Question about HP Office Equipment & Supplies
When copying the page comes out SOAKED in black ink
Printing function is fine, but when copying, the page comes out solid black. I tried adjusting for light/dark -- same result.
  • 673 Answers
The cartridge or Toner is splitting out more ink.... Remove the cartridge Clean it and place it again.
Posted on Oct 30, 2012
  • 8 Answers
SOURCE: Black Ink won't print properly (Dell AIO 966)
black cartriges bad
Posted on Mar 16, 2008
JULIANFIX
  • 975 Answers
SOURCE: hp f380 with Visa OS not printing black
when ready to print go first to where it says PREFERENCES click there , and then slect BLACK CARTRIDGE ONLY ,just to be sure that is not the cartridge ,fun a print , see what happens. hope this helps
Posted on Apr 26, 2008
  • 137 Answers
SOURCE: black smudges on printed page
Are you sure this is a Designjet 450 (large format printer) and not a Deskjet 450 (portable printer)? The following assumes you have wispy black streaking on the printed side of the paper. If the streaking is on the back side then post more details of the printer model and the issue.
In either case the most likely cause is a buildup of fibers on the underside of the printheads or carriage, causing wisps of black ink to be dragged on the paper when the carriage reverses direction. You can clean the printer as shown at the following (though the details will be somewhat different for the Designjet or Deskjet....).
Regards,
Bob Headrick, MS MVP Printing/Imaging
Posted on Sep 16, 2008
SOURCE: Print faded after replacing black cartridge Brother 240C
The print heads don't appreciate being out of ink so the Brother printer has sensors to prevent that but the tape defeated that prevention. Maybe more cleanings or maybe a cartridge with printhead cleaning solution will help. Otherwise, I fear a new printer.
Posted on Jan 08, 2009
j0llyc
  • 8 Answers
SOURCE: Solid black line when scanning or copying from KODAK ESP-3
Get a damp soft cloth and clean the scanner glass. If that doesn't resolve the issue there is a chance the scanning unit itself is damaged.
Let me know.
Cheers, Chris
Posted on Jun 21, 2009
My kodak esp 6150 prints blank pages. I bought new ink and new print head and still prints and copies blank. Kodak support says I need new printer but there has to be a way to fix it. It was fine one day...
if u can't clean the print head and there is ink in the cartridge, then a new printer is in the plan.
try cleaning head by placing a pad soaked in alcohol (not Tequila) on the head for a while then gently wiping it clean. If u can remove other parts that r full of ink to clean them do that - careful that ink will get everywhere.
Dec 09, 2014 | Kodak ESP Office Equipment & Supplies
X2250 won't print form pc
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Good Luck!!!!
May 01, 2013 | Lexmark X2250 All-In-One InkJet Printer
Hp inkjet printing solid black page
Hi Robert, if you're trying to copy something that you've placed on the glass without closing the cover of the copier, there's too much back light (coming from behind the item to be copied) and therefore the resulting page will be black. The only light should come from within the copier itself.
If the item you're copying is bulky and will not allow the cover to close, try taking an 8-1/2 x 11 inch piece of paper and cutting out only enough of the page to allow your item (to be copied) to sit flat on the glass while covering the remaining exposed glass with the paper.
I hope this helps, good luck.
Jul 16, 2012 | HP Office Equipment & Supplies
Prints black
Remove the print head, inks come out first. then lift the arm on the right of the head , it lifts out , never touch the gold pads on the back be very carful of the bottom print head. don't let cotton or tissue clog or get in the very fine print head nozels. so dont rub hard be very gentle let the alcohol do its job. soak at least 5 min.
clean the head with alcohol, let it sit on a soaked clean cloth saturated with 96% isoprople. ink will flow out on to the cloth its
ok put fresh full inks back in and deep clean right away and all should be well
Feb 16, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon B640 printing problem
The scanner lamp is not working. When making a copy, the lamp lights the source document, so if there is no light, the source document 'looks' black. Your machine will need to be serviced.
Jan 26, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Printer Pixma MX700 will only print in color not black and white?
Try going into Control Panel and click on printers. Normal 0 when the next window comes up, Click on MAINTENANCE, the Properties page will come up and this is where you can do the NOZZLE check/clean and other functions. The NOXXLE is more than likely clogged from lack of use and needs to be cleaned. It might take several times to clean it. Hope this helps. Bud
Jan 08, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Printer prints solid black block at end of page
You have to replace the white tape, connecting the scanner sensor with the printer PCB. 26642b8.jpg
Nov 23, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Hp desk jet 920c ink cartridge
hi,
i think your color ink cartridge is near to empty that's why you are experiencing a pause printing..
try to replace it and try to print again..
rey...
Oct 08, 2008 | HP DeskJet 920c InkJet Printer
Dec 13, 2007 | Brother Multi-Function Center MFC-240C...
Seeker5211
Seeker5211
