Question about Zebra GX430t Thermal Printer
Problems printing to a zebra printer with windows driver and ZPL?
Windows print is overriding the print width setting and the printer is saving this setting. The ZPL label format is based off the maximum print width for the printer. And this print is being thrown off because the maximum print width has been changed by the windows print. What can I do to reset the maximum print width after the windows print? How can I set the printer to not save the settings from the windows driver?
3 Suggested Answers
  • 254 Answers
SOURCE: Changes from 1 to 3 pages for Excel Print Area
verify the page dimension in your driver together with the header and footer dimensions
Posted on Sep 03, 2009
  • 44 Answers
SOURCE: Using MS Access, I am
First check printer. Change setting "Print Width" to maximum width, save. Switch off. Hold down pause key while switching on (untill all but power light turns off). the subsequent prints should print across the full width. If this is OK fault is with label format.
If you are using windows printer driver check settings there this can over ride printer settings. If using ZPL the problem is most likely in the label format.
Posted on Jul 07, 2011
Hi Dear All, My printer is not printing ZPL
Only Zebra printers use and print ZPL. ZPL =Zebra Programming Language. Other printers cannot intrepret ZPL.
Aug 13, 2013 | Zebra RW220 PRINTER 2" DT RUGGED MOBILE...
Hi , I have a problem with zebra 105sl printer , everytime i print somthing i have to make changes to the settings , eg. make it darker .When i save the settings permenent next time i go tto print i have...
The settings in the printer driver are overriding the saved printer settings.
Do this:
1. Correct the printer settings and save them permanently.
2. Print saved configuration for future reference and to see if it changes.(Power on while holding cancel)
3. Print a label from computer.
4. Print configuration again (Power on while holding cancel).
5. Compare the 1st and 2nd printouts. If they are different then the printer driver is changing the printer settings. In other words the printer settings and the driver are different and the driver settings will override the printer settings before printing.
6. Change the driver settings and this won't happen. Increase the darkness setting in the driver.
Aug 13, 2011 | Zebra 105SL Thermal Label Printer
Using MS Access, I am printing labels to a Zebra 110XiIII printer. The output truncates the label to 2" instead of the 3.5" I have the report page settings saved as. I have been through the setup...
Jul 05, 2011 | Zebra 110XIIII Thermal Label Printer
Can we make 300 dpi Zebra 105 SL printer to print on label expecting 203 DPI, Any configuration setting?
Krishan, sorry there are no settings that will allow you to do this on the 105SL. If the printer code expecting a 203 DPI printhead and you have a 300 DPI Printer then your label will print out much smaller then normal.
If you are printing labels with a label printing package (such as Seagull Bartender for Windows) then all you need to do is to install the proper printer driver. If you have your printer attached to a system that is sending "straight" ZPL (Zebra Printing Language Code) then your out of luck.
Hope this helps
Mikeo@acebarcode.com
Feb 28, 2011 | Zebra 105SL Thermal Label Printer
Zebra TLP 2844 does not print anything.Not even paintbrush (print) is not doing anything.I have tried everything an programmer could think of. All that it does it spews out some empty labels. IT IS NOT A...
Are you trying to program in ZPL? if you are then you don't need a driver, send the code directly to the port and it will print. I would firstly reset the defaults to make sure there are no corruptions in the settings. Just in case you not sure, press and hold the feed button, the green light will flash 1 then 2 etc on the 4th flash let the button go and it will calibrate and reset to the factory defaults.
Mar 16, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Printing on a continous teffeta label using zebra S4M zpl printer
Con un windows driver, sí imprime? Intenta reiniciar la impresora con los parametros de fabrica. La impresora tiene zpl o epl firmware?
Roberto Martinez
Jun 30, 2009 | Zebra S4M Thermal Label Printer
Only printing 1/2 a label
recalibrate the printer in the set up.
Don't just do a quick cal from the front panel.
Make sure your driver is the correct dpi zebra driver, either zebra or my preferred seagull scientific.
by .5 of the label, do you mean width or heigth.
If it is heigth, check to make sure you are set for top of print correctly. Also you will have to back feed for a label that short.
Feb 24, 2009 | Zebra 110Xi III Plus Thermal Printer
Not printing the correct text / picture
Hi..
Try using used generic text printer driver instead of windows driver for that model.or in the SAP environment try to used other driver..
Sep 18, 2008 | Zebra Stripe S600 Thermal Label Printer
140XiIII left side print right side completely blank
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
Jun 30, 2007 | Zebra 140XiIII Plus Thermal Label Printer
Zebra GX430t Thermal Printer Logo
141 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
