Question about Stanley Office Equipment & Supplies
How do you put the staples in this stapler - Stanley Office Equipment & Supplies
  • 673 Answers
1. Hold the black handle -- top part -- of the stapler with your right hand thumb and forefinger.
2. Hold the metal casing right beneath the black handle, with your left hand thumb and forefinger.
3. Use your left hand thumb and forefingers and a wedge to separate the top black part and the metal casing beneath it.
4. Done!!!
Posted on Oct 30, 2012
5 Suggested Answers
SOURCE: I can't seem to reload
With the stapler sitting a solid surface, turn it 180 degrees so it is pointed away from you, and you are looking at the back. Press down on the plastic extension that you see (about mid-height on the stapler). This releases the staple-holding compartment (it shoots out the front of the stapler). Reload it with standard staples, push the compartment back in place until you hear a click. Voila!
Posted on Oct 19, 2011
SOURCE: how do put staples in this stapler?
vaduvur.jpg1. Hold the black handle -- top part -- of the stapler with your right hand thumb and forefinger. 2. Hold the metal casing right beneath the black handle, with your left hand thumb and forefinger. 3. Use your left hand thumb and forefingers and a wedge to separate the top black part and the metal casing beneath it. 4. Bingo!
Note: Switching the two different operations on to the other hand is unlikely to work.
Posted on Mar 19, 2011
SOURCE: We have a Swingline 690
I had the same problem with my 690. This is what worked for me.. I simply pulled out the staples from the cartridge a little further than the suggested tear-off point, and the machine was able to start working. Hope this helps!
Posted on May 10, 2011
  • 1583 Answers
SOURCE: how do I make the Optima 20 electic stapler model 48208 work after putting in the staples. I put the paper in as usual and it does not work. I have put the staples in correctly as I normally do, but
Unplug it, take it apart and examine the switch actuator and switch to see why they don't trigger the stapler. There's a good chance you'll find the actuator is broken or jammed by a foreign object, or the switch is worn out. Metal-filled epoxy works well for repairing ABS plastic parts.
Another possibility is a broken power cord. You can test the electrical parts for continuity with an ohmmeter (unplugged, of course!).
Posted on Nov 10, 2011
What can I do to keep the stapler from jamming, and it is also not putting the staples in all the way?
You may be over filling the stapler, also make sure that you are using the correct staples. The fact that they are not going in all the way suggests that they are too long for the stapler. I hope this helps.
May 17, 2016 | Staples Tools & Hardware - Others
How to put back together
Stanley Model TR45 Light Duty Staple Gun Review - YouTube
? 3:35
https://www.youtube.com/watch?v=hWmvXhkqnYI
Jul 25, 2012 - Uploaded by Vansvideoreviews
Stanley Model TR45 Light Duty Staple Gun Review ... How toPut Staples in a Craftsman Stapler (Model 968447) ... Stanley SharpShooter Manual Staple and Brad Gun review - Duration: 9:35. by Unpack Guy 35,948 views.
How to load staples into a Stanley Stapler - YouTube
? 2:11
https://www.youtube.com/watch?v=j4Q5W0uKS-s
Mar 26, 2013 - Uploaded by David DeStefano
This video shows you how to load staples into a Stanley StaplerModel # TR110. ... Stanley SharpShooter Manual Staple and Brad Gun review ...
put stanley sharpshooter staple gun back together ... - Fixya
www.fixya.com > Forum > Tags
Find solutions to your put stanley sharpshooter staple gun back together question. ... staples for the TRE500 Stanley Sharpshooter Electric Heavy Duty Stapler.
Dec 10, 2015 | Stanley SHARPSHOOTER HEAVY-DUTY STAPLE GUN
How do I reload staplers?
There are two basic designs of staplers. The most common type is the Swingline or Stanley Bowstitch types. At the business end of the stapler there is a small catch that you need to pull rearward and the front staple head will drop down. Inside, you will see a metal bar and a spring. Pull the spring back towards the rear of the stapler and insert a full clip of staples appropriate for your stapler. Release the spring slowly so the metal tab pushes against the staples... should be pointed tips down. Put the stapler on a firm surface and press it as you would when stapling something. The two parts of the stapler head will join back together again.
Apr 02, 2015 | Office Equipment & Supplies
What gage staples do I need for a p300 ryobi air stapler?
Good morning Victoria,
The staple series that you'll need is probably need is a 90 series. These are again an 18gauge wire in several different lengths.
Regards
collatedfasteners
Jul 05, 2014 | Ryobi P300 One+ Stapler Brad Nailer
Help please! I have a Paper Pro high capacity stapler that will not staple. I can open it up and put staples inside, but no staple will come out when pushed down. Oddly enough, if I put ONE staple inside...
are you using the correct size of staple?? (thickness wise) secondly check the spring is pushing as it should, also a fix to get it working is as you put the staple stack into the stapler, seperate them and see if will staple. other than that it's defective and you should purchase a new one.
Oct 30, 2013 | Staples PaperPro 1200: Heavy Duty Stapler
I have a stanley heavy duty stapler TC110. When I put my staples in, they don't seem to be catching. There is some black part sticking out of the end where the staples should come out. It looks like...
The staples load on the underside of the stapler.
Step 1 Push down and retract the stapler pushup mechanism.
Step 2 Position the stapler so that the moving hammer handle is down
and the staple exit is up
Step 3 Load the staples into the chamber on the bottom with the points up.
Step 4 Push the pushup mechanism into the locked position until it latches, you will feel the spring resistance as the staples are pushed into place.
Sep 04, 2011 | Powerfast Stanley TR110 Light-Duty Staple...
Instructions on how to load a swingline heavy duty stapler.
You pull up and back on the stapler head. Then pull out the spring that keeps the staples loaded. Be careful as the spring is very strong. Then put in the staples and put the spring back in behind the staples.
Aug 13, 2010 | Swingline Heavy Duty Stapler 30 160 Sheet...
How to put the staples
depress the handle enough to release the side catch on the stapler. now pull the bottom track down. insert a few rows of staples and snap the track back up into the stapler. the spring loaded follower goes in back of the staple stack.
Oct 20, 2009 | Arrow CHROME STAPLE GUN ARROW IND....
Problem loading gun..Where do we put in the staples and change the dial to accomodate it? fred
The staples should load in through the end of the hammer stapler. The end is spring loaded to push the staples forward, so push the end - usually a crome square - into the handle end then move that part up approximately 1/4 inch and pull back. The spring mechanism should slide out so you can add new staples. These staplers take a specific size of staple and a certain number to allow you to put the spring mechanism back into the stapler. If you do not know the correct size for your stapler someone at your local hardware store can help you find the correct size and they will probably even show you how to load it. Good luck!
Jul 07, 2009 | Ace Hardware Ace Heavy Duty Staple Gun...
Electric stapler won't staple???
hi there. i hope i can help you? what you need to do is open the stapler up check for any stuck staples? where they come out. dont put two many in at any one time. please make sure you are putting the correct staples in? is there a sound when in normal use? if yes it may well be a blockage. also check the fuse in the plug just in case ? i hope this will help you,
May 01, 2009 | Kitchen Appliances - Others
761 people viewed this question
Top Stanley Office Equipment & Supplies Experts
k24674
ray gallant
Tom Chichester
Are you a Stanley Office Equipment and Supply Expert? Answer questions, earn points and help others
