Question about Dryers
Dryer not heating
I have a maytag neptune front loading dryer and it is not heating
  • tagama2 Jan 04, 2009
    I have the same problem! My dryer turns on, spins and blow cold air. What can I do to fix this?
  • tagama2 May 11, 2010
    I opened the front panel but where exactly is the ignitor?
  • 91 Answers
Remove front panel and inspect ignitor if has small white burn mark then replace burnt out
Posted on Jan 04, 2009
Maytag neptune stacked MLG2000AWW wont heat
It's either the fuse, heating element, thermal cut-off or thermostat
May 20, 2012 | Maytag Neptune MLG2000A Front Load Stacked...
Have a neptune front load dryer heat does not work either does the lights on the control panel. heat works for a second but panel where time and
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 09, 2010 | Maytag Neptune MDE6700A Electric Dryer
Maytag gas dryer will not heat
heatman101
Jul 06, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My maytag front load dryer turns on and runs,it does not blow any hot air
Make sure front of dryer is not blocked, air flow is needed to dry.Check that the lint filter and exhaust duct is clean.
Check the blown fuses and home’s circuit breaker tripped. Dryer use 2 household Fuses or a circuit breakers, Replace the Fuses or reset the circuit breaker.
Another common cause of a dryer failing to heat is a faulty Heating Element. You will need to replace it.
Good Luck and have a nice day.
Jul 01, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer not geting hot
If your Dryer is the Electric version, then more than likely you have a burned out heating element, you can check it by first UNPLUGGING THE DRYER!!! after you have UNPLUGGED THE DRYER!!!, you can remove the front cover and check the element for continuity, the whole unit comes out as a Tube.
May 31, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My maytag dryer is not staying hot to dry clothes
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Maytag Neptune MDG9700A Gas Dryer
Maytag Neptune Dryer Won't Heat up
these particular dryers have issues with the heat coils,
it probably has a bad element
Sep 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
No heat in dryer
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
98uit
Feb 05, 2009 | Maytag Neptune MLE2000A Front Load Stacked...
Dryer Drum Wont Rotate
did you check to see if the belt was not broke? if not possibly the motor went out.hope this helps
Dec 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
NEPTUNE FRONT LOAD GAS DRYER
1st.Look for glow from the igniter,are you getting power to the igniter?If you are getting power,and its not glowing replace the igniter.If your not getting power to the igniter replace the thermal fuse.
Jun 02, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryers Logo
127 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
