Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony model KP 51w5500 picture blurry
Our Sony TV has a blurry/3D picture, the color seems ok, we have gone into settings and that has not helped. Someone mentioned that the bulbs need replacing but we don't know where to start with that. any ideas?
Mark57
  • 3 Answers
SOURCE: blurry picture
I Just had the same problem with my Sony KP43HT20, was a blury picture with the red & green going bad.......My set had defective convergence IC's, they are known to go in Sony's..IC's run about $30 a piece. Good Luck.
Posted on Nov 26, 2006
  • 301 Answers
SOURCE: replacement lamp/bulb sony kp-61hs10
that model number doesn't use lamps it uses cathode ray tubes projection tubes. the CRTs for that tv are probably no longer available.
Posted on Feb 22, 2008
  • 298 Answers
SOURCE: green bulb for projection tv
This unit uses 3 CRT Tubes (green, red, and blue). There is no LAMP in this unit. In order to get the correct green CRT you will need to contact Andrews Electronics and give them your serial number from the back of your unit.
Posted on Jun 26, 2008
  • 4234 Answers
SOURCE: Sony Trinitron Picture Tube replacement
I think that you will find the picture tube to be more expensive than a replacement TV, if it is still available (unlikely). That being said, it is also unlikely that the tube itself is the problem, The more common problem is the horizontal output transistor or the flyback transformer. Either part should still be available for a reasonable cost. Check with a local servicer for the part numbers and costs. These are common parts.
Dan
Posted on May 19, 2009
Wise Frog
  • 13 Answers
SOURCE: Sony wide screen projection tv model kp-57wv600.
I found this solution from SONY's website.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
I hope this helps.
Posted on Aug 05, 2009
The left half of the picture has gotten blurry, with pink, green outlining what seems like 3 different pictures of the same thing. The left half works fine and the HD of direct TV is good on that side. I...
The tv have a problems known as a tv convergence pictures problems,it is dead.Tv set have any colors lines like R,G,B mis alingnments,have colors shadows pictures or a 3D pictures look alike?Yes,than the tv set convergence board it is dead to causes all these pictures problems.The tv set convergence board must have to be repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv set convergence board to solved the tv set covergence pictures problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 18, 2011 | Sony KP-65WS510 65" Rear Projection...
What causes a blurry screen? and what is the fix?
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 10, 2011 | Sony KP-51WS510 51" Rear Projection...
My picture is blurry and green
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 09, 2011 | Sony KP-51WS500 51" Rear Projection...
I have a red shadow in 3d on sony KP-46WT510 TV.
Ur convergence is dead.Problems:Are 3D colors,colors misaligns,and colors out of focus.Know how to solders?Must change 2 convergence ICS,and some or all the resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Problem with picture on wide sreen TV
You probably need to get a Sony TV Convergence Kit. More information can be found using the link below.
Convergence Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
KP-43170 Sony Projection TV is blurry
Try this site www.my.electronicshelponline.com they have list of free schematic diagrams/service manuals including repair and troubleshooting tips. Good luck. Hope this help.
Jan 26, 2010 | Sony KP-51WS500 51" Rear Projection...
Sony 51" Rear Projection TV is blurry with colored ghost images
Thats caused by a convergence failure. The Sony type 1 convergence repair kit from www.tvrepairworld.com will usually correct that issue the kit contains the components and the CD with repair instructions so you can repair yourself.
Dec 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Picture is blurry, out of color and the letters on tv look like 3D
If you can`t adjust your convergence via the menu then you have a faulty digital and/or analog convergence board
Oct 30, 2009 | Sony KP-53HS10 TV
Blurry tv
there is a focus control in the front of the set behind the front grill there is a door in the middle attached by screws take this off and it should be right behind it. There are six controls on a little box one row says focus and the other says screen don't adjust the screen controls. In some cases these are in the back of the set.
Aug 07, 2009 | Sony KP-65WS500 65" Rear Projection...
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
157 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
