the roller....you will be able to see the ink on the roller where your lines are appearing.
Jan 13, 2009 | Brother IntelliFax-2820 Laser Fax
Brother 2820
The toner cartridge is in the drum unit. push the blue lever and the toner pops out, make sure you have a toner cartridge in the drum unit. Lawrence
Apr 23, 2008 | Brother IntelliFax-2820 Laser Fax
Low toner
No what u have is that you need to also replace the Drum. That is why the light is reading low toner still.
Feb 13, 2008 | Brother IntelliFax-2820 Laser Fax
13 people viewed this question
jasbo
jasbo
