Question about Toshiba Portege R100 Notebook
F10 is on and it does not go of
The problem rises and sometimes cuts ut
  • max carson
    max carson Oct 30, 2012
    f10 is on and it does not go of? Could you clarifiy?
I have a sportsman 500 "08" Sometimes when I put it in fourwheel drive it kills the engine and all power. I can ut it back into 4X2 and it is fine
either a severely shorted out wire, or the 4x4 shaft, or chain, is bad. you may also consider checking the 4x4 hubs to make sure that they are not locked up tight
Mar 17, 2013 | Garden
F10 err resulting in beeping
The F10 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F10 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
GENE
Oct 02, 2011 | Frigidaire FES367 Electric Kitchen Range
2004 Honda S-2000 passenger window won't rise Child lock not on and it's not the fuses. Neither of the 2 swithces make it rise. Is it the motor? Should I remove the door switches? Yesterday it was...
Possibly the wires at the drivers door where they go into the body,sometimes from the door
being opened more than the rest ,the wires will break there.
Should be able to cut a **** in the rubber boot that covers them and look for a broken wire.
If they break at the drivers door neither switch will work.
Sep 06, 2011 | Honda S2000 Cars & Trucks
2002 Jeep liberty headlights cut off and then back on at random times. weather makes no difference nor hot or cold. went a way for a few months and now it has started all over again. hear clicking sound...
the clicking your hearing is the relay trying to stay engaged, its heating up causing the relay to power down, which in turn you lose the lights, the heat is caused by the electrical current supplied to the replay, Not the outside temp , locate that relay and replace it, and your problem should be gone
Aug 10, 2011 | 2002 Jeep Liberty
My yamaha 250f will crank right up then as im riding it, ut will cut off while in on the trail. sometimes it wont crank back up and have trouble strating it up..how do i fixs this????
Need more info on this one - how long do you get before it dies or is it dieing fist few minutes does restart again once engine cold (ie next day) is it regular does it do this every ride or has just happened couple of times lately is it running well then dies or is progressively running bad then stops
May 20, 2011 | Yamaha Fuoco 500 Motorcycles
I am unable to get dishwasher started it is brand new nevver been used is turning on b ut will not start the was cycle
if its connected to waste under the sink check that the blanking plug has been taken out from under drain spigot or the end cut off if that type . on the tap sometimes the handle spins on the shaft although you think its turned on it may still be off.
Aug 03, 2010 | Zanussi 24 in. DA6153 Free-standing...
Temp gauge will rise quickly then instantly pin in red and oil light comes on. Continue driving, after couple of minutes it will go down. The rise quickly and do it again, sometimes causes overheat sensor...
If this truck is not overheating, then I would suspect the temperature sensor, if it is overheating then this must be repaired first. The sensor should be mounted in the intake manifold. Hope this helps, let me know
Jan 23, 2010 | 1999 Ford Expedition
Toshiba Portege R100 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
